Results 1 to 6 of 6
Thread: Aerocool Touch 1000 Fan Controller & Coolermaster Megaflow 200Mm Blue Led Fan
    Default Aerocool Touch 1000 Fan Controller & Coolermaster Megaflow 200Mm Blue Led Fan
    Connectors:
    4 x 3-pin connectors + 4 x heat sensors.
    Max wattage per fan channel: 6W.
    Product link: http://www.aerocool.us/peripheral/touch1000.htm
    Is in good condition, comes with the spare bundled accessories.
    Price: 1,500/- BDT (Fixed)
    Specification:
    Dimension (W x H x D) 200 x 200 x 30 mm
    Speed (R.P.M.) 700 RPM
    Air Flow (CFM) 110 CFM
    Air pressure (mmH2O) 0.595 mm H2O
    Noise 19 dBA
    Bearing Type Sleeve Bearing
    Fan Life Expectancy 30,000 Hours
    Rated Voltage 12 VDC
    Current (Ampere) 0.16 A (Max 0.28 A)
    Power Consumption 3.36 W
    Weight 266 g
    Connector 3 Pin
    LED Color Blue
    Product link: http://www.coolermaster.com/cooling/...led-silent-fan
    Price: 700/- BDT (Fixed)
    Mentioning @Rawkill and @arefinzz who were originally interested in these items.
    Update: The Fan Controller has been booked by @R.AMD and will be delivered to him tomorrow, if everything goes according to plan.
       1
    • Rawkill's Gadgets
      • Asrock Z77 Extreme 6
      • WD Blue 1TB x 2
      • Creative Sound Blaster ZX
      • Logitech F510 Rumblepad
      • Prolink 1000VA
      • Cooler Master HAF - X
      • 550-600 KB/s
      • 200-2500 KB/s
    Rawkill's Avatar
    Teka nai akhon. :'(
       1
    And the fan controller is booked too I will be handing it over to him tomorrow, if all goes well. Pray for me that I make kazillions, so that I can gift you one
       2
    • Rawkill's Gadgets
      • WD Blue 1TB x 2
      • Prolink 1000VA
      • 550-600 KB/s
      • 200-2500 KB/s
    Rawkill's Avatar
    :'( Oh SUCH KINDNESSS !!!! THANK YOU MASTER !!!!
       1
    -_-
    Anyways, the Aerocool fan controller has been delivered to @R.AMD and the cooler master 200mm can be picked up by arefinzz from Elephant Road.
       0
    Both products are sold.
       0
  1. Sale (Used) Coolermaster 200mm fan (Haf X's Stock fan)
    Last Post: December 27th, 2012, 23:45
  2. Sale (Used) NZXT Sentry-2 5.25" Touch Screen Fan Controller
    Last Post: October 7th, 2012, 02:37
  3. Sale (Used) Coolermaster 200MM Mega flow fan
    Last Post: February 28th, 2012, 14:02
  4. Sale (New) NZXT Sentry-2 Touch Screen fan controller
    By iceman™ in forum Shop - Gadgets
    Last Post: January 14th, 2012, 19:05
Page generated in 0.17846 seconds with 14 queries.
