Results 1 to 12 of 12
Thread: For Sell 1xTT Thunderbalde 3 pin, 1xCM Blade Master 120-Sleeve Bearing 4pin,1xAC industrial Fan
    Default For Sell 1xTT Thunderbalde 3 pin, 1xCM Blade Master 120-Sleeve Bearing 4pin,1xAC industrial Fan
    1xTT Thunderbalde 3 pin 400/= BLUE LED. Used for 4 months [email protected] vertical orientation.
    1xCM Blade Master 120-Sleeve Bearing 4pin, Used for 1 year or so no led. 700/= [email protected] orientation.
    1x AC industrial Fan w/aluminium body, used for 1 month.Ball bearing 200/= [email protected] orientation
    Reason for sell: Shifting to a bigger setup with similar type of fans.
    Price revised
    • caspianprince's Gadgets
      • Gigabyte B85M-D3H
      • Intel Core i5 4570
      • 1 x Transcend 8GB DDR3 1600MHZ
      • Western Digital 500GB 7200 RPM
      • Gigabyte GTX 670 Windforce 3X OC
      • Dell E1910 19" LCD(1440x900)
      • Creative X-fi Xtreme Gamer
      • Microlab TMN-1 4:1
      • A4-TECH 9300F Wireless Combo
      • Andyson 550W
      • 1. 2 x 500GB External HDD(Western Digital) , 2. 2xTRanscend 500GB Portable HDD
      • Ultra Power 2.65KVA Line-Interactive UPS
      • Windows 7 x64
      • Happy for now.........but always searching for opportunity to Upgrade.......:P
      • 60-70 KBps
      • 60-70 KBps
    Oct 2013
    are u saying that the TT thunderblade one is only for vertical orientation or can it be used for horizontal orientation too??????
    Quote Originally Posted by caspianprince View Post
    nope. U can use either way. But I always use sleeve bearing fans at vertical orientation for prolonged life.
    • Rawkill's Gadgets
      • Asrock Z77 Extreme 6
      • WD Blue 1TB x 2
      • Creative Sound Blaster ZX
      • Logitech F510 Rumblepad
      • Prolink 1000VA
      • Cooler Master HAF - X
      • 550-600 KB/s
      • 200-2500 KB/s
    Rawkill's Avatar
    WTF were you doing with an industrial fan ? on hoile to mone hoi generator er moto shobdo kore....
    This type of fan is quite ideal for exhaust + they r extremely durable. As for sound, I use voltage regulator to keep the ummph down. Anyway planning to get 8 of these by Sanyo Denki-Made in Japan.
    • Rawkill's Gadgets
      • WD Blue 1TB x 2
      • Prolink 1000VA
      • 550-600 KB/s
      • 200-2500 KB/s
    Rawkill's Avatar
    8 fans !!!!! Keo amare fan-guard gula khuila, rotating fan chuira MAIRALAAAAAAAAAAAAAAAAAAA!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
    LoL! they are not for a typical casing. I'll soon open a thread on a new case build. See u there.
    bump.....
    where is your location? book TT Thunderblade fan for me plz
    Thermaltake and industrial Ac fan up for sale.
    Only the Thermaltake and industrial Ac fan is up for sale. Price revised
    bumpp
  1. Replies: 2
    Last Post: February 17th, 2014, 08:06
  2. Sale (New) Black & White paracord (cable sleeve)
    By Dee in forum Shop - Gadgets
    Last Post: May 17th, 2012, 01:20
  3. Sale (New) Cooler Master Blade Master 120mm fan for sale
    Last Post: February 26th, 2012, 22:02
  4. Sale (New) Xigmatek Dark Knight S1283V Black Nickel CPU Cooler with 120mm Rifle Bearing
    By acE.Shanny in forum Shop - Gadgets
    Last Post: February 7th, 2012, 15:26
  5. A legenD! of cricket--Little Master.Master blaster
    By sadi_warhead in forum Cricket
    Last Post: February 25th, 2010, 14:09
Page generated in 0.23191 seconds with 15 queries.
