Results 1 to 20 of 20
Thread: question about cpu fan speed and cooler
    • yahyasharif's Gadgets
      • gigabyte 990 fxa -ud5
      • AMD fx - 8120
      • ADATA 1600 Mhz 8 x 2 =16 GB
      • Wesstern Digital cavier green 2 TB Maxtor 250 GB
      • 7970 vapor x 3gb
      • Samsung S19D300NY
      • Cosonic
      • A4 tech bluetooth keyboard
      • A4 tech bluetooth mouse
      • Cooler Master v750s vision 600 watt psu
      • Samsung external optical drive
      • a4 tech webcam;usb speaker
      • Windows 7 Ultimate
      • ZX online bd
      • 192-200
      • 100-200
    Apr 2014
    Default question about cpu fan speed and cooler
    amar vision 600 watt power supply te motamuti sobkichu run kortese(game ekhono khelchi na). Fan speed jekhane >6000 rpm thakto motamuti 4500-5000 rpm thakche. Ar amar procesoor er temperature idle situation e 43 degree Celsius ache. So guys amar ki cooler master v8 CPU Cooler ki adew lagano dorkar?
    And fan speed >4000 rpm ki problem korte pare ?
    will accept any kind of suggestion
    • MusharratC's Gadgets
      • MSI 990FXA G65
      • Asus VX229
      • Prachin JVC UX T1
      • Gigabyte Pulse 650W
      • Dead Powertree 1250VA
      • An ALMOST decent rig!
    MusharratC's Avatar
    Feb 2013
    put it under stress testing and see where the temp goes? what software are u using to monitor the temps?
    OT: don't know how good your PSU is. may be u should change the PSU before u do any stress testing and gaming.
    • shoryuken-x's Gadgets
      • msi
      • 8gb ( to power black x)
      • 1/2 tb
      • Radeon HD 7950
      • 21.5 lcd
      • lagano hoy ni
      • Genius Gx Sw-1250
      • Delux t15s
      • venge gese
      • Tt toughpower XT 675
      • few here nd there
      • 600va
      • jana nei
      • silent htpc
      • antbd
      • 60+
      • Do
    shoryuken-x's Avatar
    Quote Originally Posted by yahyasharif View Post
    processor konta ?
    psu er parle pic dien ...
    nd idle temp means nothing ...stress koren prime 95, heavyload
    under 60 is preferable but upto 70 thakle cooler neyar dorkar nei
    V8 baad den ........normal oc korte chaile cm hyper 212x nite paren
    tt er nic series ta ei yr e ber korse otau valo hobe but ektu price beshi hote pare
      • AMD fx - 8120
      • 7970 vapor x 3gb
      • Samsung S19D300NY
      • Cosonic
      • ZX online bd
      • 192-200
      • 100-200
    Apr 2014
    processor amd fx 8120, apatoto biose check korsi..
    cooler master v8 cpu cooler ta ache but nije laganor chesta korchi na. jodi psu kini tokhon dokaner lokder diye lagabo
    Bhai ei gula dokander der diye na laganoi bhalo. Era theila kono mote lagai dilei bache, eder emon ekta vab.
    • Astro Boy's Gadgets
      • Gigabyte Sniper M5
      • Intel Core i5 4570 @ 3.20GHz
      • Corsair Vengeance 1600MHz 4x2= 8GB
      • HGST 1TB Internal SATA 3.0 + 1 TB 3.0 External
      • MSI R9 270X Twin Frozer Gaming - 4GB EDITION
      • ASUS MX239H
      • A4Tech H100
      • A4Tech Lighting KD 800 Keyboard
      • A4Tech USB Mouse
      • Cooler Master V 750W 80 PLUS GOLD
      • Asus 24x DL DVD R/W
      • BanglalionWimax
      • 1000
    Astro Boy's Avatar
    Sep 2013
    That's Ture..
