Thread: Help neded for my friend
    • shaikh_imtiaj's Gadgets
      • Asus P6X58D-E| Gigabyte G31-ES2C
      • Core i7 930 @ 3.88GHZ cooled by True Spirit| E5200 @ 3.15Ghz
      • Patriot 6GB DDR3 1600| Transcend 3GB DDR2
      • Samsung F3 500GB|Samsung 160GB +Samsung 1TB F1
      • Gigabyte GTX660 OC| Intel GMA3000
      • Asus MS228H LED
      • Creative x-fi Titanium | intregreted realtek x-fi modded
      • Creative GigaworksT20 +Inspire2.1|A4tech HS-800 Gaming Headphone
      • Newmen Backlit Gaming KB E370Logitech NewTouch 100
      • A4tech X7 747H | Logitech M90| A4tech x7
      • XFX Dual analog | Xbox360 wired Controller
      • XFX 650W Core edition|Thermaltake Litepower 400W
      • Benq DVD/RW, Benq DVD rom
      • Canon Lide25| WD 500GB USB3| 16GB+8GB Transcend | 2GB PNY
      • Rahim Afrooz 600va
      • Windows 7 x64|Windows xp sp2+Windows 7 build7600
      • A killer PC...Grrrrrr
      • Link3 | Banglalion
      • 60-70 | 100
      • 60-70 | 8
    shaikh_imtiaj's Avatar
    Jan 2009
    Greenroad,Dhaka
    Default Help neded for my friend
    My friend is facing some weird problems.
    First one, many times his pc doesn't start at one click. If he connects the power socket to main plug then remove it from there and plug into ups then it starts! When it is connected to main plug after removing from ups it doesn't start.
    Second one, he is having sluttering in fifa 14. Previously it was working fine but recently he facing this problem. He checked the gpu from ucc and it is totally ok. He is using latest driver too.
    Can anyone give me a reliable computer servicing center where the pc can be thoroughly checked?
    His pc components-
    Intel Core i5 2500
    CM hyper 212 plus
    Gigabyte h61
    4GB ram
    Sapphire 7770 Ghz edition
    Thermaltake Smart 530W
    1000va ups
    For secondary use: E2160 OC @2.2Ghz| Gigabyte 945GCMX| 1.5GB DDR2| Thermaltake 400w| Intel GMA 950
    • Muhammad Zunaid's Gadgets
      • ASRock H55M-LE
      • G Skill Ripjaws [4GBx2]=8GB
      • Samsung SyncMaster T220
      • Inbuilt Realtek Codec
      • Altec Lansing VS4121
      • Tt esports KNUCKER
      • Genius standard mouse
      • Canon Lide110 Scanner
      • RA 1000VA + Powertree 650VA
      • want to upgrade soon!
      • LINK3
    Muhammad Zunaid's Avatar
    when the computer is connected to the ups, does the ups go to battery mode[like it does when there is no electricity]. does the ups make any noise like when it's on battery power. i am asking to understand whether the mains supply[wall socket] is supplying enough voltage.
    try to connect the whole computer system in another room so you are using different wall socket. or try to use a multi-plug and use the socket used for air conditioners [if you have them at ur place].
    try stress testing the gpu with occt or sth. just for a little while and observe the temps and check for error[occt displays error automatically if there is any]
      • Asus MS228H LED
      • 60-70 | 100
      • 60-70 | 8
    Jan 2009
    Greenroad,Dhaka
    Okay will do that. But another of my friend having the same gpu issue! Is that problem is happening only in amd cards? I always used Nvidia so don't know about it.
    Quote Originally Posted by shaikh_imtiaj View Post
    The PC is probably full of STD, have it checked by the doctor ASAP.
    Jokes apart, It could be a case of bad PSU, or a bad Mobo, or even bad memory modules(s) so you will have to rule out the possibilities one by one.
  1. A Gaming Pc for best friend.
    By Ahnaf_i7X in forum Help - PC Buying
    Last Post: November 11th, 2012, 20:43
  2. friend wants help for CPU within 50k
    By gamefreak in forum Help - PC Buying
    Last Post: September 10th, 2012, 01:54
  3. Help a friend!!
    By OoAIDoO in forum Miscellaneous Topics
    Last Post: August 7th, 2012, 14:43
  4. PC Buying Help (for my friend)
    By Aziz37 in forum Help - PC Buying
    Last Post: April 3rd, 2011, 17:43
Page generated in 0.16828 seconds with 14 queries.
