Results 1 to 15 of 15
Thread: xfx8600gt Gpu problem
    • Banglavai's Gadgets
      • Asus Maximus VI Hero
      • Core i5 4670k
      • G-Skill Ripjaws X 2X 8GB 1600
      • 2X Samsung EVO 840 240GB
      • Gigabyte GTX 770 Windforce OC
      • Asus MX279H 27 inch
      • ROG SupremeFX 8-Channel High Definition Audio
      • Bose 301 Direct / Sennheiser Momentum 2.0
      • Logitech G105
      • Logitech G5
      • Xbox 360(usb wired)
      • Fractral Design 650 watt 80 plus gold
      • No need at all
      • Windows 8.1 64bit Professional
      • 100 Mbps
      • 30 Mbps
      • 146
    Banglavai's Avatar
    Oct 2009
    Helsinki, Finland
    Unhappy xfx8600gt Gpu problem
    My friend has a xfx 8600gt 512 mb gpu.it is used for 15 months.problem holo monitor e display dekhacche na.dui din ageo sob thik chilo.card chalale normal temp thake.dui din age o amak janay j or monitor er display majhe majhe chole jay.ami ok suggest kori j windows reinstall korte.kintu gotokal theke windows asha matro cpu restart nito.kintu ajk amar basay gpu ta laganor pore kono display show kortesena.or basateo show korena.ki prob hoise ei gpu tar.eta ki thik kora possible???
    kono kisu janate hole pls bolen.THANKS.
    • Albert SX65's Gadgets
      • A4 Tech KBS-8 Multimedia
      • A4 Tech 2X Office MOP-70D
      • Asus DRW-2014L1T
      • Transcend JetFlash V30(2gb)
      • Prolink 600V/A
      • 5.9 in win7
      • Quite Satisfied :-)
      • GrameenPhone - P2 Unlimited
      • 25KBps +
      • 15KBps +
    Albert SX65's Avatar
    Feb 2009
    Left Side Of Ur Brain.
    Default Re: xfx8600gt Gpu problem
    Apni ki bollen tar kisu bojlam na keu amare bujan. Moitor display dukhse na bolte ki bujai? Monitor display er sate win reinstall er ki somporko?
    Did you try to boot in to windows WITHOUT the GPU?
    And before blaming the GPU try it on other monitors, and can you see any burn or capacitor broken on the PCB?
    Let us know........
      • Core i5 4670k
      • Logitech G105
      • Logitech G5
      • No need at all
      • 100 Mbps
      • 30 Mbps
      • 146
    Banglavai's Avatar
    Oct 2009
    Helsinki, Finland
    sorry bro.ami ashole kothata gusaye bolte pari nai.
    ami mone korsilam j or computer e virus attack korse.karon or computer prithibir somosto virus er somonnoy e toiri.tai bhabsi j eita kono virus er karone hote pare jar jonno windows asha matro pc restart nicche.tai ok win install korte bolsilam.
    Quote Originally Posted by Albert SX65 View Post
    please read the post again.ami kothay likhsi j monitor display dukhsena??
    ---------- Post added at 17:54 ---------- Previous post was at 17:50 ----------
    thanx fatality bro.
    yeah i tried.and there is no prob in windows.windows ran smoothly without the gpu.but when i connected to it there were no display.And also i tried it to my pc.
    and i didn't found any capasitor broken and the card was clean.i think there is no burn problem.
      • Asus DRW-2014L1T
      • Prolink 600V/A
      • 5.9 in win7
      • 25KBps +
      • 15KBps +
    Feb 2009
    U read ur post again.
    Problem holo moitor e ...........
    Btw jeta main problem seta bole valo hoy.kar pc te ki ase seta projone jene nibo.
    monitor e ki kisu dhaka jai na?
    Full pc config ki?
    Gpu sara pc te display ki ase ?
      • Core i5 4670k
      • Logitech G105
      • Logitech G5
      • No need at all
      • 100 Mbps
      • 30 Mbps
      • 146
    Banglavai's Avatar
    Oct 2009
    Helsinki, Finland
    Albert Bhai ami apnar subidhar jonno ekdom clear kore boltesi.
    1.Gpu lagano thakle moniotor e kisu dekha jay na.(tested in 2 different cpu and 2 different monitor and got the same result)
    2.intregeted vga port e lagaile sob kisu philips battir moto poriskar dekha jay and monitor bondho hoy na and pc restart o ney na.
    Cpu config holo c2d 2.53ghz,2gb ddr2 800bus,samsung 17inch monitor.
      • Asus DRW-2014L1T
      • Prolink 600V/A
      • 5.9 in win7
      • 25KBps +
      • 15KBps +
    Feb 2009
    Philhps bati
    Gpu er warenty ase ki ?
    Jokhon gpu lagano hoy thokho gpu ki rokon gorom hoy ?
    • Arif69's Gadgets
      • Gigabyte H61 S2P B3
      • Intel Core i3 2100
      • Dell E1910H 18.5 Wide Lcd
      • VIA HD Audio Codec
      • Lexma LK7550P Slim
      • Logitech B100
      • Generic Usb Joystick
      • ITS 500 Watt
      • Samsung SH-224BB 24X
      • Transcend Jetflash350 16 GB
      • KS
    Philhps bati
    He has said early that gpu is 15 months used so i guess there is no warranty left .
