Thread: problem with casing
    Post problem with casing
    casing kinbo , budget 2000 tk . jeita choose korsi oitar dimension ( W x H x D ) 180 x 420 x 380 mm . gfx pore kinbo , r7 260x kinte chai . oitar dimension 177(L)X106(W)X35(H) mm . gfx ki ei casing e set hobe naki pore jhamelay porbo ????
    r7 260x to onek choto card howar to kotha
    like sansei said... 260X should be a small card. and it should fit any case nicely
    • MusharratC's Gadgets
      • MSI 990FXA G65
      • Asus VX229
      • Prachin JVC UX T1
      • Gigabyte Pulse 650W
      • Dead Powertree 1250VA
      • An ALMOST decent rig!
    MusharratC's Avatar
    Feb 2013
    should fit! the depth of the casing is 380mm(from your description), so it should'nt be a problem...
    @CvP amader aage arekta Sensei chilo na? Girlfriendwala. O koi akhon?
  1. Sale (Used) PSU, Casing, HDD
    By nasim in forum Shop - Gadgets
    Last Post: March 17th, 2013, 23:12
  2. Sale (Used) Thermaltake 120mm Dokker Casing fan & Asus 120mm casing fan sale
    By VIPERS in forum Shop - Gadgets
    Last Post: April 27th, 2012, 23:15
  3. Nvidia Driver Problem or Graphics Card Problem ??
  4. 200 mm Casing Fan
    By Raziel in forum Others PC Hardware
    Last Post: December 11th, 2011, 01:05
  5. help me about using Cpu fan as casing fan
    By TaherTheRetard in forum Technical Support
    Last Post: June 22nd, 2011, 01:36
Page generated in 0.17664 seconds with 14 queries.
