Results 1 to 10 of 10
Thread: Memory Card Problem
    • yahyasharif's Gadgets
      • gigabyte 990 fxa -ud5
      • AMD fx - 8120
      • ADATA 1600 Mhz 8 x 2 =16 GB
      • Wesstern Digital cavier green 2 TB Maxtor 250 GB
      • 7970 vapor x 3gb
      • Samsung S19D300NY
      • Cosonic
      • A4 tech bluetooth keyboard
      • A4 tech bluetooth mouse
      • Cooler Master v750s vision 600 watt psu
      • Samsung external optical drive
      • a4 tech webcam;usb speaker
      • Windows 7 Ultimate
      • ZX online bd
      • 192-200
      • 100-200
    Apr 2014
    Unhappy Memory Card Problem
    I bought a twinmos 8 gb memory card maybe 10 months ago. I lost my warranty paper.now i am facing some problems with this. At first i was using it in my tablet created a ext2 partition to save my apps in memory card. Then without formatting it i inserted it in my motorola mb300 and after formatting it in motorola i was unable to use it in the phone. Then i tried my tablet ;after formatting it was showing damaged SD card. Now when i plugged it into my pc it is showing it's capacity is only 1 GB :O and when i am trying to format it, it's showing that windows is unable to format.Tried Partition magic and tried to do something from Device Manager nothing worked. Is there any solution ?
    • Astro Boy's Gadgets
      • Gigabyte Sniper M5
      • Intel Core i5 4570 @ 3.20GHz
      • Corsair Vengeance 1600MHz 4x2= 8GB
      • HGST 1TB Internal SATA 3.0 + 1 TB 3.0 External
      • MSI R9 270X Twin Frozer Gaming - 4GB EDITION
      • ASUS MX239H
      • A4Tech H100
      • A4Tech Lighting KD 800 Keyboard
      • A4Tech USB Mouse
      • Cooler Master V 750W 80 PLUS GOLD
      • Asus 24x DL DVD R/W
      • BanglalionWimax
      • 1000
    Astro Boy's Avatar
    Sep 2013
    Maybe Your Card Got Write Protected.
    And I am afraid that you can't Recovery it.
    If U Lucky Then Try That http://www.wikihow.com/Disable-Write-Protection
    Maybe you can get your memory back
      • AMD fx - 8120
      • 7970 vapor x 3gb
      • Samsung S19D300NY
      • Cosonic
      • ZX online bd
      • 192-200
      • 100-200
    Apr 2014
    Quote Originally Posted by HyBrId_GaMeR View Post
    Doesn't work anything else? tried sd formatter,hp usb storage tool,command prompt etc
      • ASUS MX239H
      • A4Tech H100
      • A4Tech USB Mouse
      • BanglalionWimax
      • 1000
    Astro Boy's Avatar
    Sep 2013
    Then Nothing Else to do.
    try deleting the partition and create a new ntfs partition
    Use Diskpart to delete partition and format.
    or use linux/Gparted instead.
      • AMD fx - 8120
      • 7970 vapor x 3gb
      • Samsung S19D300NY
      • Cosonic
      • ZX online bd
      • 192-200
      • 100-200
    Apr 2014
    tried both of them
    Then try dustbin.
    try this
      • AMD fx - 8120
      • 7970 vapor x 3gb
      • Samsung S19D300NY
      • Cosonic
      • ZX online bd
      • 192-200
      • 100-200
    Apr 2014
    try this
    This one failed too. 100% complete show er por hang kore
  1. Want to Buy Want to Buy SD Memory Card and USB Internet Modem
    By Mr. Orange in forum Shop - Gadgets
    Last Post: October 25th, 2013, 17:17
  2. Windows 7 dusnt recognize my memory card...
    By Source code in forum Miscellaneous Topics
    Last Post: October 30th, 2011, 19:22
  3. Price of 16gb microSD Memory Card
    By gogeta in forum Help - General Shopping
    Last Post: September 15th, 2011, 23:34
  4. Sale (New) 1GB MicroSD Memory Card
    By Dee in forum Shop - Gadgets
    Last Post: December 31st, 2010, 12:22
  5. Closed 8GB Micro SDHC Memory Card
    By dying4004 in forum Shop - Gadgets
    Last Post: September 18th, 2009, 02:33
Page generated in 0.21024 seconds with 14 queries.
