Thread: Laptop is not getting power from battery.running it on ac power only...help
    • knroeoueqisk's Gadgets
      • Intel Core i5 750
      • Cosonic head phone
      • Perfect keyboard
      • Delux optical mouse
      • Normal Non brand gamepad
      • Thermalake TR2 500 watt
      • Samsung 22X Dvd Writer
      • i am happy with it.
      • 15 Kilobytes - 64 Kilobytes
      • 5-15 kilobytes
    Dec 2009
    Default Laptop is not getting power from battery.running it on ac power only...help
    my brother's laptop was running ok till yesterday.
    this morning when he pressed power button nothing showed up.it stays off.so he then connected the power adapter to the laptop and at first laptop's battery indicator showed battery was charged to a level and was getting power from the AC source.but after a few moments the laptop's battery charge amount indicator went to blank/showed battery charge was nil but the ac power indicator shows AC power input is ok.so when he switched on laptop this time it powered up and windows boots up and he can work with his laptop.but then if he disconnects the power adapter the laptops just shuts down directly like power is off.basically his laptop is not getting power from the battery but he can run his laptop through the power adapter/ac power which is not the way it's supposed to run.
    so guys what can be wrong with this laptop?help.
    • Rakin's Gadgets
      • Gigabyte GA-X58-USB3
      • Intel Core i7 920 Cooled by TT Frio (dual fan)
      • Transcend 2 GB + Silicon Power 2GB DDR3 1333Mhz
      • 1 TB Hitachi @ 7200 RPM 32MB Buffer
      • XFX AMD Radeon 5850 Black Edition
      • ASUS MS228H 21.5 Full HD 1080p
      • 10-channel (7.1) Dolby Home Theater Audio subsystem using the Realtek ALC892 audio codec
      • Creative Inspire M4500 4:1 , A4 Tech Headphone
      • A4 tech KBS - 8
      • A4 tech 2X office 7K
      • Xbox 360 Controller for Windows
      • ASUS 650 Watts
      • BenQ 24X
      • Transcend StoreJet 320 GB , Transcend 4 GB Pendrive
      • Powerpac 1200 VA
      • Windows 7 x64
      • 1000/1000
      • The Killer Machine
      • Qubee WiMAX @ 256 kbps
      • 32 KBps
      • 7-8 KBps
    Default Re: Laptop is not getting power from battery.running it on ac power only...help
    battery gese!!!!
    • NIMBUS_TeK's Gadgets
      • Dell Vostro 1015
      • Core 2 Duo 2.2 GHz T 6670 Mobile
      • 4 GB - 800 BUS
      • 320 GB Internal, 750GB External
      • 15.6" LED
      • Genuine Windows 7 Ultimate
      • Zoom Ultra
      • 20
      • 20
    Dhanmondi
    Actually your main problem is not on the battery.. your laptop problem on the battery processor. Every laptop battery have a battery processor... this part carry all the info about your battery.
  1. Replies: 21
  2. Any good power power supply available???
  3. HDD LED/Power LED on casing always on.is it bad?
    By knroeoueqisk in forum Others PC Hardware
    Last Post: March 19th, 2010, 08:53
  4. whats the price range for toshiba's laptop battery?
    By dying4004 in forum Technical Support
    Last Post: January 9th, 2010, 16:36
  5. Revealing The Power of DirectX 11
    By CvP in forum Software
    Last Post: February 1st, 2009, 16:08
Page generated in 0.16460 seconds with 14 queries.
