Results 1 to 14 of 14
Thread: Need suggestion on good ups battery
    • codename5302's Gadgets
      • Gigabyte X99-UD5 Wifi
      • Zotac 980Ti Amp Extreme
      • Fiio Andes E07K
      • Corsair RM850
      • 2 * Prollink 1200VA
      • Windows 7 64Bit
      • It works!!
      • 154
    codename5302's Avatar
    Default Need suggestion on good ups battery
    I have a prolink 1200va ups. the batteries are worn out now. where can i get quality replacement batteries? i have another 650va ups. i got the battery replaced by computer clinic. and it is working very good but that battery is not available anymore. so looking for suggestion for good battery (if there is any specific brand) and their availability. thanks in advance.
    * "o" is missing in the title. sorry for that.
    Nobabpur shondorbon market. Battery name long 7amp costs 900 taka with 6 month warranty.
    for how long u have been using that prolink 1200va ups?
      • Fiio Andes E07K
      • Corsair RM850
      • Windows 7 64Bit
      • It works!!
      • 154
    bought in 2012. at the end. so almost 18 months used.
    is 7amp battery enough for 1200va ups? i mean i never looked inside the ups. are 650va ups battery and 1200va battery same?
    Im quite sure that ur ups currently uses 2 x 7 or 9ah sla battery in series (24v system)
    both 7 & 9 ah battery is identical in shape and size.
    but u can opt to get 2x12ah battery (1800taka each made in vietnam)for longer backuptime given the fact that ur ups is in good condition and have active cooling system & u dont mind mounting them externally.
      • Fiio Andes E07K
      • Corsair RM850
      • Windows 7 64Bit
      • It works!!
      • 154
    thanks for the help. i think i will go to nawabpur for battery. any specific brand would you recommend?
    This is how i hooked my extra battery bank in addition to built in battery of the ups.
    i suggest long Brand with 6 month warranty.
ID:	34241   Click image for larger version.
ID:	34242   Click image for larger version.
ID:	34244   Click image for larger version.
    • Rubab's Gadgets
      • Gigabyte B85M-D3H
      • Intel Core i5 4570 3.2GHz
      • G.SKILL Ripjaws (2 x 4GB) DDR3 1600 Bus
      • Samsung 840 Evo 120 + Samsung HD103SJ 1TB
      • Sapphire Dual-X R9270X 2GB
      • Benq V2220HP
      • Realtek HD Built-In
      • Creative 2:1
      • Ortek Multimedia MCK-800
      • Logitech HD Optical Mouse
      • Corsair CX600
      • Lite-On DVD-RW / Asus-DVDROM
      • Power Tree 1250P Offline UPS
      • A decent rig. :)
      • NOT Link3
    Rubab's Avatar
    Apr 2009
    This is how i hooked my as extra battery bank in addition to built in battery of the ups.Attachment 34240
    i suggest these Attachment 34239
    The attachments aren't showing.
    • Muhammad Zunaid's Gadgets
      • ASRock H55M-LE
      • G Skill Ripjaws [4GBx2]=8GB
      • Samsung SyncMaster T220
      • Inbuilt Realtek Codec
      • Altec Lansing VS4121
      • Tt esports KNUCKER
      • Genius standard mouse
      • Canon Lide110 Scanner
      • RA 1000VA + Powertree 650VA
      • want to upgrade soon!
      • LINK3
    Muhammad Zunaid's Avatar
    powertree ups reseller superior-bd sells batteries seperately for 1100tk a piece[not exactly sure about the price]. same old 6 month warranty. it's a 8.2 Ah battery suggesting a bit longer run/backup time. i am currently using a max volta battery bought for 1000 each from laboratory road 2 months back [the 2nd hand market opposite multiplan center] running in my RA 1000VA ups.
    my previous experience with a 1200VA ups ['star' if i remember the name correctly]was bought back in 2008 had 2 separate 8.2Ah 12V batteries.
      • Fiio Andes E07K
      • Corsair RM850
      • Windows 7 64Bit
      • It works!!
      • 154
    that setup looks very good to me. but i dont think i can do that. i dont have that much technical knowledge to setup batteries outside.
    if u can make sure that ur ups unit is in good condition then i can help u to mount the batteries in correct order.
      • Fiio Andes E07K
      • Corsair RM850
      • Windows 7 64Bit
      • It works!!
      • 154
    I am pretty much sure it is in good condition. i put the UPS in a way that very little dust can reach inside. also under good ventilated area. i will be going to Nawabpur sometime in the first week of next month. if i got the batteries and if you get any chance to spare your time at that time then definitely i will take your help. many thanks for the offer.
    I have bought two 9Ahr for my 1200VA ups. See if u can get more than 7Ahr.
      • Fiio Andes E07K
      • Corsair RM850
      • Windows 7 64Bit
      • It works!!
      • 154
    could you please tell me where i can find 8.2 or 9ah battery in dhaka? i know nawabpur is the best place but it is way too far from my home and work place. any chance of getting in IDB or multiplan?
    Ground floor, idb. Bought two of them a few days ago. 2300 taka, 2 9 amp hour batteries.
  1. Need Good ISP Suggestion in Mirpur-12
    By partha1994 in forum ISP
    Last Post: August 23rd, 2014, 22:04
  2. Need suggestion for headphone with good mic
    By TaherTheRetard in forum Help - General Shopping
    Last Post: March 19th, 2014, 12:41
  3. Sale (Used) Two 7.5A UPS Battery is up for sale (Sealed Lead Acid Battery)
    By minitt in forum Shop - Gadgets
    Last Post: April 21st, 2012, 23:00
  4. Suggestion for a good router
    By Disturbed in forum Internet
    Last Post: May 17th, 2011, 03:18
  5. Suggestion For a Good UPS to handle my RIG
    By Rakin the Devil in forum Help - General Shopping
    Last Post: February 17th, 2011, 13:53
Page generated in 0.25756 seconds with 15 queries.
