Thread: Chassis USB problem
      • Asus P5KPL-AM
      • Dual Core E5400
      • Built-In
      • AOC F22 22"
      • Realtek
      • Delux
      • BUSTED !
      • Transcend 16GB
      • DigitalX 650VA
      • Windows 8 Pro x64
      • IS PROS
      • Average: 24 Kbps
      • Average: 24 Kbps
    йЦммєя³¹'s Avatar
    Apr 2009
    Default Chassis USB problem
    so, i got this thermaltake Armor(Full Tower) casing
    but whenever i connect the casing's front USB cables
    i get a weird BIOS screen
    saying the pc will shutdown in 15 seconds and then it does!
    i can't even get to the BIOS settings when the screen shows itself
    what do i do ? I have no idea why's this happening
    btw, the front audio line input works
    and i can connect my headphone with it
    and i didn't connect the IEEE firmware cable
    cause i don't need it
    someone help me ASAP
    Default Re: Chassis USB problem
    I don't have proper idea about front USBs or lines, but I can say, check those lines which are connected to mobo. Check if they're connected correctly ? :S
    BTW, why do u need it ASAP ? u can run some days using back USBs. :S
    • Red Devil's Gadgets
      • Gigabyte Z68X-UD5-B3
      • Intel Core i5-2500K Sandy Bridge @4.00 GHz with Corsair H75 LC
      • AVEXIR - Core Series 8GB(4GBX2) 1600MHz @9-9-9-24
      • Samsung 850 Evo 250GB SSD + Seagate Barracuda (4TB+3TB) HDD
      • MSI GTX 960 2GB
      • ASUS VX229H IPS Panel Monitor
      • Creative Sound Blaster X-FI Titanium
      • Altec Lansing expressionist ultra MX6021
      • Corsair Vengeance K70 Mechanical Keyboard
      • A4tech Bloody V9C/Razer Goliathus Fragged Control Edition
      • XBOX One Wireless Controller
      • Thermaltake Smart SE 630M || Cooler Master HAF 912 Advance Mid Tower Case
      • Pioneer DVD RW
      • Transcend V60 8GB, Apacer 2GB pen drive
      • RahimAfroz 800VA
      • Windows 10™ Pro 64 Bit
      • My PC is my life......
      • ICC
      • 8mbps
    Red Devil's Avatar
    may be it's about some setting!! just set your @default setting. i guess it will do the job. let me know.
      • Asus P5KPL-AM
      • Dual Core E5400
      • Built-In
      • AOC F22 22"
      • Realtek
      • Delux
      • BUSTED !
      • Transcend 16GB
      • DigitalX 650VA
      • Windows 8 Pro x64
      • IS PROS
      • Average: 24 Kbps
      • Average: 24 Kbps
    йЦммєя³¹'s Avatar
    Apr 2009
    Quote Originally Posted by Red Devil View Post
    i don't get what u are sayin?
    i didn't configure anything to begin with
    i just plugged everything as i was suppose to
    and this is what happens
    maybe i'll understand if u explain a bit
    ---------- Post added at 19:24 ---------- Previous post was at 19:22 ----------
    Quote Originally Posted by Rion a.k.a. রিয়ন View Post
    well i need it asap
    cause i have to use pen drives every single day
    and charge my mp3 player
    it's gonna be tough to turn around this huge case to do it
    maybe ur motherboard cant transfer data to the chassis usb. so i think u need check the usb connection in the mobo again.
      • MSI GTX 960 2GB
      • Pioneer DVD RW
      • RahimAfroz 800VA
      • ICC
      • 8mbps
    Red Devil's Avatar
    Quote Originally Posted by йЦммєя³¹ View Post
    in your bios menu, you will find something like "Load Fail-Safe Defaults". do it, it will set your bios in default condition.
    you said you didn't do anything at all. but i guess, there is something wrong with your bios setting. so just try it.
      • Asus P5KPL-AM
      • Dual Core E5400
      • Built-In
      • AOC F22 22"
      • Realtek
      • Delux
      • BUSTED !
      • Transcend 16GB
      • DigitalX 650VA
      • Windows 8 Pro x64
      • IS PROS
      • Average: 24 Kbps
      • Average: 24 Kbps
    йЦммєя³¹'s Avatar
    Apr 2009
    thanx but didn't require that much effort
    all i had to do was invert the cable and then insert it
    that solved the problem
      • MSI GTX 960 2GB
      • Pioneer DVD RW
      • RahimAfroz 800VA
      • ICC
      • 8mbps
    Red Devil's Avatar
    how the hell did that happen?? coz afaik there is no way you can insert the cable in wrong way. any way, thanks.
    as i said before. but nice to know ur prob solved.
  1. HDD Problem ...
    Last Post: March 17th, 2010, 00:40
  2. CPU problem
    By Codename-Scorpion in forum Technical Support
    Last Post: November 26th, 2009, 00:34
  3. Thermaltake's Jaw-Dropping Level 10 Chassis Unboxed
    By rebel_warrior in forum Others PC Hardware
    Last Post: October 4th, 2009, 17:20
  4. Replies: 0
    Last Post: April 30th, 2009, 01:20
  5. dl problem in RS
Page generated in 0.21351 seconds with 14 queries.