      • Core i5 4670k
      • Logitech G105
      • Logitech G5
      • No need at all
      • 100 Mbps
      • 30 Mbps
      • 146
    Banglavai's Avatar
    Oct 2009
    Helsinki, Finland
    gpu eto gorom hoy na.normal gorom jake bole.
    r warrenty nai.
      • Asus DRW-2014L1T
      • Prolink 600V/A
      • 5.9 in win7
      • 25KBps +
      • 15KBps +
    Feb 2009
    Then cry.
    Btw counct avas @bg i think he may help u but im not sure.
    ---------- Post added at 19:28 ---------- Previous post was at 19:26 ----------
    Acha apner gpu ki bios o show kore na. R apni gpu port e sothik vabe cable use koresilan.don't mind.
    • @bhi's Gadgets
      • Gigabyte Z87X-UD3H
      • Samsung 30nm 2x4GB
      • Gigabyte HD7950 3GB WF3
      • Samsung 20" LED BX-2035
      • Creative SoundBlaster Z
      • Microlab Solo 7C
      • Logitech K-120
      • Logitech mx518
      • Seasonic X-650 km3 80+ Gold
      • Luminous Solo 1200 VA
      • Windows 8.1 x64
      • Link3 512kbps
      • ~60
      • ~55
    @bhi's Avatar
    On My Chair
    connect the monitor with the gpu with some other port like the dvi with a dvi to vgs converter..
    My cousin had once the same problem, later found out that the vga port of the gpu was broken but dvi was working..
      • Asus DRW-2014L1T
      • Prolink 600V/A
      • 5.9 in win7
      • 25KBps +
      • 15KBps +
    Feb 2009
    Yep folow abhi
    • |-<NOSALIS>-|'s Gadgets
      • Gigabyte GA-X58A-UD3R
      • Intel Core i7 930 2.8Ghz. LGA1366 Bloomfield with 8MB L3 Cache and 4.8GT/s QPI
      • 3x2GB Team Elite 1333Mhz. Performance RAM in triple channel
      • Samsung Spinpoint 160GB SATA II HDD
      • Spaahire Radeon HD 4890OC 1GB GDDR5
      • Samsung T220 22" LCD
      • Realtek 8-channel HD Audio
      • Microlab TMN-4 4:1
      • Perfect Multimedia
      • Dell Laptop Mouse 800Dpi
      • Clone PS2 Controller
      • Corsair TX650W PSU
      • ASUS 20X Dual-Layer DVD-Burner with LightScribe; Lite-on 16X DVD-ROM
      • Transcend StorJet C 500GB & WD Elements 160GB
      • Well 1200VA Generic
      • Windows 7 Enterprise 64-Bit
      • Windows Experience Index: 5.8(HDD); rest are 7.5+
      • Too much for me!
      • Mango TeleServices
      • 40-50Kbps
      • 40Kbps
    |-<NOSALIS>-|'s Avatar
    Jan 2010
    Mirpur, Dhaka
    Quote Originally Posted by Jaber17 View Post
    r warrenty nai.
    Brother, relax:zz:! Don't whit out. A friend with a Radeon X2600 had a similar problem. But that was due to excess overclock. Three of his capacitors blew out. But we got it fixed from Alpana Plaza. In April, we also got a D102GGC2 with shorted voltage regulator(or something; can't remember) repaired from the same shop. It was Computer Mate on Level 3 of Alpana Plaza. There is another shop called Madani Computers on the same floor. Sometimes they interchange their products for repair. Anyways, I hope will you have great luck if you could manage to go there. But it is, after all, a 50-50 chance! Either you will get this: or this:. Good luck!
      • Core i5 4670k
      • Logitech G105
      • Logitech G5
      • No need at all
      • 100 Mbps
      • 30 Mbps
      • 146
    Banglavai's Avatar
    Oct 2009
    Helsinki, Finland
    Thanx tahmid bhai.repair korte approx koto lagte pare??janale khushi hobo.thanx.
    • |-&lt;NOSALIS&gt;-|'s Gadgets
      • Samsung T220 22&quot; LCD
      • Transcend StorJet C 500GB &amp; WD Elements 160GB
      • Too much for me!
      • 40-50Kbps
      • 40Kbps
    Jan 2010
    Mirpur, Dhaka
    That card's condition was too critical. Even the fan would not get running. It took Tk.600 to be fixed. Initially Tk.800 was asked.
  1. Sale (Used) GeForce XFX8600GT 1GB for sale
    By Ridoy in forum Shop - Gadgets
    Last Post: October 11th, 2009, 09:38
  2. Little Problem With BG
    By SK in forum Feedback
    Last Post: July 31st, 2009, 00:34
  3. problem!!!!
    By Walking Death in forum Software
    Last Post: May 2nd, 2009, 11:22
  4. Got Problem
    By s.a_rocky in forum Older NFS Games
    Last Post: January 29th, 2009, 11:20
  5. dl problem in RS
Page generated in 0.26385 seconds with 14 queries.
