Thread: strange problem need help
    • terrygr8_007's Gadgets
      • ASrock z77 extreme4
      • Transcend 2x4GB 1600BUS
      • Seagate Barracuda st 2TB
      • Sapphire HD7850 OC edition
      • built-in
      • CM GX650
      • Windows 7 Ultimate 64bit
    Default strange problem need help
    this is what happened...
    i tried to transfer ~750GB of data from one Ext Hd to another Ext HD..but stopped at ~135GB cause those Ext HDs were getting pretty warm
    then i downloaded HD sentinel pro to check the temps and after installation the Ext HDs were not detected
    i also have Panda USB vaccination installed
    as they were not detected and the icons changed i deleted the sentinel pro..but one Ext HD that was loaded with ~750GB data was not properly functioning and the empty one was
    so i disconnected the loaded one and right before unplugging OS showed that the drive should be formatted..and i didnt
    i tried to again but i wasn't able to get inside the Ext HD which is full of data
    USB vaccination program hanged and i tried to turn it off from task manager but it didnt turn off so i pushed the reset button
    now...
    i want to know
    is there any risk of data corruption/damage to the Ext HDs? how do i check their health status?
    how do i convert to usual desktop/hard drive icons
    thanks
    try hd tune pro and check the status and may be the hdd's temperature was too high thats why it acted abnormally, let it keep calm and again use it and maybe this time it will show everything normally,
      • built-in
      • CM GX650
    anything on the changed icons on my computer?
    you can try tuneup utility and it will fix the icon issues
  1. Strange problem in win 7
    By Speed in forum Technical Support
    Last Post: December 8th, 2014, 01:39
  2. Strange Problem!!!
    By shaikh_imtiaj in forum Technical Support
    Last Post: July 10th, 2013, 19:34
  3. Strange Problem in Nfs the run ! ! !
    Last Post: December 15th, 2011, 11:22
  4. Strange problem!!!!!
    Last Post: December 10th, 2010, 02:51
  5. Strange Pc Problem
    By D3FC0N in forum Technical Support
    Last Post: October 11th, 2010, 18:12
Page generated in 0.17343 seconds with 15 queries.
