Results 1 to 20 of 26
Thread: Monitor Repair help
    Default Monitor Repair help
    well the thing is i spilled a bit more liquid display cleaner on my display panel. its a MS 228H. now the thing is, accidentally a small portion of it went straight inside and now the place right below was initially dark. but now there are 2/3 vertical lines.
    anyone knows how to repair? or should i repair?
    as far as i know vertical lines are not good.
    another question is, is repairing a viable option? or should i buy another one?
    I'm curious to know, what cleaner did you use?
    • Rawkill's Gadgets
      • Asrock Z77 Extreme 6
      • WD Blue 1TB x 2
      • Creative Sound Blaster ZX
      • Logitech F510 Rumblepad
      • Prolink 1000VA
      • Cooler Master HAF - X
      • 550-600 KB/s
      • 200-2500 KB/s
    Rawkill's Avatar
    Acid ? Anyways I don't think you can repair a monitor panel and even if you could it would be expensive.
    some cheap 中中 from ECS -_-
    actually it was my fault i did spray a bit more thn usual!
    nope i guess it is based on base!
    -_- damn i have to buy another one thn
    • Syeef's Gadgets
      • WD 1TB Blue Sata III
      • Samsung 22-inch LED 1080p
      • N/A
      • Creative SBS 2.1
      • Tt eSports Knucker
      • Logitech F310 Gamepad
      • Samsung DVD-RAM 24x Sata
      • 650VA
      • ~15 Mbps | 128 KB/s
      • ~5 Mbps | 32 KB/s
    You are not supposed to use any cleaner with LCD or LED, usually mentioned in the manual. They recommend only microfiber cloth soaked in plain water; and if the screen is really dirty, they recommend adding 5-50% white vinegar to the water.
    the electronic tape which connects the LCD and the circuit, is messed up... if you have real experience fixing electronics, you can try fixing it, but otherwise i wouldn't recommend at all.
    You can also take it to a repair place. Last time I checked, it usually costs ~2k in IDB.
    Up to you really, repairing might leave your LCD with scratches and/or other minor issues... if you can live with those, sure.
    Syeef bro thanks for ur reply. Well i actually use the microfiber but instead of spraying on it i sprayed directly on the monitor and boom!
    tape is messed up? are you sure? And i dont have real experience of Fixing LCD. so im not going to repair it myself.
    well the thing is the two green vertical lines are real pain in the 中, i dont have problem with 5-6 dead pixels at the bottom. but those lines are not good :\
    as long as there will be no scratches on the panel and no image quality degradation i dont have any problem with this.
    so IDB? are you talking about the One stop service?
    • iGx : Itachi's Gadgets
      • MSI Z270 GAMING PRO CARBON ATX LGA1151
      • Intel Core i7-7700 3.6GHz Quad-Core
      • G.Skill Trident Z 16GB (2 x 8GB) DDR4-3200
      • Western Digital Caviar Green 2TB and Samsung 850 EVO-Series 250GB 2.5" SSD
      • GEFORCE GTX 1060
      • ViewSonic VX2270Smh-LED Black 22" 7ms (GTG) HDMI Widescreen LED Backlight LED Monitor IPS panel 250
      • 7.1
      • Steel Serise Siberia V2 & Creative Inspire
      • CORSAIR K95
      • SteelSeries DIABLO + Fnatic Mouse Pad
      • PS3 Controller
      • CORSAIR CX 600
      • Asus DVD ROM RW+-
      • TV CARD, SCANER,Pendrive, wireless Headphone
      • "LIKES" Back-up to 45min
      • MICROSOFT WINDOWS 10 PRO
      • P1567 3DMarks 11
      • Physics Score 3131 ||Graphics score 1430
      • Local <3
      • 8.9MB
      • 6MB
    iGx : Itachi's Avatar
    Khilgaon,Dhaka
    • Syeef's Gadgets
      • N/A
      • Creative SBS 2.1
      • 650VA
      • ~5 Mbps | 32 KB/s
    was talking about the "cleaner liquid" mainly... they might cause damage to the screen surface and overtime turn the screen yellowish (if they contain ammonia), that's why monitor manufacturers recommends not to use them at all. read all these information in the LCD manual .
    Ya, you can go to "One stop service", but I wouldn't recommend them, they once swapped the internal components of my LCD while I went there to claim warranty from Global. But that was ~7 years ago... who know, maybe they've changed now.
    You can take it to Rishit or Ryans or places like that instead and ask them to repair it for you.
    You should mention this before hand then, make them agree first.
    i think this cheap 中中 got only water + slightly Base based something! and the panel is still good
    dont like rishit and one stop. so i guess i will visit ryans
    i would definitely mention that but shopkeepers dont usually listen to anything. and it would be good if they do this repairing infront of me -_- which they probably wont do!
    btw thanks!
