Results 1 to 2 of 2
Thread: Asus MS228H 21.5" LED Monitor
    • Speed's Gadgets
      • Creative ZxR| Built In
      • ASUS DVD +/-RW
      • USPOWER 2000va Online UPS
      • Windows 10 Pro 64 bit
      • DHAKANET
      • 750
      • 650
    Speed's Avatar
    Khilgaon
    Default Asus MS228H 21.5" LED Monitor
    • Display
      Panel Size: Wide Screen 21.5"(54.6cm)
      True Resolution : 1920x1080
      Pixel Pitch : 0.248mm
      Brightness(Max) : 250 cd/㎡
      ASUS Smart Contrast Ratio (ASCR) : 10000000:1
      Viewing Angle (CR≧10) : 170°(H)/160°(V)
      Response Time : 2ms (Gray to Gray)
      Display Colors : 16.7M
    • Video Feature
      Trace Free Technology
      SPLENDID Video Intelligence Technology
      SPLENDID Video Preset Modes : 5 Modes
      Skin-Tone Selection : 3 Modes
      Color Temperature Selection : 5 Modes
      HDCP support
    • Convenient Hotkey
      SPLENDID Video Preset Mode Selection
      Auto. Adjustment
      Brightness Adjustment
      Contrast Adjustment
      Input Selection
    • I/O Ports
      Signal Input : HDMI , D-Sub, DVI-D (via HDMI-to-DVI cable)
      AV Audio Input : HDMI
      Audio Output : 3.5mm Mini-Jack (for HDMI Only)
    • Signal Frequency
      Analog Signal Frequency : 30~83 kHz(H)/ 55~75 Hz(V)
      Digital Signal Frequency : 30~83 kHz(H)/ 55~75 Hz(V)
    • Power Consumption
      Power Consumption < 25 W
      Power Saving Mode < 1 W
    • Mechanical Design
      Chassis Colors : Star Blue+Black
      Tilt : +20°~+10°
      Slim Design : Yes
    • Security
      Kensington lock
    • Dimensions
      Phys.Dimension(WxHxD): 519.5x377.6x155.9mm
      Box Dimension(WxHxD): 587x430x140mm
    • Weight
      Net Weight (Esti.): 3.0 kg
      Gross Weight (Esti.): 5.0 kg
    • Accessories
      VGA cable
      Power cord
      Power adapter
      Quick start guide
      HDMI-to-DVI cable
      Warranty Card
    • Regulation Approval
      Energy Star®, BSMI, CB, CCC, CE, CEL level 2, C-Tick, ErP, FCC, Gost-R, J-MOSS, PSB, PSE, RoHS, UL/cUL, VCCI, WEEE, WHQL (Windows 7, Windows Vista)
    http://www.asus.com/Monitors_Projectors/MS228H/
    Condition: fully fresh. 3 year used. no dead pixel. no scratch. no issue.
    Reason for selling : Upgraded to this sweet thingy : http://www.asus.com/Monitors_Projectors/VG248QE/
    Accesories: VGA to VGA, Belkin DVI-HDMI,Original Package(box)
    Price: 10,000 (damn fixed)
    Note:
    1. For serious buyers only.
    2. Do not reply if you are not interested.
    3. I do not need anyone's advice regarding price or anything.
    4. Product will be available for sell from 5th April 2014.
    5. You must check the product at my residence, i will not be responsible for anything after the deal is done.
    6. It's over 3 years so NO WARRANTY.
       0
    • Speed's Gadgets
      • ASUS VG248QE 1080p LED 24&quot; 144 Hz| ASUS Built In
      • ASUS DVD +/-RW
      • DHAKANET
      • 750
      • 650
    Speed's Avatar
    Khilgaon
    Update: Price Reduced.
    Product SOLD
       0
  1. Sale (Used) Asus MS228H Led Monitor
    By MaDDy in forum Shop - Gadgets
    Last Post: August 15th, 2013, 02:41
  2. Replies: 13
    Last Post: March 2nd, 2012, 08:42
  3. Asus MS228H LED Monitor Video Quality. Need your Help!
    By temp003 in forum Others PC Hardware
    Last Post: April 23rd, 2011, 20:19
  4. Replies: 34
    Last Post: November 11th, 2010, 23:51
  5. Love @ first sight: ASUS MS228H
    By AmareX in forum Technical Support
    Last Post: September 24th, 2010, 17:41
Page generated in 0.16655 seconds with 14 queries.
