Results 1 to 20 of 33
Thread: Where can I get a dust blower for cleaning PC?
    • radeef's Gadgets
      • Gigabyte H67MA-USB3-B3
      • Thermaltake Smart 650W
      • Asus DVD-RW
      • Luminous 1200VA Solo
      • Windows 7 Ultra 64-bit
      • PC Mark 7 - 4558
      • Qubee 1Mbps
      • 100 - 125 Kbps
      • Depends :|
    radeef's Avatar
    Default Where can I get a dust blower for cleaning PC?
    Anyone knows where I might be able to find one in IDB???
    • SadIkMahdI's Gadgets
      • Gigabyte B85M-D3H
      • Intel Core i5 4590 @ 3.30 GHz
      • 4x4GB G.SKILL Ripjaws Series 240-Pin DDR3 SDRAM 1600 Bus Desktop Memory
      • Western Digital WD10EZEX 1 TB | SanDisk 2.5" 128GB SATA III Internal Solid State Drive
      • EVGA GeForce GTX 750 Ti FTW Edition with ACX Cooling
      • Samsung SB19B300B 18.5 LED
      • Built in Realtech HD
      • Altec Lansing VS2621 2:1 Channel Speakers
      • Newmen E370 Illuminated Keyboard
      • Bloody V3
      • Original Microsoft Xbox360 Controller for Windows (Wired Black)
      • Thermaltake Litepower 500W
      • Samsung S-ATA TrueDirect Super WriteMaster
      • SanDisk Ultra USB 3.0 Flash Drive 32 GB
      • Windows 7 Ultimate 64 Bit
      • 5.3 @ Windows 7 Benchmark
      • long way 2 go..
      • B.Net
      • 2.5 Mbps
    SadIkMahdI's Avatar
    Quote Originally Posted by radeef View Post
    which kind of quality you want? i bought one from multiplan centre around 2 years ago i guess, it costed around 500/=, it still works and it does pretty decent job and btw it looks like this
Name:	Electric-Hand-Operated-font-b-Blower-b-font-for-Cleaning-computer-Electric-font-b-blower-b.jpg
    • neorage's Gadgets
      • Gigabyte GA-P55M-UD2
      • Intel Core i7 860 @ 2.93Ghz
      • Corsair Vengeance 2x4GB DDR3 1600MHz (9-9-9-24)
      • Samsung 830 128GB SSD (Boot Drive) & Samsung F3 1TB
      • ECS GTX560 1GB
      • View Sonic VA703m 17" LCD
      • Realtek ALC888B
      • Havit HV-H611d
      • A4Tech Bloody V3
      • Thermaltake TR2 550W || Antec One S3
      • Asus DRW-24B1ST
      • Corsair Flash Voyager 16GB USB 3.0
      • Prolink 650VA
      • Windows 7 x64 SP1
      • IS Pros
      • 1.25 Mbps
      • 512 kbps
    neorage's Avatar
    check nowabpur....you'll get it there at a competitive price.....
    • radeef's Gadgets
      • Asus DVD-RW
      • PC Mark 7 - 4558
      • Qubee 1Mbps
      • 100 - 125 Kbps
      • Depends :|
    radeef's Avatar
    Quote Originally Posted by SadIkMahdI View Post
    Yup that will do, or even better if I can get a vacuum cleaner
    Quote Originally Posted by neorage View Post
    Is that a shop name in IDB?
    • neorage's Gadgets
      • ECS GTX560 1GB
      • Realtek ALC888B
      • Havit HV-H611d
      • A4Tech Bloody V3
      • Asus DRW-24B1ST
      • Prolink 650VA
      • Windows 7 x64 SP1
      • IS Pros
      • 1.25 Mbps
      • 512 kbps
    neorage's Avatar
    lol you don't know....nowabpur road near gulistan/bongshal .....check from google maps for direction.....
    at nowabpur road you'll get many electronic goods shops (importer for goods such as switches, wires, power tools, motors,etc)....i bought my blower from there at abt 400tk. (over 4 yrs back).....you'll get blowers of various capacities/specs over there....
