Thread: Mazeda wifi issue with router:: need solution
    • Rajmi's Gadgets
      • MSI H61M-E33 [B3]
      • Corei5 2500k
      • GSkill Ripjaws 2x2 => 4gb
      • intel 3000
      • 19" LCD LG Flatron
      • Creative 2.1
      • A4tech slim
      • Delux T6 :: Dragon
      • Delta 550W
      • BTCL - ADSL
      • 64KBps
      • 15KBps
    Rajmi's Avatar
    Default Mazeda wifi issue with router:: need solution
    gotokal MAZEDA'r line nilam r, wifi use korar jonno ekta netgear N300 router kinlam, jeno mobile r laptop thekeo line use korte pari.
    amar eikhaen mazeda'r line "FnF" (net provider) niye ashche.
    unana boltese je, TPLINK er router chara onno kono router diye jodi ami net use kori, tahole torrentbd,mazeda server etc. kono tatei connect kore BDIX use korte parbo na. normal speed ashbe, cause netgrear/belkin local ip address issue kore, jeta ftp server gula recognise kore na BDIX er connection hishabe.
    only TPLINK e apparently dynamic ip issue kore for the devices using wifi.
    just jante chai, je if this is really an issue, because netgear er router already kine felsi...
    jodi solution thake, then please recommend koren, naile kalke giye bodlaye niye ashbo router ta.
    • Dracu_JeF's Gadgets
      • Intel HM65
      • core i5-2410M @2.30GHz
      • 2GB
      • 500GB
      • Intel HD Graphics 3000, Nvidia GT 410M
      • Windows 8.1
      • It's a crappy lappy ~
      • Dhakacom
      • 260
      • 200
      • 136
    Dracu_JeF's Avatar
    Quote Originally Posted by Rajmi View Post
    I'm using ASUS RT-N12 and I get the usual local speed(2-5 mBps) from Mazeda server, Antaranga server, Dhakatorrent, Theaterbd. And from the BDIX sites(like torrentbd,crazyhd and other sites) I usually get 200 kBps-1mBps. Cant say anything about netgear though.
    Since you have both the router and the line, why not just try it?
    • Rajmi's Gadgets
      • MSI H61M-E33 [B3]
      • Corei5 2500k
      • intel 3000
      • Creative 2.1
      • A4tech slim
      • Delta 550W
      • BTCL - ADSL
      • 64KBps
      • 15KBps
    Rajmi's Avatar
    hm..problem was solved...the isp ppl were stupid. there were no issues to begin with! :/
  1. Sale (Used) TP-LINK TL-W727N Wifi Receiver + 150Mbps Wifi B/G/N router
    Last Post: December 11th, 2013, 10:20
  2. Want to buy a wifi router
    By maheer.dhruba in forum Help - PC Buying
    Last Post: August 1st, 2013, 01:43
  3. Solution for 999 or 0 ping issue!
    By ralph3187 in forum Technical Support
    Last Post: June 21st, 2012, 01:16
  4. Wifi issue
    By aayman in forum Technical Support
    Last Post: November 1st, 2011, 02:52
  5. Solution of rumen's Issue
    By virus_bd in forum Complaints & Suggestions
    Last Post: October 23rd, 2011, 12:38
Page generated in 0.15784 seconds with 14 queries.
