Results 1 to 15 of 15
Thread: Help... my monitor died?
    Default Help... my monitor died?
    Is this fixable?
    I was just browsing web when suddenly the screen started to distort and fade from center until became like this, white background with colored vertical lines. The lines move and change if the image in screen is supposed to be moving or changing. The screen stays like this even with VGA and DVI disconnected, so it is not a GPU issue.
    Actually, this happened twice before in past 3 years, usually got automatically fixed after a few minutes. So I guess the actual panel is OK and the problem is somewhere in the circuitry.
    Is there any shop wher LCD TVs are repaired? If there is, I think they might be able to fix it.
    Then I guess you all could start suggesting a good replacement ......... in around 12k-15k maybe?
    • RMS's Gadgets
      • Gigabyte GA-X58A-UD3R
      • Core i7 950 @4.2 GHz Cooled by Corsair H60 Hydro Cooler
      • OCZ Gold (2+2+2) GB + Corsair Vengeance (4+4+4) GB
      • Samsung 1.5 TB + Toshiba (3 +3+ 2) TB + 4 x Seagate 2 TB + Transcend 1TB ext + Adata 1.5TB ext
      • ASUS GTX 950 STRIX OC 2 GB
      • Samsung B2230 + Viewsonic VX2270S
      • Creative X-Fi Titanium, Asus Xonar DG || Fiio E7 USB DAC and Portable Amp || X-Fi 5.1 Pro USB
      • 5x Bowers and Wilkins VM1, Klipsch RW10 || HEADPHONES: Beyer DT990, Shure SRH440, Sennheiser HD 439,
      • Newmen e370 Illuminated Gaming Keyboard, A4Tech G6 Wireless Desktop
      • Mad Catz Cyborg R.A.T. 7 || Logitech G500 || A4Tech Bloody V3, A4tech G6-70D Wireless, A4tech MOP70D
      • Genius Trio Racer F1 Wheel, Genius MaxFire Grandias 12V Wireless Gamepad, BlackCat xbox360 Gamepad
      • Antec VP550P V2 NC
      • Samsung DVDRW, Sony DVDROM
      • AUDIO PLAYERS: Ipod Nano, SanDisk Sansa Clip+ || FLASH DRIVES: Transcend 128 GB, 16 GB, 2x 32 GB
      • APC 800 VA for CPU and Appolo 800 VA for others
    RMS's Avatar
    Sep 2011
    Quote Originally Posted by aaz_swapnil View Post
    Is this fixable?
    Seems like capacitor issue in power circuit. Open the back panel, look for pregnant capacitors and replace those.
    Quote Originally Posted by RMS View Post
    Already looked. All capacitors seems fresh, none bulged or blown. Was thinking of replacing all the capacitors, just to be sure. But first want to check in the electronics repair market if there is any shop expert in these matters.
      • GIGABYTE B75M-D3H rev1.1
      • A4Tech KRS-86
      • Thermaltake azureus
      • Antec VP450P
      • Samsung DVD RW+Asus CD RW
      • Win 8.1 pro x64
    @nonymous™'s Avatar
    Unknown
    it should be fixable. seems like the problem is either on any LDI chip or a color bus/ribbon on the pcb. since it occurs occasionally the lcd panel is likely to be alright. you may need to change the whole pcb if problem can't be detected.
    Things have gotten pretty serious. My dad gave me another monitor from his office as a temporary replacement, and from this evening this one has stopped working too. Won't even power on. Now I'm suspecting my UPS.
    Eid tai noshto koira dilo.
    This thread has goten old but I think I should share the latest development here.
    The monitor is now working fine again, after I've replaced all the capacitors on it's power supply board with fresh new ones. Either the capacitors fixed it or the long rest of 2 months, which one I'm not completely sure though.
    whats about the other monitor? ups problem?
    I've since discarded the UPS and not using it anymore. And the other monitor had power supply problem too. When I opened it up, I found 2v coming from it's power supply's 5v output line. Then when I was testing the board with multimeter while plugged in, I accidentally short-circuited a 300v DC line and fried the entire board . Now it's irreparable, unless someone can give me a replacement power supply board for HP LE1851w monitor.
    How bad is the damage? U have shorted out the dc 300v? That means right after the ac to dc conversion? It should be easily fixable.
    Well, few of the diodes are shorted, and a mosfet. Few resistors shows burning signs. Also, the point where my meter probe slipped and short circuted was very near the PWM generator chip, so I think that is burned too. I don't think the pain of replacing so much SMT components worth it. If the whole replacement board could be found it would be different matter.
    Ohhh, burnt resistor.. I guess the values are not written on the pcb. If you know the output voltage of the smps you can use another similar product.
    Values are no problem. I've got the monitor's service manual with detailed circuit diagram for every board. Just SMT desoldering and resoldering and finding SMT resistors with same value will be pain. The DC output of the SMPS is normal 5v, but the board also includes the 600+volt inverter board for the CCFL Lights and dimming circuitry for those lights.
    Really i v see n them using standard values.
  1. Renowned Hacker Barneby Jack Died
    By Trave160 in forum News
    Last Post: July 27th, 2013, 10:32
  2. UPS died, need a new one. Suggestions?
    By Rakin7 in forum Help - General Shopping
    Last Post: September 14th, 2012, 23:17
  3. Replies: 1
    Last Post: July 25th, 2012, 12:59
  4. Gpu died!!!!!!
    By showdown_king in forum GPU
    Last Post: September 7th, 2010, 23:19
  5. Replies: 2
    Last Post: July 31st, 2010, 17:15
Page generated in 0.27183 seconds with 15 queries.
