Results 1 to 20 of 28
Thread: Problem with Wifi Router
    • SadIkMahdI's Gadgets
      • Gigabyte B85M-D3H
      • Intel Core i5 4590 @ 3.30 GHz
      • 4x4GB G.SKILL Ripjaws Series 240-Pin DDR3 SDRAM 1600 Bus Desktop Memory
      • Western Digital WD10EZEX 1 TB | SanDisk 2.5" 128GB SATA III Internal Solid State Drive
      • EVGA GeForce GTX 750 Ti FTW Edition with ACX Cooling
      • Samsung SB19B300B 18.5 LED
      • Built in Realtech HD
      • Altec Lansing VS2621 2:1 Channel Speakers
      • Newmen E370 Illuminated Keyboard
      • Bloody V3
      • Original Microsoft Xbox360 Controller for Windows (Wired Black)
      • Thermaltake Litepower 500W
      • Samsung S-ATA TrueDirect Super WriteMaster
      • SanDisk Ultra USB 3.0 Flash Drive 32 GB
      • Windows 7 Ultimate 64 Bit
      • 5.3 @ Windows 7 Benchmark
      • long way 2 go..
      • B.Net
      • 2.5 Mbps
    SadIkMahdI's Avatar
    Default Problem with Wifi Router
    I am Facing a problem regarding wifi router.
    Currently i am using Broadband Connection which uses WAN PPOE protocol to connect with user (username and password login). My current Wifi router TP Link TL W720N works properly with the connection after configuring with the isp designated username and password.
    But recently i have got a new wifi router from my cousin which is TP Link TL WR940N. i am giving the 720n to my cousin and taking his WR940N.
    But Now when i tried to configure the WR940N with the same process like 720N, everything happened properly with default settings, but i cant access internet with the connection (even though internet shows connected) and a while later the network shows (!) this sign.
    So what am i doing wrong? btw the WR940N is brand new
    Quote Originally Posted by SadIkMahdI View Post
    have u copied the mac?
      • Gigabyte B85M-D3H
      • Bloody V3
      • long way 2 go..
      • B.Net
      • 2.5 Mbps
    SadIkMahdI's Avatar
    Sorry for the noob question. But how should I do that?
    your router should have an option to Clone Mac.
    you can put the mac of ur earlier router.
    TP link and SMC router have the same interface. You can just clone the mac of ur system to see what happens.
    or you can manually save the mac address.
    One more thing the in the PPoEP configuration make sure everything is properly filled up.
      • Gigabyte B85M-D3H
      • Bloody V3
      • long way 2 go..
      • B.Net
      • 2.5 Mbps
    SadIkMahdI's Avatar
    filled up the PPOEP configuration just like the previous router, so i think that part is okay. at the last stage of configuration, it shows this Click image for larger version.
ID:	32645 i tried clone MAC Address and then rebooted the router, but still it shows this Name:  Untitled 1.jpg
    dont use the easy setup assistant, manually do it via browser based control panel.
    login to your router control panel from browser. (default is 192.168.1.1 most probably) and provide some screenshot of Status, WAN and LAN
    for tplink it should be " tplinklogin.net "
      • Gigabyte B85M-D3H
      • Bloody V3
      • long way 2 go..
      • B.Net
      • 2.5 Mbps
    SadIkMahdI's Avatar
ID:	32647Click image for larger version.
ID:	32648Click image for larger version.
    tried the mac from old router
    Tried the Default mac
    Tried the cloned mac
    same result in all cases
    • EBL.Mantis's Gadgets
      • Gigabyte Z77-HD3
      • Core i7 2600 @ 4 Ghz Turbo
      • Corsair Vengeance 8GB DDR3 1600 XMP
      • Samsung F3 1TB & 500 GB F3
      • Asus 5670 DDR3 1GB
      • Dell ST2210 22" LCD
      • Xonar D2X
      • Creative 2.1
      • Genius
      • A4 Tech
      • Delta 650 Watt 80+
      • Rahimafrooz Ion 1500 KVA Sine Wave
      • Windows 7 64 bit
      • 100+ KB per second
      • 25-30 KB per second
    EBL.Mantis's Avatar
    First of all hard reset the router...then try the process again.
      • Gigabyte B85M-D3H
      • Bloody V3
      • long way 2 go..
      • B.Net
      • 2.5 Mbps
    SadIkMahdI's Avatar
    Quote Originally Posted by EBL.Mantis View Post
    u mean pressing the physical reset button for 7 or more seconds? did that too
    • Overlord's Gadgets
      • Asrock Z370 Pro4
      • Geil 8GB DDR4 2400
      • MSI GTX 970 OC Gaming 4G
      • ASUS VX229H IPS 21.5 LED
      • Built in HD Audio
      • MicroLab 2.1
      • AutoKey Gaming
      • USB Gamepad
      • Corsair VS450
      • Samsung 22X DVD RW
      • Weli Power 800VA
      • Satisfied
      • Antaranga
      • 3 Mbps
      • 3 Mbps
    Overlord's Avatar
    @SadIkMahdI I am using this same Router, mine is WR941ND. In LAN section choose Static IP then put them like this. If you dont know then call your ISP and ask them about IP,Gateway & DNS addresses.
    Quote Originally Posted by Overlord View Post
    He's connection uses PPPoE, yours is static. The two are different.
      • Gigabyte B85M-D3H
      • Bloody V3
      • long way 2 go..
      • B.Net
      • 2.5 Mbps
    SadIkMahdI's Avatar
    okay, are u sure this "static" setting will work with WAN PPOEP? gonna give it a try anyway
    yeah thats what i am thinking
    subscribing
    youse the secondary connection, static. and put put ip of ur LAN card or something :S
    just use the secondary ...
    images are showing that ur router is not connected rather it is in "connecting" mode... u sure about username and password and cables?
    hmm.. It is not connected to the isp.
    Does it connect with that same username/pass if you connect the wan cable directly to pc?
    subscribing
    Thread Tools > Subscribe to this Thread…
      • Gigabyte B85M-D3H
      • Bloody V3
      • long way 2 go..
      • B.Net
      • 2.5 Mbps
    SadIkMahdI's Avatar
    yeah coz those same username and passwords work for the current one and i did configured it
    username and passwords are okay and i did configured the current router (TL W720N) with those username and passwords successfully..
    Two words, mac filtering.
    did you try directly from pc? i.e. Without the router?
    but he tried cloning mac of the pc and the old router.
  1. Sale (Used) TP-LINK TL-W727N Wifi Receiver + 150Mbps Wifi B/G/N router
    Last Post: December 11th, 2013, 10:20
  2. Suggest a WiFi Router
    By SadIkMahdI in forum Help - PC Buying
    Last Post: August 6th, 2013, 00:41
  3. Want to buy a wifi router
    By maheer.dhruba in forum Help - PC Buying
    Last Post: August 1st, 2013, 01:43
  4. Need help regarding WiFi Router
    By Noropishach in forum Technical Support
    Last Post: November 9th, 2012, 03:37
  5. Wifi router within 6.5k
    By ochin in forum Help - General Shopping
    Last Post: September 19th, 2012, 23:16
Page generated in 0.33302 seconds with 15 queries.
