Results 1 to 6 of 6
Thread: banglalion Network Searching Problem
    • riajulzanna's Gadgets
      • Gigabyte H81-S2PV
      • Intel G3220
      • Transcend 8GB DDR3 1600
      • Hitachi 1TB
      • GTX 550 TI
      • Asus VS197D LED 18.5''
      • Realtech Audio
      • 5:1 Sound System
      • Deluxe K9020
      • A4Tech Bloody V3
      • Atech :p
      • Thermaltek TR2 RX 450 watt
      • Banglalion,GrameenPhone
      • 1mbps
    riajulzanna's Avatar
    Nov 2013
    Question banglalion Network Searching Problem
    Hi,
    I hv a problem with my banglalion modem.when i connect the modem it shows searching...searching...searching.
    bt it fails to find the banglalion network.
    The "wait for connection" screen not appears even after half an hour!
    Recently It causes that disappoinment although it was working very sound in the near past...
    I'm in a strong Network coverage area.
    Any Solution ?
    1. Re-Install Drivers
    2. Modem air-tight packet e kore 30min er jonno deep fridge e rekhe dekhen. (Used to work like a charm wih me)
      • Gigabyte H81-S2PV
      • Intel G3220
      • Hitachi 1TB
      • GTX 550 TI
      • Realtech Audio
      • 5:1 Sound System
      • Deluxe K9020
      • A4Tech Bloody V3
      • Atech :p
      • 1mbps
    Nov 2013
    tarpor ki oita icecream hishebe khaoa jabe ??
    Signature ta vallagche vaa
    Quote Originally Posted by riajulzanna View Post
    khaite paro, dat bhangle blion dayi ami na :v
      • Gigabyte H81-S2PV
      • Intel G3220
      • Hitachi 1TB
      • GTX 550 TI
      • Realtech Audio
      • 5:1 Sound System
      • Deluxe K9020
      • A4Tech Bloody V3
      • Atech :p
      • 1mbps
    Nov 2013
    Problem ta ki ar karo hocce naaki only me....?
    modem signal receive ee korteche na.....1st e vabchilam as usual oder server down
    bt pore dekhi onnoder colteche......amar cole na
    ok..i have had this problem before. The best solution is reinstalling windows by formatting the c drive (in windows 8 and 7 it will keep a backup anyway). If that is not possible download revo uninstaller. Then make sure that you use the advanced option while uninstalling. Revo will show a list of junk files created. Make sure to tick all the junk files and click the delete button. Please reply whether it worked or not. Hope it helped.
  1. Getting ventrilo/mumble work on Banglalion/Qubee network
    By Anjan Bhowmik in forum World of Warcraft
    Last Post: April 7th, 2013, 15:33
  2. Replies: 3
    Last Post: January 14th, 2013, 01:37
  3. Sony Ericsson W890 Network Problem
    By king_showrav416 in forum Technical Support
    Last Post: July 26th, 2012, 14:25
  4. Network adapter problem
    By lordminhaz in forum Technical Support
    Last Post: November 1st, 2011, 14:05
  5. How is the network of Banglalion in Dhanmondi-Kalabagan ?
    By Codename-Scorpion in forum WiMAX
    Last Post: March 13th, 2010, 15:36
Page generated in 0.17781 seconds with 15 queries.
