Results 1 to 20 of 23
Thread: Need Urgent Help(Very strange Problem)
    • shuvo121's Gadgets
      • Asrock Z77 extreme 4
      • Intel core i5 3570k 3.4 GHz
      • 6 GB
      • 500 GB
      • Evga gtx 690
      • Samsung 21 inch Lcd
      • Microwlab 5:1
      • Tharmaltake smart power 750w
      • Windows 7
    shuvo121's Avatar
    Default Need Urgent Help(Very strange Problem)
    Amr boro vai er pc er Configuration:
    Motherboard:Intel DH55PJ
    Processor:Intel core i5 350M
    Graphic card:Ati readon 7770
    Ram:4*2 GB 1333Mhz
    Problem:First amr boro vai 8GB(2*4) transcend er ram use korto,Pore se 1ta 4GB sell kore day.Erpor Onno 4GB dia se tar pc onk din chalayse.Kisudin chalanor por se thik kore 8GB single Ram kinbe,Tai se 4GB single ram ta sell kore day and 8GB ekta ram kine ane,Kintu ram laganor por pc sudhu restart hote thake and windows o dhoke na,ei problem er karone take ekjon bole je 2*4GB ram ante.pore uni single 8GB change kore 2ta 4GB twinmos er ram kine nia ase, Kinto ekane ekta odvut problem 2 ta ram eksathe lagale pc restar mare and windows e dhoke na, uni linux dia boot korar try korse but pc hang hoye jay,Kinto single ram use korle windows e dhoke but kisukon por hang hoye jay....plz help....
    • Hamilton's Gadgets
      • Gigabyte H97 Gaming 3
      • Intel Core i7 4770 3.9Ghz
      • 16GB DDR3 1600hz
      • Nvidia GTX 1070 FE 8GB
      • Asus VS228N 21.5" Full HD.
      • Roccat Arvo
      • Cooler Master GX 650W.
      • 500GB
      • Windows 7/ Linux
      • 3DMARK Score, X2151.
      • Smile, BD.COM
      • 75KBPS(Variable)
      • 100+KBPS(Variable)
    Hamilton's Avatar
    Reasons:
    1. Possible damaged "Ram Slots" on the motherboard.
    2. Check the bus speed.
    3. Faulty ram(check it by one by one)
    Also, if your motherboard has 4 RAM slots then try doing this, place the ram by 1-x-1-x slot, not by 1-1-x-x or 1-x-x-1. And sometimes windows stops working for faulty ram but it's highly likely that you might see a blue screen of death.
    • [email protected]'s Gadgets
      • Asrock Z68 extreme 4
      • Core I5 2500k @ 4.4ghz
      • 8 GB corsair 1600 mhz
      • 1 TB hitachi
      • Sapphire HD 7970
      • 21.5 B2230 samsung
      • f&D
      • Thermaltake Smart power 650W
      • Luminious 1000VA
      • Windows 7 64 bit
      • Antaranga
      • 1Mbps
    xer@x's Avatar
    may b ram slots er problem
      • 6 GB
      • 500 GB
      • Evga gtx 690
      • Microwlab 5:1
      • Windows 7
    shuvo121's Avatar
    Ram slot er problem na karon vai 2 slot e ram lagay check korse,ekon ekta ram e pc choltese but dui ta ram lagale problem...bus speed 1333Mhz...Ram thik ase onno pc te check kore deka hoise....ar ram slot 2 ta...
    • fahimspider's Gadgets
      • MSI P67A GD65(B3)
      • TWINMOS 8 GB 1600 BUS
      • Saphire ATI HD 7950 Dual-X
      • HP 18.5 INCH LCD
      • Microlab 2.1
      • Tt E-sports Knucker
      • Tt Theron mouse
      • Razer Nostromo
      • Asus DVD RW. HP DVD ROM
      • Apollo 1200 VA
      • WINDOWS 7 64 BIT
      • 7.5 WEI
      • ROCKING
      • SmileBD
      • 300-600kbps
      • 250-450kbps
    fahimspider's Avatar
    have you checked timing (cl) of both ram and voltage? do they match?
    btw your processor i5 350M?
