Results 1 to 20 of 23
Thread: CPU High Temps problem
      • Asus P5KPL-AM
      • Dual Core E5400
      • Built-In
      • AOC F22 22"
      • Realtek
      • Delux
      • BUSTED !
      • Transcend 16GB
      • DigitalX 650VA
      • Windows 8 Pro x64
      • IS PROS
      • Average: 24 Kbps
      • Average: 24 Kbps
    йЦммєя³¹'s Avatar
    Apr 2009
    Default CPU High Temps problem
    while i'm playin even css
    after a while my fps drops
    and my cpu temps go high
    is it because my psu is 400W
    and my armor has 5 fans in it
    so maybe the power is being distributed
    and the CPU fan is having less rpm
    i'm not sure
    but the temps sure has increased
    • knroeoueqisk's Gadgets
      • Intel Core i5 750
      • Cosonic head phone
      • Perfect keyboard
      • Delux optical mouse
      • Normal Non brand gamepad
      • Thermalake TR2 500 watt
      • Samsung 22X Dvd Writer
      • i am happy with it.
      • 15 Kilobytes - 64 Kilobytes
      • 5-15 kilobytes
    Dec 2009
    Default Re: CPU High Temps problem
    how long you have been using that power supply of yours?
    maybe it has become weak.not sure though.
    • Albert SX65's Gadgets
      • A4 Tech KBS-8 Multimedia
      • A4 Tech 2X Office MOP-70D
      • Asus DRW-2014L1T
      • Transcend JetFlash V30(2gb)
      • Prolink 600V/A
      • 5.9 in win7
      • Quite Satisfied :-)
      • GrameenPhone - P2 Unlimited
      • 25KBps +
      • 15KBps +
    Albert SX65's Avatar
    Feb 2009
    Left Side Of Ur Brain.
    Real temp /hw monitor diye monitor koren and bios temp daken then janan.
    I think its because of ur PSU. for tasting take 500W from someone and see what happens.
      • Asus P5KPL-AM
      • Dual Core E5400
      • Built-In
      • AOC F22 22"
      • Realtek
      • Delux
      • BUSTED !
      • Transcend 16GB
      • DigitalX 650VA
      • Windows 8 Pro x64
      • IS PROS
      • Average: 24 Kbps
      • Average: 24 Kbps
    йЦммєя³¹'s Avatar
    Apr 2009
    Quote Originally Posted by anik View Post
    real Temp de dekhlam
    @idle thake 55c
    @css thake 85c
    aitai ki thaka uchit?
    but my main question is whether extra chassis fan will decrease the rpm of the cpu fan?
    • Mazhar's Gadgets
      • ASUS B250 Strix
      • AMD Ryzen 1700X
      • G.Skill 2x8GB DDR4 3200
      • Samsung 850 Pro 1TB
      • Gigabyte 1070Ti
      • Dell U2711
      • ASUS Essence STX II
      • Beyerdynamic Tesla T1
      • G910
      • G502
      • Xbox One Controller
      • Windows 10 Home
      • Aamra
    Mazhar's Avatar
    Quote Originally Posted by йЦммєя³¹ View Post
    It shouldnt, is your cpu fan connected to the motherboard or the psu? to remove your suspicions, you can disconnect the chassis fans an see if cpu fan rpm changes. it really shouldnt
    If the cpu fan is connected to the motherboard, disable smart fan control and see what the max rpm of the fan is. Might be the fan running at a lower rpm than it should due to the fan controller, happened a few times
      • Asus P5KPL-AM
      • Dual Core E5400
      • Built-In
      • AOC F22 22"
      • Realtek
      • Delux
      • BUSTED !
      • Transcend 16GB
      • DigitalX 650VA
      • Windows 8 Pro x64
      • IS PROS
      • Average: 24 Kbps
      • Average: 24 Kbps
    йЦммєя³¹'s Avatar
    Apr 2009
    Quote Originally Posted by Mazhar View Post
    cpu fan is connected to the mobo
    and i did disconnect the chassis fan
    but it's hard to guess the change in rpm just by looking at it
    but do u think the temps are not acceptable?
      • Asus DRW-2014L1T
      • Prolink 600V/A
      • 5.9 in win7
      • 25KBps +
      • 15KBps +
    Feb 2009
    Use tharmal paste .and 85'c is high for cpu.
    Actually it Should if the CPU fan is Temp regulated n smart enabled ( it mi8 be diff in ur bios). In my case if i turn off the Chassis fan, in 10-20 seconds the cpu fan rpm starts to increase (maxed around 4500 rpm). This happens when the sensor is mounted on the upper side of the sink thus more exposed to surrounding air flow.
    @ йЦммєя³¹ try to mention ur CPU model # and the temp u have mentioned doesn't not seem normal if its in stock freq.
