Results 1 to 18 of 18
Thread: Difference Between Non-brand Chassis And Lower-end Brand Chassis?
    • Franklin's Gadgets
      • Gigabyte z97P D3
      • NIA Wireless Headset
      • A4 tech
      • DS4 Wireless Controller
      • Cooler Master v750W
      • Asus DVD RW 24x
      • Transcend Jetflash v70 8 GB
      • DOT
      • 512 kBps with a B
      • 512 kBps with a B
    Franklin's Avatar
    Jul 2011
    Universe
    Default Difference Between Non-brand Chassis And Lower-end Brand Chassis?
    Non-brand chassis as in the ones that cost around ~2.5k. Lower-end brand chassis like TT Versea around ~3.5k. I have come across a few Space chassis costing around ~2.7k that are well-ventilated, spacious and has bottom-mounted psu option. Have good enough looks as well. Just wondering if the extra 1 or 2k for brand chassis is actually worth it. Thanks in advance.
    • -RAKIB-'s Gadgets
      • Asrock B75M
      • Intel Core i5 2310 (2.9 Ghz)--Stock Clock--Stock Fan
      • PQI-4gb-1333 Bus-single stick.
      • SAMSUNG Sata-2 (320gb)
      • Gigabyte 660-OC-2GB-Windforce2..
      • Samsung B1930-LCD-18.5 inch :(
      • Built in.
      • Creative Inspire T3200 (2:1)
      • Value Top-normal (multimedia)
      • A4tech X7..
      • Thermaltake Smart 550w- Modular
      • Samsung Writemaster-- Not using currently -_-
      • Apacer 8gb Pendrive-usb2-_-
      • Prolink-650VA
      • Windows 7-Ultimate-64bit
      • Gaming is fun, but Acquiring a Satisfactory setup for it is not -_-
      • 190kpbs
      • Havn't checked yet!
    -RAKIB-'s Avatar
    Jan 2013
    Quote Originally Posted by Franklin View Post
    There's other china casing's in that budget, they r more good looking than TT lower end and space, airflow isn't bad as well.. may b @genocide_cutter can give u a little more info about those.. he showed something like that few weeks ago..
    Why so Serious!
    • shoryuken-x's Gadgets
      • msi
      • 8gb ( to power black x)
      • 1/2 tb
      • Radeon HD 7950
      • 21.5 lcd
      • lagano hoy ni
      • Genius Gx Sw-1250
      • Delux t15s
      • venge gese
      • Tt toughpower XT 675
      • few here nd there
      • 600va
      • jana nei
      • silent htpc
      • antbd
      • 60+
      • Do
    shoryuken-x's Avatar
    ^lol ............ yep
      • Gigabyte z97P D3
      • A4 tech
      • Asus DVD RW 24x
      • DOT
      • 512 kBps with a B
      • 512 kBps with a B
    Franklin's Avatar
    Jul 2011
    Universe
    Quote Originally Posted by genocide_cutter View Post
    So, I should go with Space case then?
      • msi
      • 1/2 tb
      • Radeon HD 7950
      • 21.5 lcd
      • lagano hoy ni
      • Genius Gx Sw-1250
      • Delux t15s
      • venge gese
      • few here nd there
      • 600va
      • jana nei
      • silent htpc
      • antbd
      • 60+
      • Do
    No no ....... currently u have one good case ..... i cna sell u mine ..... apni new paben 3.2kte ...........valo ogulo
    pm me to knw more ...... space tt versa eigulo kinen nah
    • pcgamer's Gadgets
      • Gigabyte GA-Z87-HD3
      • i5 4670k
      • CORSAIR Vengeance 4 GB*2=8 GB DDR3 1600
      • Samsung 850 EVO 250GB, 1 TB WD Blue
      • ASUS ROG STRIX Radeon Rx 480 8GB OC
      • Samsung BX2035 LED LCD 20 inch
      • Onbord
      • Creative Labs Inspire 4400 4.1
      • A4TECH Multimedia
      • A4TECH
      • Asus U-75 HA 750 Watt
      • Asus DVD Writer
      • 1200 va (Battery-2x12volt 7.2 amp)
      • Windows 7 64-bit
      • Need to Update GPU
      • 100 KBps
      • 100 KBps
    pcgamer's Avatar
    Dhaka, Bangladesh, Bangladesh
    @genocide_cutter I also need some info. Sending PM .
