Thread: Help with GPU for mostly 3d/Rendering
    • Obscura's Gadgets
      • GIGABYTE B75M-D3H
      • INTEL i5 - 3470, 3.2 GHZ
      • 8 GB DDR3
      • Samsung 500 GB HDD
      • MSI Nvidia GTX 660 OC TF III
      • ASUS VS228-H 1920 x 1080 LED
      • Realtek HD Audio
      • Sennheiser HD 201 & Altec Lansing VS2621
      • A4 tech
      • Old badass A4 Tech
      • Hands
      • TT 530 W Smart
      • Windows 7 64 bit
      • Bdcom
    Obscura's Avatar
    Mar 2013
    Default Help with GPU for mostly 3d/Rendering
    One of my friends was asking for a GPU that would perform well in 3dsMax, adobe after effects, Google sketchup, C4D, premiere, illustrator, photoshop, a few video pixel tracking software, etc etc. His budget is almost 40-50k.
    I was suggesting him GTX 770, though I said lower ones would probably perform just as well for that kind of work. Any suggestions guys? Open for Radeon alternatives as well.
    IT would be wise for you to look at 3d animation /modeler forums to see what gfx they are using. 40 to 50K cards are good enough to render but this also depends on the user ..how demanding his job or profession is as a modeler . Some would say 100K gfx ,some would say 30K is good enough..it all depends on the user ..who is he working for ..and what he actually creates with those software. Adobe after effects illustrator dont need powerful cards..but 3dmax maya esp if he does big projects then def 30K plus card...getting the new models as well the working period..say you want the project to be rendered in pc for 12 hours..then think about the cooling system ram...you get the idea.
    • Ehsas's Gadgets
      • MSI Z97-G45
      • Intel Core i7-4790K 4.0GHz
      • G.Skill Ripjaws X Series 16GB (2 x 8GB) DDR3
      • Seagate Barracuda 3TB/Samsung Evo Pro (1TB SSD)
      • EVGA Superclocked ACX GTX 980 dual SLI
      • LG 34UM95
      • Asus Xonar
      • Razer Kraken Pro (green)
      • Rosewill STRIKER RK-6000
      • perrix mx(old one) not sure the model
      • xbox 360's controller
      • Snow Silent Seasonic 750w
      • Windows 7 64 bit
      • Mazeda BD
      • 38096
      • 9096
    Ehsas's Avatar
    Jul 2015
    Quote Originally Posted by Obscura View Post
    Tell him to get AMD's firepro or Nvidia's Quadro and not a consumer gpu then. So i would suggest getting either the AMD FirePro W5000. nvidia's alternative(at that price range) is the k2000 and it isn't good enough in that case. so get the W5000.
  1. PC for rendering and small 3D work within 50k
    By Obscura in forum Help - PC Buying
    Last Post: May 28th, 2013, 20:46
  2. Apartment Exterior Rendering
    By ArchQuad in forum Programming
    Last Post: August 18th, 2011, 18:07
  3. A new tryout - ENVIRONMENTAL RENDERING
    Last Post: June 26th, 2011, 02:28
  4. C4d rendering tutorial
    By DesiMyth in forum Programming
    Last Post: September 1st, 2010, 19:26
  5. Rendering or Extraction?
    By CvP in forum Programming
    Last Post: September 4th, 2008, 05:40
Page generated in 0.15904 seconds with 14 queries.
