Thread: Monitor problem
    Exclamation Monitor problem
    My monitor is LG E2040T. Suddenly my screen turned white and images are occurring blurry like the picture i have attached. Theres white lines all over the screen. I had also unplugged the DVI cable from GPU and plugged it into the mobo thinking it might be GPU problem but it still persists. How do i fix this? Please reply.
ID:	34129Click image for larger version.
    Quote Originally Posted by Xel-Naga View Post
    50% chance = cable problem
    other 50% chance = monitor problem
    I would say, change the cable and see if the problem exists.
    is there any place where i can fix my monitor?
    Try a different power cord and VGA/DVI cable, and then think about repairs.
    • shoryuken-x's Gadgets
      • msi
      • 8gb ( to power black x)
      • 1/2 tb
      • Radeon HD 7950
      • 21.5 lcd
      • lagano hoy ni
      • Genius Gx Sw-1250
      • Delux t15s
      • venge gese
      • Tt toughpower XT 675
      • few here nd there
      • 600va
      • jana nei
      • silent htpc
      • antbd
      • 60+
      • Do
    shoryuken-x's Avatar
    ^^^^^^^^^^^^that
    then warranty te die ashen
    • Overlord's Gadgets
      • Asrock Z370 Pro4
      • Geil 8GB DDR4 2400
      • MSI GTX 970 OC Gaming 4G
      • ASUS VX229H IPS 21.5 LED
      • Built in HD Audio
      • MicroLab 2.1
      • AutoKey Gaming
      • USB Gamepad
      • Corsair VS450
      • Samsung 22X DVD RW
      • Weli Power 800VA
      • Satisfied
      • Antaranga
      • 3 Mbps
      • 3 Mbps
    Overlord's Avatar
    I had this exactly same problem. RMA te disilam. Etar kono solution nai. Global amake kisu add kore 22 inch monitor nite bolsilo. But i traded with Viewsonic as the LG was not bought from Global but from Anex. Amake 3 month ghuraise. I will never buy any LG products in my life. never.
    Quote Originally Posted by Overlord View Post
    great. so this means i have to buy a new one? :/
    i bought it from Ryans. unfortunately lost the warranty paper. used this for only 2.5 years. age janle LG nitam na.
    already tried another cable. still the same.
    If it's only 2.5 years old, take it to the shop. They might be able to retrieve the receipt from it's serial number, assuming your monitor is under 3 years warranty.
    I think the ribbon connection from your TCON board to the Panel is damaged or the panel itself is damaged inside. Test if the white lines change pattern or disappears when you press or knock on the dop side of the monitor bezel. Unfortunately, there is no good fix for this in any way. Try to get warranty ASAP.
  1. Monitor problem
    By Arka karlos in forum Others PC Hardware
    Last Post: January 12th, 2013, 11:05
  2. CRT monitor problem
    By Cpt.Mactavish in forum Technical Support
    Last Post: March 12th, 2012, 11:18
  3. monitor or gpu problem?
    By offcutter in forum Technical Support
    Last Post: September 12th, 2011, 13:51
  4. Monitor problem
    By wasi006 in forum Others PC Hardware
    Last Post: April 26th, 2011, 09:23
  5. Monitor problem
    By Dee in forum Others PC Hardware
    Last Post: October 5th, 2010, 08:51
Page generated in 0.20688 seconds with 15 queries.
