Results 1 to 20 of 34
Thread: WEIRD Problem!!! Need Help
    • nafis087's Gadgets
      • Gigabyte H81 S2PV
      • Intel Core i5 4460 3.2 GHz
      • 8 GB Adata DDR3 1600MHz X 2
      • Toshiba 2TB + Toshiba 2TB + Samsung 320GB + Transcend 320GB (portable)
      • MSI GTX 760 TFIV GE 2GB DDR5 OC
      • ASUS VX229H (1920x1080)
      • Microlab TMN-1 2:1, A4Tech HS-19 & A4Tech HS-30
      • A4 tech bloody b120
      • Logitech F510
      • CM V650w
      • ASUS 24x DVD-RW
      • Transcend 16GB USB 3.0
      • XpressBD
      • 5 mbps
      • 1 mbps
    nafis087's Avatar
    Default WEIRD Problem!!! Need Help
    I recently updated my GPU & added a 4GB RAM with my old 4GB. For first 2-3 weeks the system ran smoothly but from last week i am facing a WEIRD problem. Sometimes my monitor is shutting down but my CPU remains ON (all the led fans & power button led keeps ON) but i can't use the system untill i restart it manually.
    The most irritating thing is i can't figure out the reason!!! Because the first time it happened i was only browsing Youtube. After that it happened while gaming, watching TV (with TV card of course) and once it happened when i was doing nothing (it was on standby because i was downloading a torrent).
    The other frustrating thing is when it happens it occurs for 2-3 times a day but then again for 3-4 days the system runs without any problem then GOD knows why it happens again........
    So help me out guys, what do you think the problem is?????? It is killing me
    • shoryuken-x's Gadgets
      • msi
      • 8gb ( to power black x)
      • 1/2 tb
      • Radeon HD 7950
      • 21.5 lcd
      • lagano hoy ni
      • Genius Gx Sw-1250
      • Delux t15s
      • venge gese
      • Tt toughpower XT 675
      • few here nd there
      • 600va
      • jana nei
      • silent htpc
      • antbd
      • 60+
      • Do
    shoryuken-x's Avatar
    ^ram failure nau hote pare .........
    dual channel ? ........
    gpu prob o hote pare ...........which game ur playing exactly ...... try with different games and stresses
    run stress tests...... ram jodi hoye thake make sure ur not overvolting nd running same bus speed for starters .
    .anyways . here is something for u ... hope u enjoy it
    http://banglagamer.com/showthread.php?97233-TRy-it-out
    oh and good morning
      • Gigabyte H81 S2PV
      • Logitech F510
      • CM V650w
      • ASUS 24x DVD-RW
      • XpressBD
      • 5 mbps
      • 1 mbps
    nafis087's Avatar
    Yes dual channel and running at 667 bus.
    Jekono game jemon watch dogs er moto demanding games a abar don bradman cricket er moto low demanding game.
    Kintu game na khelleo to problem hoy. Browsing korle ba stand by thakleo problem hoy. RAM r GPU kinar age ei problem jiboneo hoy nai.
    i think its a gpu problem... monitor your gpu temp when gaming carefully... and stress test...
    • GalibTheGamer's Gadgets
      • MSI X370 Gaming Pro Carbon
      • Ryzen R5 1600 @4.0GHz
      • Gksill Ripjawas V DDR4 16GB 3000MHz
      • Samsung 850 EVO 2350GB
      • MSI GTX 1080 Gaming X
      • Philips 223V 21.5 inch monitor
      • Logitech K270
      • Bloody A9 (core 3 cracked :P )
      • Xbox One controller (Wireless)
      • EVGA G2 850W
      • A4-Tech PKS-732G Anti-glare WebCam
      • Windows 10 Pro 64-Bit
      • KC Network (3 Mbps)
    GalibTheGamer's Avatar
    May 2013
    Well, remove your new 4GB RAM stick but keep the new gpu and see whether the problem of your monitor losing display still remains.
    If the problem no longer occurs, then the problem might either be the 4GB RAM stick or the RAM slot of the motherboard in which you set this RAM stick.
    If the problem remains, it might be your gpu. But you should also check the display cables, I mean whether they work properly and whether they are properly attached to the monitor and gpu. Try with different display cables.
    You can also try with a different psu if possible. Who knows, it might also be the culprit.
      • msi
      • 1/2 tb
      • Radeon HD 7950
      • 21.5 lcd
      • lagano hoy ni
      • Genius Gx Sw-1250
      • Delux t15s
      • venge gese
      • few here nd there
      • 600va
      • jana nei
      • silent htpc
      • antbd
      • 60+
      • Do
    Quote Originally Posted by nafis087 View Post
    bus speed ........duitar same ase kina check koren
    new ram ta khule felen
    run stress tests......nd test for 4-5days everyday use -
      • Gigabyte H81 S2PV
      • Logitech F510
      • CM V650w
      • ASUS 24x DVD-RW
      • XpressBD
      • 5 mbps
      • 1 mbps
    nafis087's Avatar
    After 6 days running without any problems it happened again last night and again today while playing don bradman cricket. Another thing is when the problem occurs a loud noise comes from the speaker and the cooling fans seems to spin more forcefully.
    wat... are u monitoring ur cpu and gpu temperature and clock?
