Results 1 to 8 of 8
Thread: Help me buying a sound card
    • Raziel's Gadgets
      • Asus P8Z77 - V
      • Intel Core i5 2500K @4.2GHz
      • Sapphire Vapor-X HD 7970
      • Asus MS228H 21.5''
      • Realtec HD Audio
      • Microlab Solo 7c
      • Logitech K220
      • X7 XL-747
      • Logitech F510
      • TT Toughpower 750watt
      • 2 GB + 8 GB
      • Micro 1000v
      • Link 3 1MB NDP
      • 100/200
      • 1.2 Mbps
    Raziel's Avatar
    Dhanmondi, Dhaka
    Question Help me buying a sound card
    Hello, i wanna buy a new sound card, to hook it with my Solo 7c for music and movies maybe games. I've my eye on Xonar essence STX. Anyone has Any advice and suggestion? also availability of xonar in BD market? Thanks....
    • [email protected]'s Gadgets
      • Gigabyte Z97x-UD3H-BK
      • G Skill 16 GB DDR3 2200MHz
      • Asus Geforce 970 4GB
      • Asus 21.5 inch IPS monitor
      • Logitech G500s
      • EVGA G2 750W 80 plus Gold
    Tom@L's Avatar
    San Francisco, USA
    what speakers do you have ? If you dont have very good speakers, a sound card wont make any difference.
    You can take a look at Sound Blaster Z OEM version which is quite cheaper than full retail one. Xonar STX is very good for music and movies but you need good bookshelf or home theatre speakers (note: not computer speakers like logitech or Bose) to notice the audio quality difference.
    • Raziel's Gadgets
      • Asus P8Z77 - V
      • Realtec HD Audio
      • Microlab Solo 7c
      • Logitech K220
      • X7 XL-747
      • Logitech F510
      • 2 GB + 8 GB
      • Micro 1000v
      • Link 3 1MB NDP
      • 100/200
      • 1.2 Mbps
    Raziel's Avatar
    Dhanmondi, Dhaka
    using Microlab solo 7c. They are quite good for music i guess. And SB - OEM are not available in BD.
      • Logitech G500s
    Tom@L's Avatar
    San Francisco, USA
    Quote Originally Posted by Raziel View Post
    alright it seems a bookshelf speaker. You can go ahead with sound card although I have no idea about your speaker performance.
    You can also go with USB DACs if available for the price of Xonar. They will be cheaper but will give similar performance.
    • SoMoN.Khan's Gadgets
      • MSI z97 Gaming 3
      • i7 4790k
      • 8 GB
      • Adata SSD sx900,1Tb Samgsung F3 7200rpm
      • Asus GTX 780
      • Dell S2240L
      • ALC 1150
      • Solo 7c/Sony XB500
      • Cosair k70
      • A4 tech X7
      • Dilong
      • TM Tough Power 550w
      • Samgsung DVD,LiteOn DVDRW
      • Win 10 64 bit
      • 7.8
      • it ok, i dont use it that much. Office gift me mac mini !!! which i use now.
    Dec 2009
    Uttara, Dhaka
    Xonar essence STX is availanle at uttara Syed Ground. I tried solo 7c with Creative sound blaster 24bit and onboard sound, found no difference.
    Those who using solo 7c, should place his speaker at right position, at the corner and sit like 6/7away and u can feel the difference.
    • blitzkrieg's Gadgets
      • Intel DG41RQ
      • Intel Core 2 Duo E7500 Wolfdale (45nm)
      • 4GB DDR-2 800 MHz Dual Channel
      • 250 GB Samsung
      • Sapphire Radeon HD5870 PCIE 2GB GDDR5 256BIT
      • LG Flatron W1942SR
      • X-Fi platinum
      • Creative Gigaworks 5.1
      • Standard
      • Standard
      • Thermaltake Tough Power 650 watt
      • Samsung DVD writter
      • Rahimafroz 550 va
      • Windows 7 Ultimate x64
      • I'm satisfied.
      • 20
      • 56
    blitzkrieg's Avatar
    If you're willing to spend a bit more money for audiophile grade audio, then ditch the sound card all together and get yourself a USB DAC (Digital to Analogue Converter) and reference monitors.
    Quote Originally Posted by SoMoN.Khan View Post
    If it was a 2000 taka worth of Creative sound blaster card then im not surprised.
    But the diff would've been a lot pronounced if these speakers were driven from Asus Xonar Essence STX
      • MSI z97 Gaming 3
      • i7 4790k
      • 8 GB
      • Asus GTX 780
      • Dell S2240L
      • ALC 1150
      • Cosair k70
      • A4 tech X7
      • Dilong
      • Win 10 64 bit
      • 7.8
    Dec 2009
    Uttara, Dhaka
    yes may be, as i never use Xoner STX, so cant tell.
  1. Sale (Used) Creative Sound Blaster X-Fi Titanium PCI Express Sound Card
    By areek in forum Shop - Gadgets
    Last Post: August 23rd, 2013, 23:34
  2. Sale (Used) Creative Sound Blaster X-Fi Titanium PCI Express Sound Card
    Last Post: December 30th, 2012, 17:27
  3. SOund card Buying help
    By Rorschach in forum Help - PC Buying
    Last Post: May 21st, 2012, 01:25
  4. URGENT Sound Card Buying Help!
    By Irfan in forum Help - General Shopping
    Last Post: January 24th, 2012, 05:24
  5. Sale (Used) Creative Sound Blaster AUDIGY Value 7:1 Sound Card
    By Reventon in forum Shop - Gadgets
    Last Post: February 10th, 2011, 17:22
Page generated in 0.19659 seconds with 14 queries.
