Thread: Front panel USB header replacement
    Default Front panel USB header replacement
    Hi guys, new here, just registered.
    Having problem with front panel I/O port, the one that comes with 2 USB ports with headphone out & mic in. Although the audio headers work fine, but those 2 USB ports worn out after prolonged use. As we all know, these panel comes with casing but I'm wondering how to replace these in need such as mine. The last time workaround was to buy a (old) whole casing . This time I need to find something else. Have you guys seen anyone selling spare "front" header in Dhaka?
    I know some alternatives to this such as USB extension cable, HUB, back panel header. But still, I need my front panel USB ports. Any help for this poor man will be appreciated!
    Thanks
    Milwaukee
    If your front panel header looks like this Click image for larger version.
ID:	34028, you can try this as a last resort: Open the front panel of the casing, remove the header PCB containing the usb and audio jacks, de solder the USB ports from the pcb, replace and re solder them with good usb ports. I have found exact same USB ports like the ones generally used in these headers at an electronics shop in Khulna, I guess they can easily be found on other places too.
    But still, you would need to solder yourself or find a friend who can solder. I don't think any repair shop will take this kind of small task.
    • RMS's Gadgets
      • Gigabyte GA-X58A-UD3R
      • Intel Xeon X5670 @4.2 GHz Cooled by Corsair H60 Hydro Cooler
      • OCZ Gold (2+2+2) GB + Corsair Vengeance (4+4+4) GB
      • Intel 545s 512GB + WD Black 4TB + Toshiba (4+4+3+3 +3+2)TB + 2 x Seagate 2TB + 4 x Transcend 1TB ext
      • ASUS GTX 950 STRIX OC 2 GB
      • LG 42LB623T 42" 3D + 3 x Samsung B2230 21.5" + Optoma HD131XE FHD Projector
      • Yamaha RX-V1065, Creative X-Fi Titanium, Asus Xonar DG || Fiio E7 || X-Fi 5.1 Pro USB
      • 5x B&W VM1, Klipsch RW10 || HEADPHONES: Beyer DT990, Shure SRH440, Sennheiser HD 439,
      • Newmen e370 Illuminated Gaming Keyboard, A4Tech G6 Wireless Desktop
      • Mad Catz Cyborg R.A.T. 7 || Logitech G500 || A4Tech Bloody V3, A4tech G6-70D Wireless, A4tech MOP70D
      • Genius Trio Racer F1 Wheel, Genius MaxFire Grandias 12V Wireless Gamepad, BlackCat xbox360 Gamepad
      • Antec VP550P V2 NC
      • Samsung DVDRW, Sony DVDROM
      • AUDIO PLAYERS: Ipod Nano, SanDisk Sansa Clip+ || FLASH DRIVES: Transcend 128 GB, 16 GB, 2x 32 GB
      • APC 800 VA for CPU and Appolo 800 VA for others
      • 155
    RMS's Avatar
    Sep 2011
    Quote Originally Posted by limaj View Post
    Thanks
    These are found in the old computer market which is situated at the opposite side of multiplan center. Last time (1 years ago) I bought those for 30~50 taka. The shopkeepers might ask much more but you'll get it bellow 50 taka if you bargain.
    Bring your one when you get there, to maintain exact measurement as those front panel units vary in sizes.
    If you are unable to find the size that match your one or if you are handy with soldering iron, do what @aaz_swapnil suggested.
  1. USB 3.0 20 Pin 2 Ports Front Panel Floppy Disk Bay
    By optimus prime in forum Help - General Shopping
    Last Post: January 17th, 2014, 18:56
  2. Sale (New) Usb 3 front panel bay
    By MaDDy in forum Shop - Gadgets
    Last Post: May 16th, 2013, 23:06
  3. Sale (New) Anker Uspeed USB 3.0 Front Panel with 2 USB 3.0 Ports Hub
    Last Post: May 13th, 2013, 20:06
  4. Trouble with front panel audio output
    By arefinzz in forum Technical Support
    Last Post: July 11th, 2012, 11:00
  5. Front Panel USB 2.0 Port
    By zaman_177 in forum Others PC Hardware
    Last Post: December 26th, 2010, 09:25
Page generated in 0.16704 seconds with 15 queries.