      • 6 GB
      • 500 GB
      • Evga gtx 690
      • Microwlab 5:1
      • Windows 7
    shuvo121's Avatar
    Yes they have same voltage 1.5 and same timing 9 9 9 24..
    • Ony's Gadgets
      • Gigabyte G1 snipper 5
      • Core i7 4770 with DeepCool Mini FS
      • 1TB HDD(WD) .128GB SSD(Kingston) . 1TB external HDD transcend,128GB Transcend SSD370 (As Live CD)
      • Gigabyte GTX 750 TI Windforce edition
      • Dell S2240L
      • Gigabyte G1 snipper 5 internal extreme sound card
      • Samsung Earphones (S4 version) Works fine for me.
      • A4tech Bloody b120 gaming
      • A4tech Bloody ZL5 core 3 Activated
      • PS 1 with adapter
      • Thermaltake Smart 530W
      • Asus 24X
      • 16 Gb JF500,16 GB JF710S, 1TB external HDD,
      • Apollo 1000 VA Offline UPS
      • Windows 7 64bit , Ubuntu 14.04
      • Nothing big, just a starter PC for extreme gaming.
      • Delstar @ Eirtel
      • 512KB/s = 4Mbps
      • ^ in reverse
    Jul 2014
    May be bios problem, Motherboard er battery khule kichu time wait kore abar lagan. Remember to unplug ur PSU from the motherboard.
    Shob khule abr lagiea dhekte paren
    • _batman's Gadgets
      • msi Z87-GD65 inside Corsair Carbide 300R Windowed Edition
      • Intel Core i5 Devil's Canyon with CM Hyper 212X
      • G.Skill TridentX 8GB DDR3
      • Transcend SSD720, WDC20EZRX, WDC 10EZEX, WDC 5000AAKX
      • msi gaming x rx480
      • Viewsonic VX2270S 21.5'' IPS LED + Philips
      • Realtek ALC 1150 with Creative SBC
      • Piston 3 (Dead), Iron Ring Pro, Iron Ring HD
      • Logitech K120, Blackwidow X Chroma
      • Bloody A6, Logitech M557
      • Xbox 360 (Dead)
      • CM V650 Semi-Modular (80+ gold, active PFC)
      • Asus
      • WD My Passport, My Passport Ultra
      • Powerguard 1200 volt-ampere simulated sinewave
      • Win 7 Ultimate 64-bit / Windows 10
      • So... many... X
      • ~500KBps
      • 1/2 of download
    _batman's Avatar
    Jun 2013
    Processor khule mainboarder socket check koren, kono bent pin ase kina. Ekta G1 boarder pin bent thakar karone eirokom problem hoisilo, but seita notum board chilo so ferot pathao hoisilo.
      • 6 GB
      • 500 GB
      • Evga gtx 690
      • Microwlab 5:1
      • Windows 7
    shuvo121's Avatar
    Vai sob kisu korse but 4GB 2 ta dile problem hosse but vai tar ek friend er ram ene chalasse 2*2GB ekn pc valo vabe choltese!!!Eta kivabe possible????
    Probably those RAMs aren't supported.
    http://www.intel.com/support/motherb.../CS-031469.htm
    Try different RAM.
    • Overlord's Gadgets
      • Asrock Z370 Pro4
      • Geil 8GB DDR4 2400
      • MSI GTX 970 OC Gaming 4G
      • ASUS VX229H IPS 21.5 LED
      • Built in HD Audio
      • MicroLab 2.1
      • AutoKey Gaming
      • USB Gamepad
      • Corsair VS450
      • Samsung 22X DVD RW
      • Weli Power 800VA
      • Satisfied
      • Antaranga
      • 3 Mbps
      • 3 Mbps
    Overlord's Avatar
    @shuvo121 Its Your board, not ram. Intel DH55 series has compatibility issue as they are old and do not have any bios update. Gigabyte R9 270X does not run/boot in DH55WB. But a sapphire one runs perfectly. Because the card is compatible for older boards. this is the case may be.
    Either change your board or Brand of ram.
