Results 1 to 6 of 6
Thread: Netbook Display problem
    • QuadStorm's Gadgets
      • Gigabyte H81M-S2PV
      • Core i5-4460
      • Toshiba 1TB
      • Asus VX229H
      • A4tech
      • ProLink Evotis
      • GameMax GM-650
      • Banglalion Modem
      • Windows 8.1 64bit
      • 120
    Mar 2012
    Chittagong
    Default Netbook Display problem
    HP mini 210 netbook....Phillips 105s5 CRT monitor er sthe lagiye duplicate korsilam...worked fine...kintu jokhon cable khule fellam tokhon netbook er display r change kora jacche na...netbook er resolution 1024*768 hoye geche ebong etke konovabei 1024*600 te ante partechi na...ki korbo?
    Ei problem er age display te ekta problem dekha diecilo...halka ekta bari khawar karone display te black ongsho full red hoye gesilo r screen jhirjhir kortesilo...pore monitor e duplicate korar kichukkhon por savabik hoileo resolution problem ta srishti hoise...kisher problem hoite pare? :/
    Connect the monitor again, set display mode to 'extend'
    Now you can set resolutions freely on both displays as required, hopefully. If this doesn't work, nuke the driver, boot -> drivercleaner the remains, reboot into vanilla and your display will hopefully pick up the native res again.
    You should be able to install the real driver again after this.
      • Core i5-4460
      • Toshiba 1TB
      • Asus VX229H
      • A4tech
      • ProLink Evotis
      • GameMax GM-650
      • Banglalion Modem
      • Windows 8.1 64bit
      • 120
    Mar 2012
    Chittagong
    sorry,couldn't get u...can u xplain a little more about the procedure?
    8.1 er driver hobe vga?
    See the multiple displays setting for starters,
      • Core i5-4460
      • Toshiba 1TB
      • Asus VX229H
      • A4tech
      • ProLink Evotis
      • GameMax GM-650
      • Banglalion Modem
      • Windows 8.1 64bit
      • 120
    Mar 2012
    Chittagong
    erokom ase na...2 pashertai same ase...ami windows renew korsi...reset korsi but kono kaj hoyna...driver update korsi...same problem :/
      • Core i5-4460
      • Toshiba 1TB
      • Asus VX229H
      • A4tech
      • ProLink Evotis
      • GameMax GM-650
      • Banglalion Modem
      • Windows 8.1 64bit
      • 120
    Mar 2012
    Chittagong
    it was actually Hardware problem! I gave it to the shop from where got it...they changed the display and everything is okay now
  1. Display Problem
    By fahimspider in forum Technical Support
    Last Post: April 9th, 2013, 02:38
  2. netbook within 25k!!
    By giant in forum Help - PC Buying
    Last Post: March 7th, 2013, 20:32
  3. laptop display problem
    By outragedhuman in forum Technical Support
    Last Post: October 19th, 2011, 22:32
  4. Laptop display problem
    Last Post: May 27th, 2011, 07:20
  5. which netbook is better?
    By ronycmc in forum Technical Support
    Last Post: January 3rd, 2011, 03:48
Page generated in 0.18322 seconds with 14 queries.
