Results 1 to 8 of 8
Thread: Need help for CPU cooler positioning
    • Ony's Gadgets
      • Gigabyte G1 snipper 5
      • Core i7 4770 with DeepCool Mini FS
      • 1TB HDD(WD) .128GB SSD(Kingston) . 1TB external HDD transcend,128GB Transcend SSD370 (As Live CD)
      • Gigabyte GTX 750 TI Windforce edition
      • Dell S2240L
      • Gigabyte G1 snipper 5 internal extreme sound card
      • Samsung Earphones (S4 version) Works fine for me.
      • A4tech Bloody b120 gaming
      • A4tech Bloody ZL5 core 3 Activated
      • PS 1 with adapter
      • Thermaltake Smart 530W
      • Asus 24X
      • 16 Gb JF500,16 GB JF710S, 1TB external HDD,
      • Apollo 1000 VA Offline UPS
      • Windows 7 64bit , Ubuntu 14.04
      • Nothing big, just a starter PC for extreme gaming.
      • Delstar @ Eirtel
      • 512KB/s = 4Mbps
      • ^ in reverse
    Jul 2014
    Exclamation Need help for CPU cooler positioning
    Hello, My Case is the Corsair spec-01 , My problem is that i wanted to buy a CM hyper 212x . But i can position it only horizontally. Is there any problem if i place it horizontally? And are there any other good cpu cooler which have less then 150 mm hight ? ( some info: my GPU is the Gigabyte GTX 750 TI windforce edition)
    • Sybaris Caesar's Gadgets
      • Intel DH61WW B3 Rev.
      • Intel Core i5 2400 3.10 Ghz
      • Thermaltake Commander
      • Logitech G402
      • Original Xbox 360 Wireless
      • Cooler Master G550M
    Sybaris Caesar's Avatar
    Nowy Warsaw
    AFAIK you can post it horizontally or vertically as you wish.
    Just be cautious about airflow.
    My probable next build: Qisan MagicForce 68 (Outemu switch) / Teamwolf Zhuque+ 87 TKL (Outemu) / Monoprice Select series full size (Outemu/Gateron) / Drevo Gramr 84 TKL (Outemu) • Logitech G102 Prodigy • Deepcool Dukase V3 / Thermaltake Versa U21 • Superlux HD 681 • Creative Sound Blaster E1 • LG 22MP68VQ • SteelSeries QcK • Generic executive chair • others TBA
    djrock please don't bother me. You are in my ignore list so I don't have to see literal poop.
    • Ony's Gadgets
      • Dell S2240L
      • PS 1 with adapter
      • Asus 24X
      • Delstar @ Eirtel
      • 512KB/s = 4Mbps
      • ^ in reverse
    Jul 2014
    That is the problem . The GPU wish push hot air inside and the cooler will take that hot air. Won't that increase the cpu temp???
      • Logitech G402
    Nowy Warsaw
    when you put it hor. the gpu's back will take the hot air if you put the fan to intake air from the top of the casing.
    • MusharratC's Gadgets
      • MSI 990FXA G65
      • Asus VX229
      • Prachin JVC UX T1
      • Gigabyte Pulse 650W
      • Dead Powertree 1250VA
      • An ALMOST decent rig!
    MusharratC's Avatar
    Feb 2013
    afaik the gpu exhaust's the air out the back. put intakes on the front and bottom. exhaust on the back and top. if the cooler is horizontal put the cpu cooler's fan such that it pushes air to the top and out.
    • Ony's Gadgets
      • Dell S2240L
      • PS 1 with adapter
      • Asus 24X
      • Delstar @ Eirtel
      • 512KB/s = 4Mbps
      • ^ in reverse
    Jul 2014
    Quote Originally Posted by MusharratC View Post
    Problem is that there isn't any bottom fan positioning locations and the gpu pushes the air at the bottom .
      • Logitech G402
    Nowy Warsaw
    Quote Originally Posted by Ony View Post
    is your card reference model or an aftermarket? reference cards push the air from their back to the outside whereas aftermarket ones circulate inside the case. but you shouldn't worry too much about temp. 750ti's not that power hungry thus creates less heat. you can do it like this: put cooler horizontally, place intake fan on top, place exhaust on bottom, be happy. or you can do it vice versa. but gpu's back pcb(and surrounding air) tend to be warmer.
    • Ony's Gadgets
      • Dell S2240L
      • PS 1 with adapter
      • Asus 24X
      • Delstar @ Eirtel
      • 512KB/s = 4Mbps
      • ^ in reverse
    Jul 2014
    Okk will give it a try. I thing my gpu is a aftermarket one. . Let's what happens. Thanks for the help.
  1. Microlab solo 7c positioning!!!!
    By oceanpearl in forum General Discussion
    Last Post: February 15th, 2013, 17:28
  2. Want to Buy 2nd hand Cooler master 1155 CPU Cooler
    By fahimspider in forum Shop - Gadgets
    Last Post: January 18th, 2013, 18:45
  3. Stock cooler or Chinese Haofeng cooler for i5-2310
    By Camouflage in forum Others PC Hardware
    Last Post: August 21st, 2012, 13:37
  4. Sale (Used) Cooler Master Hyper N520 CPU Cooler
    By VIPERS in forum Shop - Gadgets
    Last Post: February 26th, 2012, 05:46
  5. Replies: 42
    Last Post: February 21st, 2010, 15:51
Page generated in 0.19242 seconds with 14 queries.
