Thread: How am I supposed to clean my LED panel ?
    • Metal's Gadgets
      • GIGABYTE [ GA-EP43-UD3L ]
      • INTEL(R) Core(TM)2 Quad CPU Q9505 @ 2.83Ghz
      • APACER 4GB DDR2
      • SAMSUNG 750GB
      • NVDIA GeForce 9500 GT
      • Dell E178WFP
      • CREATIVE Sound Blaster 5:1
      • COSONIC CD-779MV
      • A4Tech KR-83 USB [Black]
      • A4Tech OP-620D
      • ASUS P-50GA
      • ASUS DRW 24B1ST
      • Windows 7 Ultimate
      • ISPROS Limited
    Metal's Avatar
    Feb 2012
    Chittagong
    Lightbulb How am I supposed to clean my LED panel ?
    Today I was reading online articles on how to clean a LED panel and I am totally lost in many of myths where people ended up with dead pixel, white spots on screen, scratch/smudge etc.
    Hence after buying my Sony W954A 47 inch for a month now I need to clean spots on screen. So need expert advice and opinion on which is the best method.
    Bellow are some available options I can see online.
    1. mild soap in a lukewarm water.then wipe using a soft cloth.
    2. Spray or liquid like iKlear then using a microfiber cloth.
    3. home invention vinegar+water [50/50]
    I am always seeing nightmare of chemical reaction so let's not destroy my LED panel.
    Through your suggestion/idea pls.
    Power is not only what you have but what the enemy thinks you have.
    • Rawkill's Gadgets
      • Asrock Z77 Extreme 6
      • WD Blue 1TB x 2
      • Creative Sound Blaster ZX
      • Logitech F510 Rumblepad
      • Prolink 1000VA
      • Cooler Master HAF - X
      • 550-600 KB/s
      • 200-2500 KB/s
    Rawkill's Avatar
    khali pani dia rub korle hoi, eto cleaner lage na. Use a soft cloth, dampen it and rub on the places woth spots and then rub the entire screen
    • Syeef's Gadgets
      • WD 1TB Blue Sata III
      • Samsung 22-inch LED 1080p
      • N/A
      • Creative SBS 2.1
      • Tt eSports Knucker
      • Logitech F310 Gamepad
      • Samsung DVD-RAM 24x Sata
      • 650VA
      • ~15 Mbps | 128 KB/s
      • ~5 Mbps | 32 KB/s
    Quote Originally Posted by Metal View Post
    ^ this.
    been doing this for years. was actually suggested to me by the instruction manual for both my LG and Samsung panels.
    first wipe the panel with microfiber cloth soaked in vinegar+water solution, clean any dirt. then soak the microfiber cloth in plain water and wipe the panel again to remove any vinegar.
  1. How do you clean your PC?
    By Nirzhar Uchiha in forum Technical Support
    Last Post: July 26th, 2014, 21:24
  2. How to clean backside?
    By VANGUARD in forum Technical Support
    Last Post: February 14th, 2014, 13:22
  3. Not getting the supposed speed in torrents (foreign)
    By gamefreak in forum Smile/BDCom
    Last Post: November 29th, 2013, 19:42
  4. Clean bg!
    By Overlord in forum Miscellaneous Topics
    Last Post: July 6th, 2013, 00:48
  5. Is Transcend Jetflash 350 Pendrive Supposed to be this slow
    By TheNutKicker in forum Technical Support
    Last Post: February 18th, 2013, 15:21
Page generated in 0.15525 seconds with 14 queries.
