Results 1 to 18 of 18
Thread: Need help with Online UPS selection
    Default Need help with Online UPS selection
    I have been contemplating to get an Online UPS for my current/future setup.
    Found 2 model so far
    1. Computer Source Asking for 42K for 2KV model (Prolink 2KVA PRO802S)
    2. Flora Limited Asking for 35K by Winner2K by voltranic power
    Now it seems both UPS is from the same OEM. The specs, outlook and software everything looks identical.
    If my doubts are true, Computersource is basically trying a sell something at a fat margin or their purchase price is high.
    please feel free to share your thoughts/experience/suggestions regarding the above.
    Regards.
    u want to use this Online UPS for ur PC?
    Quote Originally Posted by GLaDOS View Post
    PC+47" led TV+Router+Cordless phone+ speaker+12 cooling fans+ others
    Any 2kVA or 3kVA offline UPS is more then enough for ur setup. Don't waste ur cash on on-line UPS.
    Go for any Sine wave UPS,, APC will be best in term of quality but little overpriced.
    • Speed's Gadgets
      • Creative ZxR| Built In
      • ASUS DVD +/-RW
      • USPOWER 2000va Online UPS
      • Windows 10 Pro 64 bit
      • DHAKANET
      • 750
      • 650
    Speed's Avatar
    Khilgaon
    today's power sensitive psu are not compatible with most aftermarket or so called branded offline ups. apc's minimum 1kv still alone will cost more than 70k. so, his best option is an online ups.
    APC Smart UPS 1000VA from flora costs 50K whereas 2Kv Online UPs costs less than 45K + The delicious 0 sec transfer time.
    Another surplus advantage is due to 0 transfer time, the online UPS doesn't even need to face high inrush current of the connected load.
    If i were to buy a proper sized pure sine wave UPS I would require an UPS which can produce at least 775 watt or 1500VA
    A 1500VA from APC costs atleast 60000/= :/
    Amer friend ke kine dicilam ekta APC 750VA,, se rokom ekta UPS price 24k chilo tokhon.
    750W er cheye higher capacity APC er price asolai onek high
    My old Sendon 1000VA UPS is running fine with my PC. 700W er moto output dite pare may be (PC+Monitor+Router). But ekhon market out.
    BTW is there anyway to use two 750VA UPS as 1500VA in a single load? Just curious
    • Rawkill's Gadgets
      • Asrock Z77 Extreme 6
      • WD Blue 1TB x 2
      • Creative Sound Blaster ZX
      • Logitech F510 Rumblepad
      • Prolink 1000VA
      • Cooler Master HAF - X
      • 550-600 KB/s
      • 200-2500 KB/s
    Rawkill's Avatar
    Regards.
    Chom-one amare MAIRALAAAAAAA !!!!!!!!!
    Chom-one amare aro MAIRALAAAAA !!!!!!!!!
    Chances are it will work for sometime.
    Quoting directly from APC
    "APC does not recommend that you daisy-chain two or more UPSs together. Each unit should be plugged directly into a properly grounded wall outlet for optimum surge protection.
    We do not recommend daisy-chaining UPS systems for the following reasons:
    1. Daisy-chained UPSs do not provide any extra surge protection. A UPS is designed to remove any possibility of a surge reaching the output receptacles. In the event of a surge strong enough to damage equipment, the first UPS in the chain would sacrifice itself to protect the load. This would mean that power would be removed from the secondUPS in the chain, forcing the unit into battery operation.
    2. Whenever connecting a second UPS to another UPS, the chance of overloading the first one is greatly increased. The number of receptacles in a UPS is restricted by the power limitations of the UPS itself. Even if the number of receptacles was increased, the overall Watt capacity of the first UPS would remain unchanged. The capability of the second UPS would be inversely affected by that of the first unit. Therefore, the overall Watt capacity of the configuration is no greater than that of the first UPS in line.
    3. In most cases, daisy-chaining UPSs does not allow for extra runtime. If you are using a UPS that outputs a step-approximated sine wave when running on battery, as soon as the first UPS goes to battery operation, the second one will also do so because it will see the step-approximated sine wave as distorted or bad power. Both UPSs will discharge together and will not provide any extra runtime to the load."
    Any one have friends/colleagues @ computersource? or using their online UPS?
    • Speed's Gadgets
      • ASUS DVD +/-RW
      • DHAKANET
      • 750
      • 650
    Speed's Avatar
    Khilgaon
    so, u r finally getting robbed by computer source
    Finally got it! Prolink PRO901S with Extra external battery bank 12amp. Built in 9AMP. Total 21AMP. Still has the expansion space to add another 9 amp.
    Looks pretty small for a online ups.
    Price koto nilo? Warranty 3yrs or 1yrs?
    1 yr for battery n unit
ID:	34237Click image for larger version.
ID:	34238Click image for larger version.
    Lets hope that this tiny cheap Chinese charger will be able to charge up these twins.
    (12V Hamko Deep Cycle IPS/UPS Battery 75A x 2)
    The charging initially started at 10A and then after an hour gradually dropped to 4A.
    @redwan hasan is there any way to guesstimate the remaining time until both the batts r fully charged. Currently it shows 27V on MM and Charger shows 3.5A
    Would I be wrong if i say 70% charge is complete at the current state?
    @Shetu if u want longer backup time then external flooded lead acid battery gives the best bang for the buck.
    • KING offspring's Gadgets
      • H61
      • i3-2100
      • 8gb
      • 1.16tb
      • gtx 960 2gb
      • tt volos
      • ps3
      • TT 450w
      • prolin650va
      • windows 10
      • 256
      • 256
    Sep 2014
    bro how much did ur ups setup cost??
    Quote Originally Posted by KING offspring View Post
    18.5K for ups + 12500 for ext batt hamko hpd75+ ext charger 2200+2000 for high power relay+600 for high gauge cable= priceless shanti
  1. UPS selection (need to know the VA)
    By Rawkill in forum Others PC Hardware
    Last Post: October 20th, 2012, 19:40
  2. Need help on GPU selection.
    By EaGL1337 in forum GPU
    Last Post: December 26th, 2011, 17:01
  3. Wcg 2010 official game selection
    By Speed in forum World Cyber Games
    Last Post: December 22nd, 2009, 19:17
  4. GOTM selection - march'08
    By Noob™ in forum Goal of The Month
    Last Post: March 27th, 2008, 02:03
  5. Goal Of The Month Jury Selection Poll
    Last Post: March 18th, 2008, 03:32
Page generated in 0.29544 seconds with 15 queries.
