Results 1 to 16 of 16
Thread: Half Life 2 (ep2) installation problem. HELP
    • SnakeEye's Gadgets
      • MSI G41 [G41M4-L]
      • Pentium DC e5400 @ stock
      • Apacer 2gb DDR2 800MHz
      • Samsung F3 [500gb]
      • g41/ integrated
      • Fujitsu 19inch LCD
      • Realtek/ integreted
      • Microlab 2.1
      • Perfect Standard keyboard
      • Perfect optical Mouse
      • Perfect / Int.
      • Samsung WriteMaster
      • Prolink 650VA
      • Windows SE7EN 32bit
      • N/A
      • GP edge
      • Avg. 10 kbps
      • N/A
    SnakeEye's Avatar
    Mar 2010
    Default Half Life 2 (ep2) installation problem. HELP
    Half life 2 ep2 install korar somoy ei msg dekhache. "Unable to create folder 'NPSWF32\".
    Next msg "RipForGames.bat not found"
    What to do?
    note: game ta heavily compressed kora ar orginal installation na.
      • MSI G41 [G41M4-L]
      • g41/ integrated
      • Microlab 2.1
      • Perfect / Int.
      • Prolink 650VA
      • N/A
      • GP edge
      • Avg. 10 kbps
      • N/A
    SnakeEye's Avatar
    Mar 2010
    Default Re: Half Life 2 (ep2) installation problem. HELP
    snap shots
    Attached Images Attached Images
    • Rumen's Gadgets
      • Gigabyte GA-EP45-UD3RL
      • Intel Core 2 Quad Q9400 2.93 ghz(OC)
      • 3 GB 1333 mhz DDR3
      • Samsung 320 gb HDD
      • Xfx 5850 1 gb DDR5 BLACK edition
      • Samsung 2243 1920x1080 HD LCD monitor
      • built in Realtek
      • Cosonic CD-721MV
      • xbox 360 controller
      • Coolermaster 600 watt ati xfire certified(italy)
      • ASUS 16x DVD Rom
      • 2 and 16 GB Pendrive
      • Name onek boro, lekhte parbona
      • Windows 7 nd xp
      • 7.1 in Windows 7 index(sometimes 7.2)
      • 2009-2013 porjonto valo vabe game khelte parlei hoy.
      • SMILE
      • 30-35 kBps normal and 200kBps-7MBps from local torrents.
      • 30-40 kBps normal and 150-500 kBps from local torrents
      • 9
    Rumen's Avatar
    Azimpur
    Vai amar time-eo eki error disilo. Onek try koreo kono lav hoy nai. Pore half life 2 orange box (2 dvd) kinsilam. Then install korte parsi.
    Anywhere Anytime Anytask
    Nothing but Excellence
    • Albert SX65's Gadgets
      • A4 Tech KBS-8 Multimedia
      • A4 Tech 2X Office MOP-70D
      • Asus DRW-2014L1T
      • Transcend JetFlash V30(2gb)
      • Prolink 600V/A
      • 5.9 in win7
      • Quite Satisfied :-)
      • GrameenPhone - P2 Unlimited
      • 25KBps +
      • 15KBps +
    Albert SX65's Avatar
    Feb 2009
    Left Side Of Ur Brain.
    same problem i face .buy orange box DVD.
      • MSI G41 [G41M4-L]
      • g41/ integrated
      • Microlab 2.1
      • Perfect / Int.
      • Prolink 650VA
      • N/A
      • GP edge
      • Avg. 10 kbps
      • N/A
    SnakeEye's Avatar
    Mar 2010
    Hmm. tahole eita thik korar poth nai?
      • Asus DRW-2014L1T
      • Prolink 600V/A
      • 5.9 in win7
      • 25KBps +
      • 15KBps +
    Feb 2009
    Nope coz game dvd te file mising
    Yah, there's a way. Badhon installed it in his PC, and he couldn't run it. He asked for my help.
    What I did is [can't exactly remember] - gone to his installation directory, gone to 'half-life 2 episode two' folder (can't remember the folder name exactly). Made shortcut of the hl2.exe file.
    then gone to the properties > target. edited the target to -
    "his installation directory\half-life 2 episode two\hl2.exe" -steam -game ep2
    and it worked, he played for 3 hours. his copy was it next 1dvd.
      • MSI G41 [G41M4-L]
      • g41/ integrated
      • Microlab 2.1
      • Perfect / Int.
      • Prolink 650VA
      • N/A
      • GP edge
      • Avg. 10 kbps
      • N/A
    SnakeEye's Avatar
    Mar 2010
    Quote Originally Posted by Rion a.k.a. রিয়ন View Post
    At last. Extracted them manually. Organized them. Full three hours. Did as you said. And worked! Rep added.
    One prob, no sound.
    Hmm... looks like there maybe some problem with extracting the sound files. :S
    • Rumen's Gadgets
      • built in Realtek
      • Cosonic CD-721MV
      • ASUS 16x DVD Rom
      • Windows 7 nd xp
      • SMILE
      • 9
    Rumen's Avatar
    Azimpur
    Orange box kinlei hoi.
      • MSI G41 [G41M4-L]
      • g41/ integrated
      • Microlab 2.1
      • Perfect / Int.
      • Prolink 650VA
      • N/A
      • GP edge
      • Avg. 10 kbps
      • N/A
    SnakeEye's Avatar
    Mar 2010
    Quote Originally Posted by Rumen View Post
    Next chance pailei kinbo . Coz, net e search kore dekhlam onekei ei prob face korche. Ar audio file gulor extension change kore *.wav e nite hobe. Ami er majhe nai.
    Man, my IT NEXT's 1 DVD copy worked, so why u guys are saying about orange box again and again ? :S
      • MSI G41 [G41M4-L]
      • g41/ integrated
      • Microlab 2.1
      • Perfect / Int.
      • Prolink 650VA
      • N/A
      • GP edge
      • Avg. 10 kbps
      • N/A
    SnakeEye's Avatar
    Mar 2010
    well, its a prob with os. Today i headed back to xp and the game installed and everything ok.
      • Asus DRW-2014L1T
      • Prolink 600V/A
      • 5.9 in win7
      • 25KBps +
      • 15KBps +
    Feb 2009
    Great .happy gaming with HL2
    I tried in both Win XP SP2 32-bit & Win 7 Ultimate 64-bit. No problem occured.
    Asole, Windows 7 e ei problem ta hoy. Windows XP te kono problem hoy na (jodio extract hoite onek onek time lage). Ami last time amar ak friend er XP te install kore tarpor copy kore niye khelsilam. Tarporeo ei DVD te file missing. Onek texture file missing, tai game er majhe onek jinishpotro plastic er moto dakhay.
    Orange box kothay pabo? Koto dam porbe keo bolte paren?
  1. Half Life 3
    By SenSeiFAR in forum FPS
    Last Post: May 27th, 2009, 12:26
  2. Half Life
    By freelance in forum FPS
    Last Post: May 26th, 2009, 20:38
  3. E3 2009 : Crysis 2 , Half-Life EP3 and Max Payne 3 ?
    By pollob.codename13 in forum Gaming Topics
    Last Post: May 19th, 2009, 23:30
  4. Replies: 28
    Last Post: March 28th, 2009, 13:07
  5. Half Life 2: Episode 3
    By pollob.codename13 in forum Upcoming PC Titles
    Last Post: October 15th, 2008, 23:01
Page generated in 0.25989 seconds with 15 queries.
