Thread: Virtualbox save state problem during Host shutdown
    Default Virtualbox save state problem during Host shutdown
    @CvP @Codex
    I have been trying to save state of my virtualbox guest OS (XP) while my UPS is initiating a shutdown in the host OS (Windows 7 x64).
    But the problem is during the shutdown initiation, the virtualbox pops up a dialog box for the guest OS (Save machine state,send shutdown signal,power off machine)
    This dialog box prevents the shutdown process.
    Is there any way I can make ALT+F4 to do Savestate of guest OS instead of popping up the dialog box?
    *The ups software tries to close everything with ALT+f4
    Noblesse Oblige
    • CvP's Gadgets
      • ASUS P8Z77 V Delux
      • Intel Core i7 3770K @3.9GHz
      • EVGA 980Ti 6GB
      • Samsung 17"+22"+22"
      • Realtek HD Audio <internal>
      • Creative Inspire 5:1
      • Razer BlackWidow Ultimate
      • G7
      • Seasonic X 850W 80Plus Gold
      • External DVD-RW
      • Link3/Amber IT
      • 10000
      • 10000
    CvP's Avatar
    You should consult virtualbox documentation.
    Usually, they will have some command line that can do something directly. Then you need to execute that from UPS software instead of alt+f4.
    alternatively, you can use taskkill /f
    Ok problem solved by doing below and future ref for anyone who is in similar situation.
    updated to virtualbox 4.3.12 & installed VBoxHeadlessTray.exe
    Now Vboxheadlesstray detects hosts shutdown and save guest OS before shutdown. Vboxheadlesstray also resume guest OS during bootup with
    This shortcut dropped at windows startup folder ==> "C:\Program Files\Oracle\VirtualBox\VBoxManage.exe" startvm "1" (1 is the name of guest OS) virtualbox documentation helped!! @CvP
  1. CoD 4 Host Problem in GameRanger
    By gunner93 in forum Call of Duty
    Last Post: February 12th, 2013, 01:07
  2. pc auto- shutdown problem
    By wayne in forum Technical Support
    Last Post: July 16th, 2012, 23:35
  3. browsing problem - generic host process..
    By Noob in forum Software
    Last Post: December 7th, 2010, 19:53
  4. CoD 4 Cod 4 host Problem!
    By $hr in forum Call of Duty
    Last Post: August 17th, 2010, 23:54
  5. Generic Host Problem
    Last Post: October 30th, 2008, 02:14
Page generated in 0.15795 seconds with 14 queries.
