Results 1 to 10 of 10
Thread: need help about PS2 dvd..
    • HAWKai's Gadgets
      • Intel DG 35 EC
      • Core 2 Duo E7200
      • Kingston 2 GB DDR2 800
      • Samsubg 250 GB SATA
      • xfx 7200 gs
      • SyncMaster 793 DF
      • Microlab 2:1
      • Win 7
      • Ordinery 4 d time being..
      • GP
      • 26
    HAWKai's Avatar
    N.gonj
    Unhappy need help about PS2 dvd..
    i've got some heavily scratched PS2 DVDs which gets frozen, displays only the start page and some don't even load on my console. so i thought why not try copy the contents in my HDD and then write a new DVD for my own? and so i did. but now the console says: 'insert a PS2 type DVD'.. for writing i used a Verbatim DVD- R disk which of course is a blue disk and Nero smart writer on safe mode.
    plz share any solution/ suggestion that u have. ty.
    • AmareX's Gadgets
      • 1000 GB Samsung
      • Realtec 8 channel digital
      • A4tech GameMaster
      • XFX XGear
      • Transcend 4 GB Pendrive
      • Sendon Extreme 1000 VA
      • Windows 7 Ultimate x64
      • I am satisfied :)
      • GP
      • 30
      • 30
    AmareX's Avatar
    Between α and Ω.
    Default Re: need help about PS2 dvd..
    How did u copied them on ur HDD? U need to image them.
    • HAWKai's Gadgets
      • Intel DG 35 EC
      • Core 2 Duo E7200
      • xfx 7200 gs
      • SyncMaster 793 DF
      • Microlab 2:1
      • Win 7
      • GP
      • 26
    HAWKai's Avatar
    N.gonj
    Quote Originally Posted by AmareX View Post
    i copied like every other dvd. Image them, u mean like .iso file? should i use virtual drive to make an image?
    • AmareX's Gadgets
      • 1000 GB Samsung
      • A4tech GameMaster
      • XFX XGear
      • I am satisfied :)
      • GP
      • 30
      • 30
    AmareX's Avatar
    Between α and Ω.
    Yup. image them into iso or mdf ...
    • HAWKai's Gadgets
      • Intel DG 35 EC
      • Core 2 Duo E7200
      • xfx 7200 gs
      • SyncMaster 793 DF
      • Microlab 2:1
      • Win 7
      • GP
      • 26
    HAWKai's Avatar
    N.gonj
    got it. gonna give it a try.
    • HAWKai's Gadgets
      • Intel DG 35 EC
      • Core 2 Duo E7200
      • xfx 7200 gs
      • SyncMaster 793 DF
      • Microlab 2:1
      • Win 7
      • GP
      • 26
    HAWKai's Avatar
    N.gonj
    .iso/ .mdf is not working.. AmareX have u done it before? i tried with Daemon Tools lite.
    • AmareX's Gadgets
      • 1000 GB Samsung
      • A4tech GameMaster
      • XFX XGear
      • I am satisfied :)
      • GP
      • 30
      • 30
    AmareX's Avatar
    Between α and Ω.
    No I didn't, but it should work.. try with alcohol 120 enabling all emulation.
    I'm not exaclt sure if it'll work. It might though, it didn't when I tried doing the same thing for a 360 game. Normally creating the ISO and burning didn't work as the DVD drive was unable to read the security sectors of the DVD. I had to flash custom firmware to the DVD Drive so that it can read the full thing.
    I'm not sure if its the same for PS2 dvd's as well, but making the ISO directly probably is the way.
    • HAWKai's Gadgets
      • Intel DG 35 EC
      • Core 2 Duo E7200
      • xfx 7200 gs
      • SyncMaster 793 DF
      • Microlab 2:1
      • Win 7
      • GP
      • 26
    HAWKai's Avatar
    N.gonj
    i tried ISO directly from the DVD though. Gonna give it a last try with alcohol 120.
    Does your PS2 have a Mod chip?
    If your PlayStation does not have a modchip, then Copying the games wont work, as the PlayStation unit will reject copied games.
    Try out those Copied games on a modded PS2, and if it works on that, then it will not work on your PS2 without a modchip.
Page generated in 0.22175 seconds with 13 queries.
