Results 1 to 20 of 22
Thread: Facing a weird problem with my GTX 670
    • caspianprince's Gadgets
      • Gigabyte B85M-D3H
      • Intel Core i5 4570
      • 1 x Transcend 8GB DDR3 1600MHZ
      • Western Digital 500GB 7200 RPM
      • Gigabyte GTX 670 Windforce 3X OC
      • Dell E1910 19" LCD(1440x900)
      • Creative X-fi Xtreme Gamer
      • Microlab TMN-1 4:1
      • A4-TECH 9300F Wireless Combo
      • Andyson 550W
      • 1. 2 x 500GB External HDD(Western Digital) , 2. 2xTRanscend 500GB Portable HDD
      • Ultra Power 2.65KVA Line-Interactive UPS
      • Windows 7 x64
      • Happy for now.........but always searching for opportunity to Upgrade.......:P
      • 60-70 KBps
      • 60-70 KBps
    Oct 2013
    Default Facing a weird problem with my GTX 670
    i have a Gigabyte GTx 670 windforce 3x OC edition GPU which i am having some issues with..............even though i placed it in x16 PCIe 3.0 slot of gigabyte b85m-D3h mobo it is always running at x4 speed..............i tried reseating it again and again but it's always running at x4 at full load which is ridiculous.............is it a problem of the GPU or the MoBo???????i have warranty left for the GPU...........so if i bring it to the shop how long do u think will it take to repair or replace it????????
    Quote Originally Posted by caspianprince View Post
    make sure to connect it in the Top PCI express port. the lower port is actually a x4 port.
    if it doesnt work reset CMOS.
    i dont think the gpu has any issue, as far i know the b85 boards has 2 pci slots so did you try both of them? and update the bios of your motherboard that might help
    anyway for single gpu x4 doesn't really make any performance differences
    You put in the 2nd pcie slot to look your machine cool Didnt even read whats written in the circuit board.
    you are wrong again.
    • Syeef's Gadgets
      • WD 1TB Blue Sata III
      • Samsung 22-inch LED 1080p
      • N/A
      • Creative SBS 2.1
      • Tt eSports Knucker
      • Logitech F310 Gamepad
      • Samsung DVD-RAM 24x Sata
      • 650VA
      • ~15 Mbps | 128 KB/s
      • ~5 Mbps | 32 KB/s
    Motherboards usually has features to turn down PCIe speed when not needed, to save power, like the CPU.... my CPU is 3.50GHz, but most of the time it is running at ~1.5GHz.
    And my GTX 680 is normally running at x8 speed with x16 PCIe 3.0 motherboard.... so don't worry about it.
    it wont matter for a GT210 but it should matter if the GPU is a 670. although difference will be small but saying it wont make any performance difference is 100% wrong.
    Quote Originally Posted by Syeef View Post
    as far as i know the link width doesnt change.
ID:	33209Click image for larger version.
    yes the difference will be a litte bit like 1 to 3 fps may be which is as same as no difference at all
    http://hardocp.com/article/2010/08/2...4#.U0u4KVehG-M
    PCIE 2.0 x8 = PCIE 1.0 x16
    PCIE 1.0 x16 = PCIE 3.0 x4
    PCIE 2.0 x4 = PCIE 1.0 x8
    Any more insults thrown around here, and they'll get an instant infraction.
    Do not reply to this post.
      • Gigabyte B85M-D3H
      • Andyson 550W
      • Windows 7 x64
      • 60-70 KBps
      • 60-70 KBps
    Oct 2013
    [QUOTE=Vanguard;628955] You put in the 2nd pcie slot to look your machine cool Didnt even read whats written in the circuit board.
    nope..........i am 100% certain i have placed it in the x16 slot...............not the x4 slot...........
    Install your card in the first pcie slot and problem solved. Say Jeeeezzzz!
      • Gigabyte B85M-D3H
      • Andyson 550W
      • Windows 7 x64
      • 60-70 KBps
      • 60-70 KBps
    Oct 2013
    nope.............i am saying again i used the right x16 slot not the x4 slot..........
    remove the battery. wait for a minute thn put the battery back on. see what happens.
    can u put a pic here?
      • Gigabyte B85M-D3H
      • Andyson 550W
      • Windows 7 x64
      • 60-70 KBps
      • 60-70 KBps
    Oct 2013
    did everything u guys said............no improvement..........i forgot to mention earlier............sometimes it's running at x1 speed.............but after restarting PC it goes back to x4..............
    send your card to RMA. You see that sweet cute thing of mine? Thats an 8800GT OC gigabyte. The same problem happened to me in 2008. Had to sell it for damn cheap price then.
    And the psu you see there, is a dual circuit Minebee 1100w.
    u wanted to sell this card right?
      • Gigabyte B85M-D3H
      • Andyson 550W
      • Windows 7 x64
      • 60-70 KBps
      • 60-70 KBps
    Oct 2013
    yup............but that was before i found out about this problem................now i'll have to send it to RMA............
      • Gigabyte B85M-D3H
      • Andyson 550W
      • Windows 7 x64
      • 60-70 KBps
      • 60-70 KBps
    Oct 2013
    They couldn't fix it............so they are replacing it.......but gigabyte gtx 670 is unavailable in market.......so they gave me 2 choices...
    1.replace with gigabyte gtx 670
    2.replace with gigabyte gtx r9 280x........but then i'll have to pay 5000Tk more......
    i am thinking about going for r9 280x......what do u guys think????
    • shoryuken-x's Gadgets
      • msi
      • 8gb ( to power black x)
      • 1/2 tb
      • Radeon HD 7950
      • 21.5 lcd
      • lagano hoy ni
      • Genius Gx Sw-1250
      • Delux t15s
      • venge gese
      • Tt toughpower XT 675
      • few here nd there
      • 600va
      • jana nei
      • silent htpc
      • antbd
      • 60+
      • Do
    shoryuken-x's Avatar
    go for it .........................tk manage koren they can wait
  1. Anyone facing problem with steam???
    By codename5302 in forum General PC Gaming
    Last Post: June 14th, 2013, 21:17
  2. (help)facing weird problem after buying lappy.
    By hasan_1223 in forum Technical Support
    Last Post: March 19th, 2013, 10:19
  3. To those Who are Facing problem inCrysis 3!!PC ONLY!!
    By ATypicalAssasin in forum Technical Support
    Last Post: March 5th, 2013, 22:57
  4. Suddenly Facing A Weird Problem ... Help Appreciated
    By pre in forum Technical Support
    Last Post: March 7th, 2012, 07:26
  5. Suddenly Facing A Weird Problem ... Help Appreciated
    By pre in forum Others PC Hardware
    Last Post: March 6th, 2012, 18:54
Page generated in 0.30255 seconds with 15 queries.