    1. There is no good chinese casing below 2.8-3.0k.
    2. Those are of Vatyn Series. Tyrannosauras and SUC-- these two models.
    3. Vatyn is imported by Superior Electronics BD, IDB, Level 2, Left side.
    4. Tyrannosauras is market out and will not be imported anymore according to Superior Ltd.
    5. Only SUC model is available which has 1 120mm fan slot in the front, 1 200mm fan slot in the left side panel, 1 120mm rear fan at the back and 1 top 120mm fan.
    6. Side and top fan are included in the casing, no fan filter included.
    7. You can add 2 more 120mm fan at the front and at the back if you wish.
    8. No USB3.0 front panel port.
    9. Bottom mounted psu.
    10. Screwless DVDRW/HDD setup design.
    Hope this helps. DALE!
    • pcgamer's Gadgets
      • i5 4670k
      • Onbord
      • A4TECH Multimedia
      • A4TECH
      • Asus DVD Writer
      • Windows 7 64-bit
      • 100 KBps
      • 100 KBps
    pcgamer's Avatar
    I have found a delux casing with USB 3, bottom mount PSU with filter. Its on onix IDB. But with no fan included! 3k price. Planty of airflow option. Comes with no PSU. But looks kind of not soo good. I will provide link (if found)
    • -RAKIB-'s Gadgets
      • Asrock B75M
      • Built in.
      • A4tech X7..
      • Prolink-650VA
      • 190kpbs
    -RAKIB-'s Avatar
    Jan 2013
    Quote Originally Posted by pcgamer View Post
    how many fan slot?
    Why so Serious!
    • pcgamer's Gadgets
      • i5 4670k
      • Onbord
      • A4TECH Multimedia
      • A4TECH
      • Asus DVD Writer
      • Windows 7 64-bit
      • 100 KBps
      • 100 KBps
    pcgamer's Avatar
    Quote Originally Posted by -RAKIB- View Post
    how many fan slot?
    I have got the link yeah: http://www.hardware-business.com/ind...category_id/53
    But Onix has the full black version.
    how is the gigabyte casings?
    • -RAKIB-'s Gadgets
      • Asrock B75M
      • Built in.
      • A4tech X7..
      • Prolink-650VA
      • 190kpbs
    -RAKIB-'s Avatar
    Jan 2013
    Quote Originally Posted by sharan View Post
    depends on which model u r preferring to.. Apart from that, it's a reliable brand ..
    Why so Serious!
      • msi
      • 1/2 tb
      • Radeon HD 7950
      • 21.5 lcd
      • lagano hoy ni
      • Genius Gx Sw-1250
      • Delux t15s
      • venge gese
      • few here nd there
      • 600va
      • jana nei
      • silent htpc
      • antbd
      • 60+
      • Do
    sure bhai ask anytime
    GigabyteGz g1+ is good
    how many fan slot?
    2.5k te paben
    @Rakib je koita para jai ...........................................
    nije deikha lon .............
    http://www.youtube.com/watch?v=Xxh39jW-X0o
    but as far i see in bangladesh the gigabyte brand has cable management issues.
    I wanna buy that girl.
      • msi
      • 1/2 tb
      • Radeon HD 7950
      • 21.5 lcd
      • lagano hoy ni
      • Genius Gx Sw-1250
      • Delux t15s
      • venge gese
      • few here nd there
      • 600va
      • jana nei
      • silent htpc
      • antbd
      • 60+
      • Do
    onnogulo ase ..........................
    different bottle e same mal
    kotha shotto... but amar ta dekhte bhalo bd te jegula anse ogular moddhe
    actually 658R er White edition ta best dekhte but ota BD te ane nai
  1. Want to Buy Want to buy a chassis!
    By -xeibit in forum Shop - Gadgets
    Last Post: July 16th, 2013, 19:47
  2. Want to Buy Chassis
    By MaDDy in forum Shop - Gadgets
    Last Post: February 11th, 2013, 22:48
  3. Difference between cheap and brand PSU
    By arefinzz in forum Technical Support
    Last Post: February 5th, 2012, 03:37
  4. New Chassis
    By s.s.shuvo in forum Others PC Hardware
    Last Post: March 19th, 2011, 15:28
Page generated in 0.28279 seconds with 14 queries.
