Thread: Need Help with Earthing/Grounding My Computer
    • iSzAlchemist's Gadgets
      • Intel DP55WB
      • Intel i5 750 @ 2.67Ghz
      • 2GB DDR3 1333Mhz
      • 500GB SATA
      • Sapphire 5850
      • Dhar kore chalachchi!
      • VIA (Onboard)
      • Audio Technica ATH M50
      • A4 Tech Bloody V3
      • Thermaltake 550W
      • Samsung DVDW
      • Windos XP 32-bit s/p 3
      • 512Kbps Night Doubler
      • 1.5MB Local
    May 2010
    Vhuter Goli, Dhaka
    Default Need Help with Earthing/Grounding My Computer
    Hi there
    As the title suggests, i want to earth/ground my computer. Can u guys give me some pointers. I have next to zero idea about how to go about doing it. Any help will be appreciated.
    • rabbyx7's Gadgets
      • Gigabyte GA-B75M-D3H rev1.1
      • Intel Core i3 3220 3.3ghz
      • A-Data XPG 1600MHz DDR3 4x 2GB = 8GB
      • Western Digital 500GB 7200rpm 3gb/s; Western Digital Cavier Blue 1TB; Transcend 500GB USB 3.0
      • SAPPHIRE HD 7870 2GB GDDR5 DUAL-X OC GHZ EDITION
      • Sony Bravia 32inch FULL HD LED; Asus VX229h 21.5 FULL HD IPS
      • REALTEK HIGH DEFINITION
      • Thermeltek Esports Shock Spin Blazing Red
      • MERCURY 8X00
      • SKYTECH
      • Xbox One Wireless Controller
      • Cooler Master V550 550W 80+ Gold
      • ASUS 18X DVD ROM
      • Banglalion WIMAX
      • APOLLO
      • Windows 7 64bit Ultimate
      • 5.9
      • HAPPY :)
      • Banglalion WIMAX
      • 256
      • 24KBPS
    rabbyx7's Avatar
    Dec 2011
    Quote Originally Posted by iSzAlchemist View Post
    Hi there
    Maybe others can give better advise but here's what our electrician did:
    Took a single electric wire and connected one end of the wire internally to the negative point of the wall socket, connected the other end of the wire to the body of the casing.
    Hello.
    Here's how I workaround with this issue successfully EVERY TIME. Use a wire (insulated/uninsulated both will do) to connect with casing. If insulated, tear some of it's insulation at both end. You can connect the wire with a screw of the casing but better practice is to connect with power cable's earthing pin (marked with E with grounding sign, top pin). Please be VERY careful with attaching the wire with correct pin, since connecting it with Live/Line pin (marked with L) may cause serious ELECTROCUTION. Find someone to help if necessary. Then connect the other end of the wire with a metallic stuff like grille of window, construction rod etc that is earthed through the building. That being said, don't connect it with door knob, nail or metallic stuff lying on floor or table like steel scales or steel legged bed. It's found out that floor (let it be tiled or ceramic) isn't conductive. I suggest you to use your room's window/veranda grille. Generally it's coated with paint so you need to scratch a little portion of it where you would connect the wire by wrapping around this portion. Now you're done. Feel free to touch the casing and/or the window/veranda grill since both are electrically grounded (i.e. neutral). But first use a electric tester (the one that is used by electricians) to check your casing's body.
    সংবিধিবদ্ধ সতর্কীকরণঃ if you don't feel comfortable with electricity, or even don't get this whole idea about what's happening here as mentioned, DO NOT try this by yourself, find someone else to do this for you. I and/or this web forum is not responsible for any consequence resulting by this instruction. It is yours and only yours responsibility to prevent hazards/shocks to yourself.
    @limaj jodi wire diye casing ar floor er connection kore dei tahole hobe?
  1. List of Computer Hardware Retailers at BCS Computer City
    By minitt in forum Help - PC Buying
    Last Post: May 4th, 2013, 11:27
  2. How to transfer a computer game to another computer?
    By MalcolmJoan in forum Recruitments
    Last Post: January 12th, 2013, 11:10
  3. Help Regarding My Old Computer...
    By $hakil619 in forum Technical Support
    Last Post: June 29th, 2012, 23:38
  4. Help Regarding My Old Computer...
    By $hakil619 in forum Feedback
    Last Post: June 29th, 2012, 22:50
  5. Sale (Used) Computer with everything
    By shahriar in forum Shop - Gadgets
    Last Post: June 25th, 2012, 17:34
Page generated in 0.17986 seconds with 14 queries.