    • GalibTheGamer's Gadgets
      • MSI X370 Gaming Pro Carbon
      • Ryzen R5 1600 @4.0GHz
      • Gksill Ripjawas V DDR4 16GB 3000MHz
      • Samsung 850 EVO 2350GB
      • MSI GTX 1080 Gaming X
      • Philips 223V 21.5 inch monitor
      • Logitech K270
      • Bloody A9 (core 3 cracked :P )
      • Xbox One controller (Wireless)
      • EVGA G2 850W
      • A4-Tech PKS-732G Anti-glare WebCam
      • Windows 10 Pro 64-Bit
      • KC Network (3 Mbps)
    GalibTheGamer's Avatar
    May 2013
    Well, I went to Onix Computers Ltd to install my Deep Cool Ice Blade Pro cooler. Instead of installing properly, their so-called engineers messed up everything. I came at home and found that the cpu fans were not properly attached to the heatsink, the air-flow was in the wrong direction, way too much thermal paste used, etc. Then, I had to install everything and decided that either I will either buy components and install them myself no matter how tough it will be, or, I simply won't buy them.
    By the way, oi dokandar gular bhab er bapare ar bollam na.
      • msi
      • 1/2 tb
      • Radeon HD 7950
      • 21.5 lcd
      • lagano hoy ni
      • Genius Gx Sw-1250
      • Delux t15s
      • venge gese
      • few here nd there
      • 600va
      • jana nei
      • silent htpc
      • antbd
      • 60+
      • Do
    oh buldozer .....
    v8 asei jokhn rekhe diesen ki krote .lagie felen ............youtube dekhen..............
    fx8120 er jonne aftermarket cooler recommended .......... use ur cooler asap
    • RMS's Gadgets
      • Gigabyte GA-X58A-UD3R
      • Core i7 950 @4.2 GHz Cooled by Corsair H60 Hydro Cooler
      • OCZ Gold (2+2+2) GB + Corsair Vengeance (4+4+4) GB
      • Samsung 1.5 TB + Toshiba (3 +3+ 2) TB + 4 x Seagate 2 TB + Transcend 1TB ext + Adata 1.5TB ext
      • ASUS GTX 950 STRIX OC 2 GB
      • Samsung B2230 + Viewsonic VX2270S
      • Creative X-Fi Titanium, Asus Xonar DG || Fiio E7 USB DAC and Portable Amp || X-Fi 5.1 Pro USB
      • 5x Bowers and Wilkins VM1, Klipsch RW10 || HEADPHONES: Beyer DT990, Shure SRH440, Sennheiser HD 439,
      • Newmen e370 Illuminated Gaming Keyboard, A4Tech G6 Wireless Desktop
      • Mad Catz Cyborg R.A.T. 7 || Logitech G500 || A4Tech Bloody V3, A4tech G6-70D Wireless, A4tech MOP70D
      • Genius Trio Racer F1 Wheel, Genius MaxFire Grandias 12V Wireless Gamepad, BlackCat xbox360 Gamepad
      • Antec VP550P V2 NC
      • Samsung DVDRW, Sony DVDROM
      • AUDIO PLAYERS: Ipod Nano, SanDisk Sansa Clip+ || FLASH DRIVES: Transcend 128 GB, 16 GB, 2x 32 GB
      • APC 800 VA for CPU and Appolo 800 VA for others
    RMS's Avatar
    Sep 2011
    Quote Originally Posted by GalibTheGamer View Post
    What is the current price of that cooler?
    If it is possible, please post a link or image. Thanks.
      • AMD fx - 8120
      • 7970 vapor x 3gb
      • Samsung S19D300NY
      • Cosonic
      • ZX online bd
      • 192-200
      • 100-200
    Apr 2014
      • MSI 990FXA G65
      • Asus VX229
      • Prachin JVC UX T1
    MusharratC's Avatar
    Feb 2013
    how come u have a v8 AND a 15 inch monitor? :o
    u should buy a monitor asap to do your gpu justice.