      • Asus DRW-2014L1T
      • Prolink 600V/A
      • 5.9 in win7
      • 25KBps +
      • 15KBps +
    Feb 2009
    cpu model c2d e7400.
    @31 ru overclock ur cpu?
    looks too high for e7400
    checklist:
    re apply thermal paste.
    Manually put vcore to default voltage.
    Check CPU FAN rpm.
      • Asus P5KPL-AM
      • Dual Core E5400
      • Built-In
      • AOC F22 22"
      • Realtek
      • Delux
      • BUSTED !
      • Transcend 16GB
      • DigitalX 650VA
      • Windows 8 Pro x64
      • IS PROS
      • Average: 24 Kbps
      • Average: 24 Kbps
    йЦммєя³¹'s Avatar
    Apr 2009
    no i never overclocked
    so how do i check my cpu fan rpm?
    is there any software for that?
    and i don't know the bios settings much
    so tell me how can i access them
    here i found a soft that can show the fans rpm
    btw, i have 1 cpu fan and 2 LED fans connected to the mobo
      • Asus DRW-2014L1T
      • Prolink 600V/A
      • 5.9 in win7
      • 25KBps +
      • 15KBps +
    Feb 2009
    Try hw monitor soft.just google it dl it.
      • Asus P5KPL-AM
      • Dual Core E5400
      • Built-In
      • AOC F22 22"
      • Realtek
      • Delux
      • BUSTED !
      • Transcend 16GB
      • DigitalX 650VA
      • Windows 8 Pro x64
      • IS PROS
      • Average: 24 Kbps
      • Average: 24 Kbps
    йЦммєя³¹'s Avatar
    Apr 2009
    here u go:
    are the fans at their default rpm?
    and all the volt thingy ok or not?
      • Asus DRW-2014L1T
      • Prolink 600V/A
      • 5.9 in win7
      • 25KBps +
      • 15KBps +
    Feb 2009
    Cpu volt ok no problem.
    fast clean old paste and cpu fan then reaply paste (little just only 0.5mg) i hope it's work.
      • Asus P5KPL-AM
      • Dual Core E5400
      • Built-In
      • AOC F22 22"
      • Realtek
      • Delux
      • BUSTED !
      • Transcend 16GB
      • DigitalX 650VA
      • Windows 8 Pro x64
      • IS PROS
      • Average: 24 Kbps
      • Average: 24 Kbps
    йЦммєя³¹'s Avatar
    Apr 2009
    thank god volt bolt thik ase
    so, how do i clean the paste?
    with normal cloth or tissue? or do i need some other kind of paste for that also?
    and can i apply non brand paste e.g. normal ones?
      • Asus DRW-2014L1T
      • Prolink 600V/A
      • 5.9 in win7
      • 25KBps +
      • 15KBps +
    Feb 2009
    Normaly use tissue and use some water in heatsink base.if u have alcohole(mod) then use it's best cleaner ever.and yeah there is has a peste cleaner and good news mazar bro sell it.
      • Asus P5KPL-AM
      • Dual Core E5400
      • Built-In
      • AOC F22 22"
      • Realtek
      • Delux
      • BUSTED !
      • Transcend 16GB
      • DigitalX 650VA
      • Windows 8 Pro x64
      • IS PROS
      • Average: 24 Kbps
      • Average: 24 Kbps
    йЦммєя³¹'s Avatar
    Apr 2009
    yeah so i've read that 99% alcohol is best
    but where do i get 99% alcohol?
    read that spirit also works
    have u ever done it?
    can u give me some personal experience pointers?
      • Asus DRW-2014L1T
      • Prolink 600V/A
      • 5.9 in win7
      • 25KBps +
      • 15KBps +
    Feb 2009
    Pesonal experience i use allways water and sometime i use cerosin but muard bro use both paste cleaner and alcohol.
    Btw i have know idea about who sell alcohol.
    • Mazhar's Gadgets
      • ASUS B250 Strix
      • AMD Ryzen 1700X
      • Gigabyte 1070Ti
      • Dell U2711
      • G910
      • G502
      • Windows 10 Home
      • Aamra
    Mazhar's Avatar
    Thats the point. I should have noted that some older motherboards have the smart fan control temperature sensor outside the CPU, but newer motherboards adjust the fan speed based on the diode in the CPU itself. Hence for the newer motherboards, the chassis fans wouldnt matter as the CPU was already at 85'C
    Thanks for pointing it out though, I should have checked his configuration first
  1. Replies: 7
    Last Post: March 27th, 2010, 19:33
  2. cpu temp too high
    Last Post: February 22nd, 2009, 02:23
  3. NFS 4:High Stakes WINXP SP2 FiX
    By ScS :: XTR in forum Older NFS Games
    Last Post: September 16th, 2008, 00:12
Page generated in 0.31409 seconds with 15 queries.
