Results 1 to 14 of 14
Thread: bootup problem
    • Mahfuz's Gadgets
      • Asus 9600GT 512MB
      • Asus ML239H 23'' IPS Panel
      • Never Interested :-/
      • Asus 18X DVD RW
      • RahimAfrooz 1000VA
      • Not half-bad.
      • 30KBps
      • 7KBps
    Mahfuz's Avatar
    May 2010
    মনে নাই
    Question bootup problem
    after turn on power button of pc ,bootup process stopped in mobo's logo screen and no matter how many time i try to reset its not responding at all .......i have to turn off the main switch and after about 5-10 minutes later it become normal......though its happened occasionally but i'm felling worry about this weird behaviour .....
    is that problem of BIOS ??? i checked BIOS version and its the latest one ....or psu ??
    asus p5qc P45 chipset ;
    C2D Q8200 2.33ghz 4mb L2 ;
    asus 9600GT 512mb DDR3 HDMI ;
    1x2gb transcend 1333 bus ram ;
    500gb hitachi sata HDD ;
    value top 400 watt psu with 34A available on +12V rails ;
    2x8cm and 1x12cm cooling fan ;
    • Albert SX65's Gadgets
      • A4 Tech KBS-8 Multimedia
      • A4 Tech 2X Office MOP-70D
      • Asus DRW-2014L1T
      • Transcend JetFlash V30(2gb)
      • Prolink 600V/A
      • 5.9 in win7
      • Quite Satisfied :-)
      • GrameenPhone - P2 Unlimited
      • 25KBps +
      • 15KBps +
    Albert SX65's Avatar
    Feb 2009
    Left Side Of Ur Brain.
    Default Re: bootup problem
    I think hdd problem or rom problem.remove all sata and ide cable from ur mobo then run ur pc again.
    if no problem found then its hdd or rom problem.
    Or if problem found then reset ur bios(remove battary from ur mobo and after 1hour later replace battary again and run ur pc)hope it will help u.
    Ya, follow Anik vai's sugessions. Also, reinstall the RAMs. And, check your monitor cable, and it might be monitor's problem too.
    • Uchiha Obito's Gadgets
      • ASUS P7H55M
      • A4Tech X7
      • 1 x Samsung DVD-RW
      • Transcend 16GB JetFlash 700
      • Windows 7 x64 + Linux x64
      • Didn't see till now.
      • RIG OK and Console Awesome.
      • BTCL ADSL 512kbps, 1mbps
      • 60KB/s and 120KB/s
      • Secret
    Uchiha Obito's Avatar
    Sep 2008
    Mymensingh, Bangladesh.
    Quote Originally Posted by Albert SX65 View Post
    Yeah do these.....
    and did you hear any sound while booting up in BIOS?
    hear if it broken or continuous.
    • Mahfuz's Gadgets
      • Asus 9600GT 512MB
      • Asus 18X DVD RW
      • Not half-bad.
      • 30KBps
      • 7KBps
    Mahfuz's Avatar
    May 2010
    মনে নাই
    anik :- most probably ami ekbar bios reset kore dekesilam ......
    OT: bios reset r flash ki ekoi jinish??? to solve this boot up problem, 1 of my friend suggested to flash the bios by removing mobo's jumper ....
    Rion :- ram er slot koykber change kore deksi karon age majemodde BSOD show korto ....ram er problem vebe tai koykber slot change kore deksi.....r cable e problem mone hoy na ase.... VGi r DVI 2 ta cablei same trouble dey..... could b monitor but how m i supposed to diagnosis monitor's problem ????
    Sumon :- umm , im in mym ri8 now ....could give ur ans saturday ni8 ....
      • ASUS P7H55M
      • A4Tech X7
      • Secret
    Sep 2008
    what is mym? :S
    • Mahfuz's Gadgets
      • Asus 9600GT 512MB
      • Asus 18X DVD RW
      • Not half-bad.
      • 30KBps
      • 7KBps
    Mahfuz's Avatar
    May 2010
    মনে নাই
    Quote Originally Posted by Sumon View Post
    what is mym? :S
    short form of mymensingh ..... :mellow:
    • Manzoor's Gadgets
      • Intel PM45
      • Core 2 Duo [email protected]
      • 2GB DDR3
      • Toshiba 320GB
      • ATI Radeon HD4570
      • 14" LCD @ 1366*768
      • Realtek HD Audio
      • Synaptics Multitouch Pad / A4 Tech XL-747H
      • A cheapo Chinese one
      • Transcend StoreJet 80GB
      • Windows 7 x64 / Ubuntu 10.04
      • Windows Experiance Index - 5.0 (Windows7)
      • Toshiba L510-S4314
      • Smile Silver
      • 20~25Kbps
      • 10~15Kbps
    Manzoor's Avatar
    Try to enter BIOS by pressing DEL at boot up. If that fails, open your casing reattach everything (Graphics card, RAM etc.). If it still fails to boot, probably motherboard has problem. Claim warranty before it's too late. If you're not comfortable with opening your casing just take your CPU from where you purchased it. They'll take care of it.