    • radeef's Gadgets
      • Asus DVD-RW
      • PC Mark 7 - 4558
      • Qubee 1Mbps
      • 100 - 125 Kbps
      • Depends :|
    radeef's Avatar
    I asked because I was specifically looking for a shop in IDB. But thanks for the info
    • RMS's Gadgets
      • Gigabyte GA-X58A-UD3R
      • Core i7 950 @4.2 GHz Cooled by Corsair H60 Hydro Cooler
      • OCZ Gold (2+2+2) GB + Corsair Vengeance (4+4+4) GB
      • Samsung 1.5 TB + Toshiba (3 +3+ 2) TB + 4 x Seagate 2 TB + Transcend 1TB ext + Adata 1.5TB ext
      • ASUS GTX 950 STRIX OC 2 GB
      • Samsung B2230 + Viewsonic VX2270S
      • Creative X-Fi Titanium, Asus Xonar DG || Fiio E7 USB DAC and Portable Amp || X-Fi 5.1 Pro USB
      • 5x Bowers and Wilkins VM1, Klipsch RW10 || HEADPHONES: Beyer DT990, Shure SRH440, Sennheiser HD 439,
      • Newmen e370 Illuminated Gaming Keyboard, A4Tech G6 Wireless Desktop
      • Mad Catz Cyborg R.A.T. 7 || Logitech G500 || A4Tech Bloody V3, A4tech G6-70D Wireless, A4tech MOP70D
      • Genius Trio Racer F1 Wheel, Genius MaxFire Grandias 12V Wireless Gamepad, BlackCat xbox360 Gamepad
      • Antec VP550P V2 NC
      • Samsung DVDRW, Sony DVDROM
      • AUDIO PLAYERS: Ipod Nano, SanDisk Sansa Clip+ || FLASH DRIVES: Transcend 128 GB, 16 GB, 2x 32 GB
      • APC 800 VA for CPU and Appolo 800 VA for others
    RMS's Avatar
    Sep 2011
    I bought a RED DEKKER 600 watt blower for only 630 Taka in March. Bought it from 6th floor, Multiplan. Other shops might ask much more from you but don't pay over 650 Taka for 600 watt ones, because its distributor price is only 600 Taka.
    1200 watt blowers cost more than 1000 Tk. But 600 watt blowers are more than enough for normal use. These blowers can also be used as suction pump to remove dust from keyboard.
    I would suggest you not to buy the cheap, orange colored blowers (these usually cost 400~500 BDT) coz these don't last long.
    • shoryuken-x's Gadgets
      • msi
      • 8gb ( to power black x)
      • 1/2 tb
      • Radeon HD 7950
      • 21.5 lcd
      • lagano hoy ni
      • Genius Gx Sw-1250
      • Delux t15s
      • venge gese
      • Tt toughpower XT 675
      • few here nd there
      • 600va
      • jana nei
      • silent htpc
      • antbd
      • 60+
      • Do
    shoryuken-x's Avatar
    Quote Originally Posted by RMS View Post
    bhai blower jinistar watt beshi hole ki dhoroner subidha paua jai ?
    • RMS's Gadgets
    RMS's Avatar
    Sep 2011
    Quote Originally Posted by genocide_cutter View Post
    Beshi watt er ta diye somvoboto batas beshi jore ber hoy.
    • Astro Boy's Gadgets
      • Gigabyte Sniper M5
      • Intel Core i5 4570 @ 3.20GHz
      • Corsair Vengeance 1600MHz 4x2= 8GB
      • HGST 1TB Internal SATA 3.0 + 1 TB 3.0 External
      • MSI R9 270X Twin Frozer Gaming - 4GB EDITION
      • ASUS MX239H
      • A4Tech H100
      • A4Tech Lighting KD 800 Keyboard
      • A4Tech USB Mouse
      • Cooler Master V 750W 80 PLUS GOLD
      • Asus 24x DL DVD R/W
      • BanglalionWimax
      • 1000
    Astro Boy's Avatar
    Sep 2013
    I wish, Small vacuum cleaner is Better than Blower? Any Sugg..??
