Results 1 to 18 of 18
Thread: Tunngle port forwarding problem
    • Shawon191's Gadgets
      • Gigabyte H-61
      • Intel Core i5 3570s 3.1 GHz
      • 4 GB DDR3 1600
      • Samsung 850 Evo 256 GB + WD 1 TB
      • GTX 660
      • Asus VX229H
      • Microlab M223
      • SteelSeries Rival
      • Logitech F310
      • Thermaltake TRS 550W
      • Aamra Technologies
      • 5 mbps
      • 5 mbps
    Shawon191's Avatar
    May 2014
    Default Tunngle port forwarding problem
    So I wanted to play Borderlands with 2 other friends of mine, I watched a youtube video about using tunngle and did all the steps properly. But I can't use the port forward and my status remained yellow(I couldn't host games but join others, my friend had the same issue). My ISP is aamra and my friend's ISP is smile.
    2 questions .. 1. do you have static ip?
    2. do you use router?
      • Gigabyte H-61
      • 4 GB DDR3 1600
      • GTX 660
      • Asus VX229H
      • Microlab M223
      • SteelSeries Rival
      • Logitech F310
      • 5 mbps
      • 5 mbps
    Shawon191's Avatar
    May 2014
    1. Not sure
    2. No
    ask your isp to provide you a real ip unless you cant host a game in GR
    • Franklin's Gadgets
      • Gigabyte z97P D3
      • NIA Wireless Headset
      • A4 tech
      • DS4 Wireless Controller
      • Cooler Master v750W
      • Asus DVD RW 24x
      • Transcend Jetflash v70 8 GB
      • DOT
      • 512 kBps with a B
      • 512 kBps with a B
    Franklin's Avatar
    Jul 2011
    Universe
    I am not sure whether your ISP provides real static IP but Smile does. So, an easy solution would be to tell your friend to forward the Tunngle ports and host the game. You can join it and play with around 100ms ping.
      • Gigabyte H-61
      • 4 GB DDR3 1600
      • GTX 660
      • Asus VX229H
      • Microlab M223
      • SteelSeries Rival
      • Logitech F310
      • 5 mbps
      • 5 mbps
    Shawon191's Avatar
    May 2014
    Isn't there a way to find out if my ISP is static?
    • TaherTheRetard's Gadgets
      • CONSOLE MASTER RACE
      • 136
    Khilgaon
    Quote Originally Posted by Mohammad Shawon View Post
    It's not static since you dont use router but still your port is closed.
    you can ask your isp to open the port but they wont be able to open it permanently since you dont have a real ip
      • Gigabyte H-61
      • 4 GB DDR3 1600
      • GTX 660
      • Asus VX229H
      • Microlab M223
      • SteelSeries Rival
      • Logitech F310
      • 5 mbps
      • 5 mbps
    Shawon191's Avatar
    May 2014
    Quote Originally Posted by fAzIL p0lA View Post
    My IP doesn't get changed if I reconnect or restart PC. Does that mean my IP is static?
      • 136
    Khilgaon
    neither does mine but that doesnt mean i have a real ip. why dont you call your isp ask them all these?
    changing or not changing is not the factor with real ip, in case of real ip they open ports for every connections and even after telling them to forward the port wont be helped because in a certain time later eventually the ip will be changed and and so far the forwarding will be interrupt again, ask them to give you a real ip and after that you will see a green smiling face in the bottom of the software
    • Mike Harper's Gadgets
      • GYGABITE G41 COMBO
      • Pentium(R) Dual Cor E5500 2.80 GHz
      • 4 GB
      • 500 GB
      • ZOTAC GT440 3.25 GB DDR3
      • Windows 7
    Mike Harper's Avatar
    Nov 2013
    Hi . Note that, yellow smiley doesn't always indicate problems. If you see most of the players with red cross, then yellow face is a problem.
    If you do NOT see too many red crosses in a room then the yellow face should be fine .
    As everyone said, asking the ISP will be the best for you .
    Also, as this is Tunngle related you should have posted it also in the Tunngle Forum. Tunngle also have Bengali forum for Bengali Tunnglers .
    Tunngle is a small and awesome software that lets you play ALL the LAN games over Internet for FREE!!
    Join Tunngle and Enjoy awesome Gaming experience
      • Gigabyte H-61
      • 4 GB DDR3 1600
      • GTX 660
      • Asus VX229H
      • Microlab M223
      • SteelSeries Rival
      • Logitech F310
      • 5 mbps
      • 5 mbps
    Shawon191's Avatar
    May 2014
    Okay I talked with my ISP and they said its possible to give me a real IP.
    Quote Originally Posted by Franklin View Post
    My friend's internet is provided through a third party who probably doesn't provide static IP, cause he also wasn't able to open port.
    Quote Originally Posted by Mike Harper View Post
    I was able to join other players game but games hosted by me wasn't visible by my friends.
    Quote Originally Posted by shawon0418 View Post
    once you get the real ip, there wont be any problem with your friends ..
    Unhappy Port forwarding
    tunngle on korle maximum player er normal thake but ami amr friend er shathe connect hote try koresilam but or ta red cross dekhasse.
    and on the other hand or pc te amr ta red cross dekhasse.
    ami port forward koresi tp link diye. but kaj koreni. and amr isp amr bashar niche arekta box set korese jekhan theke amake like dei ora. same thing for my friend.
    ami exploreonlinebd.net isp use kori and amr friend "KS Network" use kore.
    What can I do??? please reply soon. Thank you.
      • 136
    Khilgaon
    Quote Originally Posted by arefinrx View Post
    isp port block kore rakhse. oder phone kore tunngle port open korte bolte paren
    sorry, ami new to port forwarding. amr isp ke call kore exactly ki bolte hobe aktu please bolben? i mean...oder ki ami bolbo je tunngle 11155 port ta amr pc er jonno open kore dite?? aktu confused. and thank you for the promt reply.
      • 136
    Khilgaon
    yes 11155 port open kore dite bollei hobe but apnar ip mone hoy dynamic tai port open kore dileo ta permanently open thakbe na.
    ami portforward utilities diye static ip kore rekhesi...eta ki kaj korbe??
  1. Port Forwarding in Link3?
    By streetsweeper9 in forum Questions
    Last Post: January 31st, 2014, 11:45
  2. Qubee + TP-Link Port Forwarding Issue
    By cyberemon in forum WiMAX
    Last Post: June 11th, 2013, 22:33
  3. FIFA 12 port forwarding
    By Barcaboy in forum FIFA 12
    Last Post: May 9th, 2012, 22:56
  4. Port Forwarding
    By abir in forum Internet
    Last Post: March 23rd, 2011, 22:24
  5. GP Port Forwarding Issue
    By k39bk in forum ISP
    Last Post: February 14th, 2011, 00:48
Page generated in 0.32654 seconds with 14 queries.