      • AMD fx - 8120
      • 7970 vapor x 3gb
      • Samsung S19D300NY
      • Cosonic
      • ZX online bd
      • 192-200
      • 100-200
    Apr 2014
    Quote Originally Posted by MusharratC View Post
    I know V8 is too old but bought it from my friend and i will change my monitor after getting my tuition fees. it will at least take 2 months though
      • Logitech K270
      • EVGA G2 850W
    May 2013
    Well, I bought the Deep Cool Ice Blade Pro cooler for Tk 3600 from Onix Computers Ltd. Their website still shows the same price. But not sure about it and also whether it's in stock even. Anyways, here's the link - http://www.onixcomputers.com/index.p...etail?Itemid=0
    And about the image, I will try to upload some photos of my cooler as soon as possible. By the way, it's quite a looker
    I've seen it's reviews, and they said it's disappointing.
      • AMD fx - 8120
      • 7970 vapor x 3gb
      • Samsung S19D300NY
      • Cosonic
      • ZX online bd
      • 192-200
      • 100-200
    Apr 2014
    Onix der website sei jemon chilo temon e ase.ar eikhane maybe normal dam theke 2-3K extra charge kore
      • msi
      • 1/2 tb
      • Radeon HD 7950
      • 21.5 lcd
      • lagano hoy ni
      • Genius Gx Sw-1250
      • Delux t15s
      • venge gese
      • few here nd there
      • 600va
      • jana nei
      • silent htpc
      • antbd
      • 60+
      • Do
    V8 kharap noi ....... apni na lagie keno chalasssen etai to dhukse na mathai .......asap cooler lagan .......
    btw u knw the price of v8 right ?
    ^^^ Right on .............. Efat bhai .....
    bd te apatoto ........................
    to anyone who is looking for cooler .......bang for buck is still cm hyper 212X/evo
    tt er newly released Nic series tau besh valo ........
    nd then there is old trusty frio ...................
    dont buy deepcools ...........
      • AMD fx - 8120
      • 7970 vapor x 3gb
      • Samsung S19D300NY
      • Cosonic
      • ZX online bd
      • 192-200
      • 100-200
    Apr 2014
    Quote Originally Posted by genocide_cutter View Post
    ami 3.5k diye kinsi friend er kas theke actual price ta jani na .lagacchi na karon nij hate ulta palta kisu jodi kore feli ei voye tai
      • Logitech K270
      • EVGA G2 850W
    May 2013
    Can you give some links please?
    It wasn't meant for your V8, it was meant for the Deep Cool Ice Pro
    The review I saw is old, I am trying to look for it.
    Edit: I apologize. This isn't the exact Deep Cool Product that was reviewed.
      • Logitech K270
      • EVGA G2 850W
    May 2013
    Well, almost all the reviews I have read online are positive for the Deep Cool Ice Blade Pro cooler. May be it's a bit expensive then cm hyper 212X/evo, but it provides almost similar performance and is very quiet . And as I have said, it's looks extremely good especially the black scheme of the cooler along with that blue LED fan, so, you can consider the extra price a premium . But I accept the fact that the cm hyper 212X/evo provides better bang for the buck.
    And "
    genocide_cutter" mentioned about Frio, well, it cools really well but it is extremely noisy. And I don't want my PC to sound like a jet. Besides that, I didn't have that much money either at the time of purchase. And one more thing, you mentioned that "don't buy deepcools". Well, may be some deepcool coolers are not up to the mark but the Ice Blade Pro cooler is a serious contender and provides good bang for the buck. So, don't write off an entire company before knowing about all their products.
    By the way, what's the current price of Cooler Master Hyper 212 Evo cooler? And where is it available?
  1. Replies: 2
    Last Post: February 17th, 2014, 08:06
  2. Want to Buy 2nd hand Cooler master 1155 CPU Cooler
    By fahimspider in forum Shop - Gadgets
    Last Post: January 18th, 2013, 18:45
  3. Stock cooler or Chinese Haofeng cooler for i5-2310
    By Camouflage in forum Others PC Hardware
    Last Post: August 21st, 2012, 13:37
  4. Sale (Used) Cooler Master Hyper N520 CPU Cooler
    By VIPERS in forum Shop - Gadgets
    Last Post: February 26th, 2012, 05:46
  5. Replies: 42
    Last Post: February 21st, 2010, 15:51
Page generated in 0.30427 seconds with 14 queries.
