Thread: dvd writing problem but dvd writer can read and copy data from earlier burned discs......
    • knroeoueqisk's Gadgets
      • Intel Core i5 750
      • Cosonic head phone
      • Perfect keyboard
      • Delux optical mouse
      • Normal Non brand gamepad
      • Thermalake TR2 500 watt
      • Samsung 22X Dvd Writer
      • i am happy with it.
      • 15 Kilobytes - 64 Kilobytes
      • 5-15 kilobytes
    Dec 2009
    Default dvd writing problem but dvd writer can read and copy data from earlier burned discs......
    i am using an asus dvd writer.so i was burning a few blanc dvds yesterday morning without any problem.then suddenly when i tried to burn a blanc dvd.this message was shown and i can't burn any blanc DVDs.i tried another blanc dvd disc but same message shows up.
    here is the message that shows up with writing failure.
    @ .... time caching of files started
    '' caching of files completed
    '' Burn process started at 16X (22,160KB/s)
    " J:ASUS DRW-1608P3S
    write error
    J:ASUS DRW-1608P3S
    @... time Writing short lead-out
    session fixation error
    J:ASUS DRW-1608P3S
    @... time J:ASUS DRW-1608P3S
    could not perform end of disc-at-once
    @... time Burn process failed at 16x (22,160KB/s)
    i am using Nero ultra 7.i tried both Nero Burning Rom and Nero Express.but same message shows up. plus i also tried with lower speeds like 12x/8x/4x. also my dvd writer is reading my earlier burned disc and i can copy data from those discs to hard disc.
    and for some reason after this problem started Nero also acting weirdly.when i try to burn dvds using Nero Burning Rom nero crashes but if i try Nero Express then burning process starts but after a few moments burn fails and shows up above mentioned message.i uninstalled Nero ultra 7 (deleted old registry entrys using CCleaner and reinstalled Nero Ultra 7 a couple of times but no positive result.
    so is the problem software or hardware related?
    Default Re: dvd writing problem but dvd writer can read and copy data from earlier burned discs......
    reinstall the ODD: open up the case, re-plug the drive into your motherboard's SATA or IDE port & give it a go.
    If that doesn't work, try a different burning software like PowerISO. If this method fails, then I guess it's a hardware failure!
      • Intel Core i5 750
      • Perfect keyboard
      • 5-15 kilobytes
    Dec 2009
    well i reinstalled the ODD once yesterday.so i am gonna try your next advice.i will try PowerIso plus another version of Nero.thanks for your suggestions.+ repu for you bro.
    • Manzoor's Gadgets
      • Intel PM45
      • Core 2 Duo [email protected]
      • 2GB DDR3
      • Toshiba 320GB
      • ATI Radeon HD4570
      • 14" LCD @ 1366*768
      • Realtek HD Audio
      • Synaptics Multitouch Pad / A4 Tech XL-747H
      • A cheapo Chinese one
      • Transcend StoreJet 80GB
      • RahimAfrooz 1000VA
      • Windows 7 x64 / Ubuntu 10.04
      • Windows Experiance Index - 5.0 (Windows7)
      • Toshiba L510-S4314
      • Smile Silver
      • 20~25Kbps
      • 10~15Kbps
    Manzoor's Avatar
    Nero bad dilei ki valo hoy na? Nero ekhon onek bloated hoye gese. Free and Opensource onek valo valo burning soft ase. Ami personally Burnaware use kori. Valo valo alternative thakte crack nia ganjam korar ki dorkar. Tobe dip jeta bolse onno soft e kaj na hoile hardware failure dhore nite hobe. Last try hishabe clean Windows setup ar lens cleaner try kore dekha jete pare.
      • Intel Core i5 750
      • Perfect keyboard
      • 5-15 kilobytes
    Dec 2009
    Quote Originally Posted by Manzoor View Post
    hmm thanks for sharing your experience and for suggesting me burnaware.i searched in google and found some freeware dvd burning software which i am going to try like ImgBurn ,BurnAware Free.ei duita bole free dvd burning software er moddeh best.
    ar egula kaj na hole mone hoy windows clean setup dite hobe.
    Quote Originally Posted by kung fu panda_4444 View Post
    yep, go for Manzoor bhaiya's suggestion. I recommend PowerISO as I found it the most clean interface with image support. Alternatively you can cleanse the lense OR do a firmwire update, but it's very confusing!
    My DVD Combo drive was cured after doing a firmwire update, after months of usage...it couldnt write CDs anymore haha.
      • Intel Core i5 750
      • Perfect keyboard
      • 5-15 kilobytes
    Dec 2009
    ei mas 2-3 ageo amar dvd writer er problem hoisilo.kono dvd ba cd write ba read konotai korto na.tarpor dokane nia gele writer ta khulle vitore brash dula poriskar kore disilo tarpor theke valoi cholsilo .but ei kalke theke abar somossa hocche.lens cleaner ase but khujte hobe kothay jano rakhsi.tarpor writer lense clean korbo.firmwire update kemne kore jani na.asha kori firmware nia gatagati kora lagbe na.
  1. problem with dvd writer
    By knroeoueqisk in forum Others PC Hardware
    Last Post: February 22nd, 2010, 16:53
  2. pendrive to HDD copy problem
    Last Post: October 15th, 2009, 23:10
  3. writing bengali in forums
    By s.a_rocky in forum Software
    Last Post: December 10th, 2008, 04:40
  4. Writing Bangla in Photoshop
    By Necray in forum Technical Support
    Last Post: November 11th, 2008, 15:49
  5. Debate - writing bengali in forums
    By s.a_rocky in forum Miscellaneous Topics
    Last Post: August 28th, 2008, 14:17
Page generated in 0.18850 seconds with 14 queries.
