Results 1 to 12 of 12
Thread: UPS, Casing, Speaker buying help
    • terrygr8_007's Gadgets
      • ASrock z77 extreme4
      • Transcend 2x4GB 1600BUS
      • Seagate Barracuda st 2TB
      • Sapphire HD7850 OC edition
      • built-in
      • CM GX650
      • Windows 7 Ultimate 64bit
    Default UPS, Casing, Speaker buying help
    as the title goes...i want to buy
    1. UPS (2-5 min back up needed)
    2. Speakers with sub/woofer (need clear sound specially voice, don't need the best there is but should be durable and of medium to good quality stuff)
    3. casing (i'm thinking of CM scout 2/CM 690 II advanced)
    budget ~8k for ups and speakers and another 8k for casing
    please suggest me some good deals in the above mentioned price range
    thanks
    hello? bump
      • built-in
      • CM GX650
    anything on the speakers??
    Quote Originally Posted by terrygr8_007 View Post
    would have suggested altec lansing vs2621 but dats too hard to find nowadays,, logitech z313,, creative T3130 dekte paren.
      • built-in
      • CM GX650
    thanks bro
    thanks
    hello? bump
    any setup that has separate speaker for mid frequency, high frequency and low frequency . something like below picture (Right one) http://www.highfidelity.pl/foto_test.../tannoy/02.jpg
      • built-in
      • CM GX650
    http://www.computersourcebd.com/logi...z443_1855.html
    http://www.ryanscomputers.com/Altec-Lancin-2846
    http://www.ryanscomputers.com/Creative-SBS-3674
    out of the above 03 which one will be better???
    sorry i didnt understand...can you provide an easier explanation??
    Get Microlab Solo 7 C if u want clear voice and tighter bass. costs around 13k to 15K
    Go for the first one. Coz to me, 2y warranty matters.
      • built-in
      • CM GX650
    get me big discount with that bro
    okay...
    • Billybuoy's Gadgets
      • ASUS micro ATX H97M-E
      • Intel Core i5-4590 Haswell Quad-Core 3.3GHz LGA 1150
      • 8GB (2 x 4GB) DDR3
      • Primary: Crucial MX100 512GB SSD, Sec: Toshiba 2TB, Sec: HGST 1 TB
      • Asus Strix GTX 1070 OC Edition
      • Dell S2440L 24 inch LED backlit VA Panel
      • Fiio E10K USB DAC/AMP
      • SP: Logitech Z623 2.1, HP: Beyerdynamic Custom One Pro, Audio Technica M40x, Phillips SHP9500
      • G.SKILL RIPJAWS KM780R MX Cherry Brown (Red LED)
      • Thermaltake Toughpower 650W Gold (Semi Modular)
      • Asus DVD RW/R
      • ADATA UV128 16 GB
      • Powervault 1200VA
      • Windows 8.1 Pro x64 bit
      • Windows Exp Index: 7.6, Glary Utilities: 16 Sec Boot Time
      • Childhood desire for a Gaming Rig Finally came tru! All parts from earned money, still building
      • Bracnet
      • 2 MBPS
      • 1 MBps
    Billybuoy's Avatar
    Jul 2014
    thanks
    hello? bump
    for casing you can go with similar specs but 1000 taka less for haf 912 advance @7500
    it has a very good all star global user rating for being best at good price!
    http://binarylogic.com.bd/cm-storm-h...id-tower-case/
    review: http://www.newegg.com/Product/Produc...82E16811119233
  1. suggestion on buying a speaker
    By saurav in forum Help - PC Buying
    Last Post: May 8th, 2013, 01:49
  2. 5.1 speaker buying help.
    By Bold Nsd in forum Help - PC Buying
    Last Post: April 25th, 2013, 19:43
  3. Help regarding buying speaker
    By mustaky2k in forum Help - General Shopping
    Last Post: March 9th, 2013, 16:35
  4. help regarding buying pc speaker
    Last Post: September 10th, 2012, 01:12
  5. Need suggestion for buying Speaker
    By Dee in forum Help - General Shopping
    Last Post: January 13th, 2011, 13:37
Page generated in 0.22926 seconds with 14 queries.