    You never fail until you give up...
      • ASUS P7H55M
      • A4Tech X7
      • Secret
    Sep 2008
    Quote Originally Posted by amateur_geek View Post
    Do you live in mym?
    I am too.:S
    • Mahfuz's Gadgets
      • Asus 9600GT 512MB
      • Asus 18X DVD RW
      • Not half-bad.
      • 30KBps
      • 7KBps
    Mahfuz's Avatar
    May 2010
    মনে নাই
    Quote Originally Posted by Manzoor View Post
    problem ta sobsomoy hoy na bro ....tobe tmi ja bolso tar kisui ami bad dei nai /*even d warranty issue ...... vendor already changed mobo but thats irrelevant now cz it was not for this problem.... */
    sumon : not really , though its my hometown.... my uni is dhk so have to stay in dhk for last 1.5years ..... but nice to see some one who belonging in my hometown .....
      • ASUS P7H55M
      • A4Tech X7
      • Secret
    Sep 2008
    ooo.
    nice.
    • Manzoor's Gadgets
      • Intel PM45
      • 2GB DDR3
      • Toshiba 320GB
      • ATI Radeon HD4570
      • Realtek HD Audio
      • Smile Silver
      • 20~25Kbps
      • 10~15Kbps
    Manzoor's Avatar
    If you're sure your motherboard is ok, then there might be problem with your power supply. Try with a different power supply.
    • |-<NOSALIS>-|'s Gadgets
      • Gigabyte GA-X58A-UD3R
      • Intel Core i7 930 2.8Ghz. LGA1366 Bloomfield with 8MB L3 Cache and 4.8GT/s QPI
      • 3x2GB Team Elite 1333Mhz. Performance RAM in triple channel
      • Samsung Spinpoint 160GB SATA II HDD
      • Spaahire Radeon HD 4890OC 1GB GDDR5
      • Samsung T220 22" LCD
      • Realtek 8-channel HD Audio
      • Microlab TMN-4 4:1
      • Perfect Multimedia
      • Dell Laptop Mouse 800Dpi
      • Clone PS2 Controller
      • Corsair TX650W PSU
      • ASUS 20X Dual-Layer DVD-Burner with LightScribe; Lite-on 16X DVD-ROM
      • Transcend StorJet C 500GB & WD Elements 160GB
      • Well 1200VA Generic
      • Windows 7 Enterprise 64-Bit
      • Windows Experience Index: 5.8(HDD); rest are 7.5+
      • Too much for me!
      • Mango TeleServices
      • 40-50Kbps
      • 40Kbps
    |-<NOSALIS>-|'s Avatar
    Jan 2010
    Mirpur, Dhaka
    Geek bro,
    I had same problem few years back. It was simply my HDD cable and jumper. Do you have all Sata drives or mixed configuration (including DVD Writer)? If you have all SATA drives, interchange the connectors in the motherboard. If you use SATA and PATA both, try switching the jumpers in the PATA drive. This problem also sould be because of a bad cable. Remove all cables and then try to boot to BIOS. If it does boot, it could be the problem with a bad cable. Also remember, SATA should never be aligned at 90 degrees. It hampers data flow. This is what is written in my last motherboard's manual.
    • Mahfuz's Gadgets
      • Asus 9600GT 512MB
      • Asus 18X DVD RW
      • Not half-bad.
      • 30KBps
      • 7KBps
    Mahfuz's Avatar
    May 2010
    মনে নাই
    could b ....... that's why mentioned about it on d 1st thread :S
    Quote Originally Posted by mdtahmid View Post
    Geek bro,
    thnx (+repu)...... lets try ur therapy.....
  1. Webcam Problem
    Last Post: October 7th, 2009, 00:43
  2. Little Problem With BG
    By SK in forum Feedback
    Last Post: July 31st, 2009, 00:34
  3. problem!!!!
    By Walking Death in forum Software
    Last Post: May 2nd, 2009, 11:22
  4. Got Problem
    By s.a_rocky in forum Older NFS Games
    Last Post: January 29th, 2009, 11:20
  5. dl problem in RS
Page generated in 0.26333 seconds with 14 queries.