    • mithun12ka4's Gadgets
      • Gigabyte B75M-D3H
      • Intel Core i3-3220
      • Transend 4x2 Gb 1600Mhz
      • Western Digital Caviar Blue 1TB, Samsung Spinpoint F3 500 GB and Seagate Barracuda 3TB
      • Sapphire Radeon HD 7790 OC Dual-X
      • LG 22" Class Widescreen LCD (W2243T)
      • FND 2.1
      • A4-Tech ComfortKey KR-85
      • A4-Tech OP-620D USB
      • Havit HV-G83
      • Corsair VS450
      • Mazeda
    Oct 2013
    Definitely compatibility issues. i5 350M doesn't support 1333 mhz bus speed. They support either 800mhz or 1066mhz. Whereas the motherboard supports 1333Mhz or 1066Mhz. So either try to downclock the ram to 1066Mhz or try using ram which is by default 1066mhz. And one more thing the mother board doesnt support 8GB sticks.
      • MSI P67A GD65(B3)
      • HP 18.5 INCH LCD
      • Microlab 2.1
      • Tt Theron mouse
      • Razer Nostromo
      • Apollo 1200 VA
      • WINDOWS 7 64 BIT
      • 7.5 WEI
      • ROCKING
      • SmileBD
      • 300-600kbps
      • 250-450kbps
    Forgive my noobness. I can't find any intel i5 350m processor in Google. Its showing i3 350m and its a notebook processor. Pls correct me if I am wrong.
    Member IBNU's Avatar
    Dec 2014
    Did you find the solution ?
    amaro DH55PJ MB, team elite 2gb 1333MHz use korteci... chaycilam 8GB use korbo.
    kintu ajke twinmose 4gb 1333MHz mainstream series dilam ram payyee na.. r ager 2gb add korle beep beep sound korte thake ...
    8 GB kivabe use korbo...kon ram ? @shuvo121
      • 6 GB
      • 500 GB
      • Evga gtx 690
      • Microwlab 5:1
      • Windows 7
    shuvo121's Avatar
    Ota motherboard e problem cilo. Pore boro vai er motherboard change kora lagse @ Ibnu Iqbal Hasan
    • giant's Gadgets
      • MSI H77MA-G43
      • Intel Core i5 3470 @ 3.6ghz
      • Realtek ALC892
      • Delux K9020
      • Thermaltake SE 630W
      • Asus DRW-24B3ST (24x)
    giant's Avatar
    Feb 2012
    Khulna, Bangladesh
    Quote Originally Posted by Ibnu Iqbal Hasan View Post
    the problem is that..the mobo supports 8gb,thats okayy...but...4gb on each slots....
    Dec 2014
    but twinmose 4gb 1333 lagayci ...kintu ram pay nai ?
    Quote Originally Posted by shuvo121 View Post
    mother board model konta cilo please ? mother board change korte chay karon mobo+cpu change kora amar pokkhe r somvob nah..
    r ami 8gb ram use korte chayteci...please 1 tu help korenn na..
    Quote Originally Posted by giant View Post
    I think this is the problem. My motherboard, G43 also supports up to 16GB, but only in 4+4+4+4 condition. Even, the rams have to be 4GB dual sided, meaning made with 16 256MB chips on both sides, not 8 512 MB chips on only one side. So, keep using 4+4 GB RAM. don't try to use 1 8GB RAM.
      • 6 GB
      • 500 GB
      • Evga gtx 690
      • Microwlab 5:1
      • Windows 7
    shuvo121's Avatar
    Motherboard:Intel DH55PJ eta cilo motherboard er model. Vai pore 2nd hand ekta motherboard kinse asrock g41.Karon new kono brand er 1st generation er motherboard market e cilo na. New gula sob e Chinese brand.
  1. Strange problem in win 7
    By Speed in forum Technical Support
    Last Post: December 8th, 2014, 01:39
  2. strange problem need help
    By terrygr8_007 in forum Technical Support
    Last Post: January 12th, 2014, 16:04
  3. Strange problem
    By Cpt.Mactavish in forum Technical Support
    Last Post: January 20th, 2012, 20:46
  4. Strange problem!!!!!
    By shaikh_imtiaj in forum Technical Support
    Last Post: December 10th, 2010, 02:51
  5. Strange Pc Problem
    By D3FC0N in forum Technical Support
    Last Post: October 11th, 2010, 18:12
Page generated in 0.31115 seconds with 14 queries.
