Thread: System Fan & CPU Fan Speed Control
    • Rubab's Gadgets
      • Gigabyte B85M-D3H
      • Intel Core i5 4570 3.2GHz
      • G.SKILL Ripjaws (2 x 4GB) DDR3 1600 Bus
      • Samsung 840 Evo 120 + Samsung HD103SJ 1TB
      • Sapphire Dual-X R9270X 2GB
      • Benq V2220HP
      • Realtek HD Built-In
      • Creative 2:1
      • Ortek Multimedia MCK-800
      • Logitech HD Optical Mouse
      • Corsair CX600
      • Lite-On DVD-RW / Asus-DVDROM
      • Power Tree 1250P Offline UPS
      • A decent rig. :)
      • NOT Link3
    Rubab's Avatar
    Apr 2009
    Default System Fan & CPU Fan Speed Control
    Recently i purchased a B85M-D3H Motherboard and I am failing to find the automatic fan speed setting in the BIOS.
    Reading the manufacturer's manual and google didn't help much.
    The 4 available options I can find was:
    1. Silent
    2. Normal
    3. Manual
    4. Full Speed
    Isn't there supposed to be an automatic setting which would increase CPU & System(Casing) fan speed when things get hot and slow it down if I am not fully utilizing the PC?
    What other options can I select to get the best performance out of my system?
    A. Degrading fellow human beings over the internet is the only way for social rejects to feel any sense of empowerment whatsoever
    B. If one party understands something that the other party doesn't, degrading that person leads to an enhanced self-perception of intelligence
    C. The internet is a clear depiction of our natural aggression towards each other as a species, that will undoubtedly wipe itself off the planet at some point in time.
    Quote Originally Posted by Rubab View Post
    1. Silent
    2. Normal
    3. Manual
    4. Full Speed
    you can select manual and then set the PWM value...
    • @bhi's Gadgets
      • Gigabyte Z87X-UD3H
      • Samsung 30nm 2x4GB
      • Gigabyte HD7950 3GB WF3
      • Samsung 20" LED BX-2035
      • Creative SoundBlaster Z
      • Microlab Solo 7C
      • Logitech K-120
      • Logitech mx518
      • Seasonic X-650 km3 80+ Gold
      • Luminous Solo 1200 VA
      • Windows 8.1 x64
      • Link3 512kbps
      • ~60
      • ~55
    @bhi's Avatar
    On My Chair
    Manual and normal are both automatic for gigabyte. In manual you can set the speed curve by defining the pwm value and it normal it will be the default curve.
    try speedfan.
  1. Sale (New) Brand New Genius GX Control & Speed Darklight Edition Gaming mouse pad
    By Ic3_STrik3R in forum Shop - Gadgets
    Last Post: April 21st, 2013, 19:33
  2. Replies: 20
    Last Post: February 7th, 2012, 21:54
  3. How to Control the Speed of Thermaltake Thunderblade 120mm?
    By VANGUARD in forum Technical Support
    Last Post: November 22nd, 2011, 23:51
  4. Replies: 7
    Last Post: August 1st, 2011, 03:24
  5. need info abt cheap wireless router with speed control
    By saadbillah in forum Others PC Hardware
    Last Post: January 22nd, 2011, 16:37
Page generated in 0.17183 seconds with 14 queries.