    • radeef's Gadgets
      • Asus DVD-RW
      • PC Mark 7 - 4558
      • Qubee 1Mbps
      • 100 - 125 Kbps
      • Depends :|
    radeef's Avatar
    Bought a 500w hoteche dust blower from idb. Took me 750 bdt though
    • RMS's Gadgets
    RMS's Avatar
    Sep 2011
    IDB te blower er price ta amar kace ektu beshi mone hoyece. Amar RED DEKKER er price o IDB te 850~900 BDT chaisilo.
    Are these blowers strong enough to blow dust off small corners and linings? I've been looking for a cheap alternative to compressed air cans which themselves do not seem to be available here.
    Quote Originally Posted by mryellow View Post
    Nope. -_-
    Seriously how do poeple in BD clean these corners/cracks of their PC. All these gunk is so hard to clear, and compressed air makes it look so easy to clean, but sadly we don't have that in BD. :/
    I'm using one of these blowers my friend bought for ~450tk 3yrs back and it's still working perfectly. The brand name is "Kingsay"
    Maybe can DIY an attachment nozzle that will taper towards the end or hold one of those WD40 straws. Thanks for the brand name, I'll probably look for one of these in Multiplan. Good investment in place of compressed air (though cost of electricity will have to be factored in).
    u can use it as vacuum cleaner too.
    • maheer.dhruba's Gadgets
      • Gigabyte H81 S2PV rev 2.0
      • Core i5 4460 @3.2Ghz
      • Avexir (2x4)Gb 1333Mhz
      • WD Blue 1TB
      • ASUS VX229H 21.5 inch 1080p
      • Creative 5.1 channel
      • Thermaltake Knucker
      • A4tech bloody v3
      • Logitech f310
      • samsung DVD writer
      • Corsair 32GB usb 3.0
      • Windows 8.1 pro 64bit
      • I'm Loving it!!! :)
      • X-link 1Mbps
      • 128 KBps
      • 128 KBps
    maheer.dhruba's Avatar
    Jun 2012
    Narayanganj, Bangladesh
    He he....amar mne hoe shb chaite joss dust blower hoitese garir tyre pump korar machine ta...mashe ekbar garir garage e nawar koshto korte hbe rki...
    Quote Originally Posted by maheer.dhruba View Post
    amio radiator cleaner diye clean korar plan korsilam.
    but jodi component khule ure jay
    • radeef's Gadgets
      • Asus DVD-RW
      • PC Mark 7 - 4558
      • Qubee 1Mbps
      • 100 - 125 Kbps
      • Depends :|
    radeef's Avatar
    Bhaloi kaj kore alga dust er jonno. But jome gele segulo obviously clean kora jabena ei blower diye
    just buy a rong korar brush
  1. Dust Blower for PC
    By Rubab in forum Help - General Shopping
    Last Post: May 7th, 2014, 07:31
  2. Blower vs usb vacuum cleaner for pc cleaning
    By outragedhuman in forum Help - General Shopping
    Last Post: January 13th, 2014, 22:11
  3. Sale (Used) Electric Blower
    By SheikhItBaby in forum Shop - Gadgets
    Last Post: May 27th, 2012, 02:13
  4. From dust
    By st_Shuvo in forum Sand Box
    Last Post: August 25th, 2011, 20:39
  5. CPU er vitore clean korar jonno ekta SILENT Air blower kuj tasi.
    By knroeoueqisk in forum Others PC Hardware
    Last Post: April 25th, 2010, 02:27
Page generated in 0.32985 seconds with 15 queries.
