Thread: Facing problem to Convert VGA to DVI-D...PLZ need urgent help
    Jun 2013
    Narayanganj, Bangladesh
    Default Facing problem to Convert VGA to DVI-D...PLZ need urgent help
    I am wishing to buy R7 260X currently i have HD6570....
    but my monitor has only VGA port my HD 6570 have DVI D Duel link......i have bought a new converter to test but it is not working....my monitor go into power saving mood......
    my monitor model-Dell 19 Monitor - E1914H
    Will my monitor support DVI D and Redeon r7 260X
    • MusharratC's Gadgets
      • MSI 990FXA G65
      • Asus VX229
      • Prachin JVC UX T1
      • Gigabyte Pulse 650W
      • Dead Powertree 1250VA
      • An ALMOST decent rig!
    MusharratC's Avatar
    Feb 2013
    u just need a DVI-to-VGA converter. Sapphire cards generally come with them. make sure the converter u bought is the right kind and test it before u buy it.
    • giant's Gadgets
      • MSI H77MA-G43
      • Intel Core i5 3470 @ 3.6ghz
      • Realtek ALC892
      • Delux K9020
      • Thermaltake SE 630W
      • Asus DRW-24B3ST (24x)
    giant's Avatar
    Feb 2012
    Khulna, Bangladesh
    i suggest you take your monitor with you, when you buy the 260x.....
    i think you tried the converter with your 6570's DVI-D port.....the port might not support DVI-D to VGA.......
    i'm using xfx 4650's DVI-D to VGA converter with my Sapphire HD 5850.....converters usually dont pass away that easily.....
  1. Facing a weird problem with my GTX 670
    By caspianprince in forum GPU
    Last Post: April 30th, 2014, 15:05
  2. Anyone facing problem with steam???
    By codename5302 in forum General PC Gaming
    Last Post: June 14th, 2013, 21:17
  3. To those Who are Facing problem inCrysis 3!!PC ONLY!!
    By ATypicalAssasin in forum Technical Support
    Last Post: March 5th, 2013, 22:57
  4. Smile: anyone facing browsing problem?
    By AmareX in forum Smile/BDCom
    Last Post: February 5th, 2010, 14:39
  5. Smile: anyone facing browsing problem?
    By AmareX in forum Internet
Page generated in 0.25470 seconds with 14 queries.