    Quote Originally Posted by nazmul1515 View Post
    Bro,
    I had a broadband connection before and I was using tp-link 150 mbps router to make it wifi. Now I don't have the broadband connection. I'm using banglalion wimax. I want to use the same router to create my own wifi zone. Please help me do that. I need your help badly. My mobile number is 01935-208319.
    I'm waiting to read your kind reply.
    wrong place but u can hook up the wimax router using USB and share it over LAN. then hook up the routers wan port to the LAN port of PC. good luck!
    http://redwanhasan.blogspot.com/2013/03/good-afternoon-hope-everyone-is-fine-in.html
      • GIGABYTE B75M-D3H rev1.1
      • A4Tech KRS-86
      • Thermaltake azureus
      • Antec VP450P
      • Samsung DVD RW+Asus CD RW
      • Win 8.1 pro x64
    @nonymous's Avatar
    Unknown
    do the lines change position? if so, then probably a lcd bus(which they call ribbon) got partially damaged. this chance is low since the spray shouldn't reach there and damage that.
    if they are stable then it's likely some rows of lcd matrix are dead. this can't be repaired unless changing the whole lcd panel which may cost almost as much as a new monitor.
    Quote Originally Posted by @nonymous™ View Post
    do the lines change position? if so, then the color addressing bus got partially damaged. this chance is low since the spray shouldn't reach there and damage that ribbon.
    well they does change. but right now there is no vertical lines. only the lower part of the monitor has about 4-5 pixels which are just white.
    so i guess the ribbon is ok. and only a few pixels down there might be leaked somehow. ?!!
      • A4Tech KRS-86
      • Antec VP450P
      • Win 8.1 pro x64
    @nonymous's Avatar
    Unknown
    means they disappeared automatically ?
    only the lower part of the monitor has about 4-5 pixels which are just white.so i guess the ribbon is ok. and only a few pixels down there might be leaked somehow. ?!!
    may be.......
    may be.......
    yes they disappeared. i guess a somehow something leaked and shorted out those lines. but not sure abt what might happen to the pixels there.
    surrounding pixels that might look black is actually dust.
      • A4Tech KRS-86
      • Antec VP450P
      • Win 8.1 pro x64
    @nonymous's Avatar
    Unknown
    seems like typical dead/stuck pixel
    as far as i know there is no way to fix a dead pixel?! so it cant be repaired?
    i did apply a small pressure. didnt work. btw
    • -RAKIB-'s Gadgets
      • Asrock B75M
      • Intel Core i5 2310 (2.9 Ghz)--Stock Clock--Stock Fan
      • PQI-4gb-1333 Bus-single stick.
      • SAMSUNG Sata-2 (320gb)
      • Gigabyte 660-OC-2GB-Windforce2..
      • Samsung B1930-LCD-18.5 inch :(
      • Built in.
      • Creative Inspire T3200 (2:1)
      • Value Top-normal (multimedia)
      • A4tech X7..
      • Thermaltake Smart 550w- Modular
      • Samsung Writemaster-- Not using currently -_-
      • Apacer 8gb Pendrive-usb2-_-
      • Prolink-650VA
      • Windows 7-Ultimate-64bit
      • Gaming is fun, but Acquiring a Satisfactory setup for it is not -_-
      • 190kpbs
      • Havn't checked yet!
    -RAKIB-'s Avatar
    Jan 2013
    So, my dream came true??? It got repaired automatically
    Why so Serious!
    Quote Originally Posted by -RAKIB- View Post
    not fully.
      • A4Tech KRS-86
      • Antec VP450P
      • Win 8.1 pro x64
    @nonymous's Avatar
    Unknown
    there are bunch of weird ideas & so called fixer software available on the net. although i've never seen or heard anything worked in practice. only chance if they disappear automatically too....
    there are bunch of weird ideas and so called fixer software available on the net. although in practice i've never seen or heard anything worked. only chance if they disappear automatically too....
    yuuup. anyway thanks !
    ms 228H... damn... you should regret using that cleaner
    i always use wataaaa
  1. [Help]HDD repair
    By Mohiuddin in forum Technical Support
    Last Post: September 6th, 2012, 22:30
  2. Gpu repair
    By Raziel in forum GPU
    Last Post: October 21st, 2011, 19:15
  3. Repair GPU?
    By vergil007 in forum Technical Support
    Last Post: September 11th, 2011, 05:41
  4. repair psp or psp hardware
    By alimusaweer in forum PSP/PS Vita
    Last Post: June 9th, 2011, 00:35
  5. Help!!!!where Can I Repair My Gpu????????
    By xk :: CranKpin in forum Technical Support
    Last Post: July 16th, 2008, 23:33
Page generated in 0.30918 seconds with 15 queries.