      • Gigabyte H81 S2PV
      • Logitech F510
      • CM V650w
      • ASUS 24x DVD-RW
      • XpressBD
      • 5 mbps
      • 1 mbps
    nafis087's Avatar
    Yes i am. Nothing seems unusual to me. GPU temp goes as high as 70-78 degrees at 70% fan speed when playing demanding games like WatchDogs
    and in don bradman cricket in remains under 50 degrees at "auto" fan speed
    if possible try to update bios (be careful)
    but galib the gamer maybe right... may be the ram is culprit... try what he said
    also whats ur gpu driver? 337.88 ?
    pull out one of the rams and check if the problem bumps again or not
      • Gigabyte H81 S2PV
      • Logitech F510
      • CM V650w
      • ASUS 24x DVD-RW
      • XpressBD
      • 5 mbps
      • 1 mbps
    nafis087's Avatar
    As per many of yours suggestions I ejected my new ram yesterday but the problem occurred again just now.
    Any thoughts .....
    I have the same problem as you, and for a long time, but with a complete different set of hardware. I have a Sapphire Radeon HD 4830 card and Core2 gen cpu+mobo. In my case it happens only once or twice in a month so I decided to ignore it.
    The thing that happens is, my GPU shuts down with the onboard LEDs on the GPU indicating core overheat shutdown (solid red on LED2), GPU fan starts to spin at full speed and any audio that was playing starts looping/stuttering. But, as far as I have monitored, the temps are never high when the problem occurs. Also, sometimes it happens when browsing facebook, and sometimes it doesn't happen even after 6-8 hours gaming sessions. Also, it occurs more when the GPU is set at stock, and less when overclocked. I've ran stress tests, taking my GPU temp up to 90c from the idle ~45c without any of this happening.
    Once I thought it was power supply issue, as I have a lower rated PSU than recommended, but in that case the LED indicator should be core power failure (solid red on LED1 instead of LED2). In the end, I believe it is some sort of bios issue.
      • Gigabyte H81 S2PV
      • Logitech F510
      • CM V650w
      • ASUS 24x DVD-RW
      • XpressBD
      • 5 mbps
      • 1 mbps
    nafis087's Avatar
    Quote Originally Posted by aaz_swapnil View Post
    So i am not alone.
    Did you fixed it by any chance? or are you still using it??
    So i am not alone.
    Nope. I just keep my card OCed a bit now. Last time this happened was about 2 months ago. The occurences are not frequent enough for proper troubleshooting.
      • Gigabyte H81 S2PV
      • Logitech F510
      • CM V650w
      • ASUS 24x DVD-RW
      • XpressBD
      • 5 mbps
      • 1 mbps
    nafis087's Avatar
    Okay the problem was happening again and again yesterday so I pulled the gpu out of the casing and started using the computer with internal gpu but now another kind of problem is occurring! !!
    Now my pc is restarting without any reason. The whole cpu is shutting down with all the lights then after a second or two it is restarting by itself!!!! WHAT IS HAPPENING?? Is it my PSU???
    • Shawon191's Gadgets
      • Gigabyte H-61
      • Intel Core i5 3570s 3.1 GHz
      • 4 GB DDR3 1600
      • Samsung 850 Evo 256 GB + WD 1 TB
      • GTX 660
      • Asus VX229H
      • Microlab M223
      • SteelSeries Rival
      • Logitech F310
      • Thermaltake TRS 550W
      • Aamra Technologies
      • 5 mbps
      • 5 mbps
    Shawon191's Avatar
    May 2014
    It might be monitor problem, my old monitor died after showing this problem for a few days
    built in eo jokhon problem hoy tahole to monitor problem mone hosse
      • Gigabyte H81 S2PV
      • Logitech F510
      • CM V650w
      • ASUS 24x DVD-RW
      • XpressBD
      • 5 mbps
      • 1 mbps
    nafis087's Avatar
    I have tried powering just the cpu without monitor and other things but now the pc is not even starting. The lights are powering on and off.....
      • Gigabyte H81 S2PV
      • Logitech F510
      • CM V650w
      • ASUS 24x DVD-RW
      • XpressBD
      • 5 mbps
      • 1 mbps
    nafis087's Avatar
    Amar PSU ta gese totally. Ekhon ekta generic backup PSU diye kono mote GPU, DVD-RW, 1TB HDD r 3xLED fan baad diye PC chalaitesi.
    Ekhon ki korbo PSU repair korbo naki new kinbo. Guys please give me some suggestions........
    @VANGUARD i need your help again Bro
  1. Weird Problem = IDM
    By Uchiha Obito in forum Technical Support
    Last Post: November 27th, 2010, 18:20
  2. a weird problem!
    By Mohaan in forum Technical Support
    Last Post: June 19th, 2009, 13:49
  3. Weird Problem????????
    By Walking Death in forum Technical Support
    Last Post: May 9th, 2009, 05:50
  4. Weird problem
    Last Post: April 15th, 2009, 21:54
  5. Weird Problem
    Last Post: April 5th, 2009, 03:45
Page generated in 0.29084 seconds with 14 queries.
