Thread: Power supply
    • yahyasharif's Gadgets
      • gigabyte 990 fxa -ud5
      • AMD fx - 8120
      • ADATA 1600 Mhz 8 x 2 =16 GB
      • Wesstern Digital cavier green 2 TB Maxtor 250 GB
      • 7970 vapor x 3gb
      • Samsung S19D300NY
      • Cosonic
      • A4 tech bluetooth keyboard
      • A4 tech bluetooth mouse
      • Cooler Master v750s vision 600 watt psu
      • Samsung external optical drive
      • a4 tech webcam;usb speaker
      • Windows 7 Ultimate
      • ZX online bd
      • 192-200
      • 100-200
    Apr 2014
    Default Power supply
    Is vision 600 watt power supply good enough to run 7970 vaporx , amd fx 8120, cooler master v8 cpu cooler, 16gb 1600 MHz Ram, 3 asing fan altogether?
    If not then anybody willing to sell a psu within the range of 6K ?
    I know the PSU isn't renowned but could you please give us the specs like the ratings and stuff? It's hard to tell with such a vague description of it.
      • AMD fx - 8120
      • 7970 vapor x 3gb
      • Samsung S19D300NY
      • Cosonic
      • ZX online bd
      • 192-200
      • 100-200
    Apr 2014
    native cable: 20+4 pin motherboard connector *1 ,4+4 pin cpu+12v connector *1
    Modular cable : (pci-e 6 pin,pci-e 6+2 pin)*1,SATA x 3 *2,(peripheral x 3,FDD x 1)*2
    Type:Intel Form Factor ATX12v V2.3
    Active pfc
    i/p voltage : 90-264 V
    i/p current : 10-3A @ 90- 240 Ac voltage
    i/p frequency : 47-63 HZ
    Fan :135 mm fan
    power good signal : 100-500 ms
    hold up time > 1ms
    efficiency >80% typically
    MTBF > 100000 hours
    protection OVP/OCP/OPP/SCP/OTP
    OPERATION TEMP : 0- 40 degree celcius
    safety : Nemko/CE/GOST/C-tick/TUV
    • rabbyx7's Gadgets
      • Gigabyte GA-B75M-D3H rev1.1
      • Intel Core i3 3220 3.3ghz
      • A-Data XPG 1600MHz DDR3 4x 2GB = 8GB
      • Western Digital 500GB 7200rpm 3gb/s; Western Digital Cavier Blue 1TB; Transcend 500GB USB 3.0
      • SAPPHIRE HD 7870 2GB GDDR5 DUAL-X OC GHZ EDITION
      • Sony Bravia 32inch FULL HD LED; Asus VX229h 21.5 FULL HD IPS
      • REALTEK HIGH DEFINITION
      • Thermeltek Esports Shock Spin Blazing Red
      • MERCURY 8X00
      • SKYTECH
      • Xbox One Wireless Controller
      • Cooler Master V550 550W 80+ Gold
      • ASUS 18X DVD ROM
      • Banglalion WIMAX
      • APOLLO
      • Windows 7 64bit Ultimate
      • 5.9
      • HAPPY :)
      • Banglalion WIMAX
      • 256
      • 24KBPS
    rabbyx7's Avatar
    Dec 2011
    you need to post what's the amp in the +12v rail ...
      • AMD fx - 8120
      • 7970 vapor x 3gb
      • Samsung S19D300NY
      • Cosonic
      • ZX online bd
      • 192-200
      • 100-200
    Apr 2014
    +3.3 -> 24 Ampere
    + 5 -> 24 A
    +12V -> 20A
    +12V -> 20A
    -12V -> 0.5A
    +5Vsb -> 2.5 A
    I'm assuming there are 2 +12V rails, and you have about 34A in that 12V rail in total. It's total output should be in the 500 to 550W range. Not a good choice for the components you have chosen.
    I seriously dont think like that. My assumption its about 25-28A max.
      • AMD fx - 8120
      • 7970 vapor x 3gb
      • Samsung S19D300NY
      • Cosonic
      • ZX online bd
      • 192-200
      • 100-200
    Apr 2014
    so what psu should i choose to run them perfectly?? :/
    To both @Overlord and @VANGUARD keep your personal discussion away from public threads.
    @ALL keep your posts related to the thread title. I won't repeat this again!
  1. Power Supply help
    By abirtj in forum Others PC Hardware
    Last Post: October 23rd, 2013, 21:36
  2. Sale (Used) Tansnet Casing with 430watt Thermaltek Lite power Power Supply
  3. Replies: 21
  4. Power supply
    By outragedhuman in forum Others PC Hardware
    Last Post: May 28th, 2010, 00:23
Page generated in 0.20768 seconds with 14 queries.
