Results 1 to 20 of 22
Thread: Difference Between TwinMOS Mainstream Series And TwinMOS ValueRAM Series (M-Tec Chip)?
    • Franklin's Gadgets
      • Gigabyte z97P D3
      • NIA Wireless Headset
      • A4 tech
      • DS4 Wireless Controller
      • Cooler Master v750W
      • Asus DVD RW 24x
      • Transcend Jetflash v70 8 GB
      • DOT
      • 512 kBps with a B
      • 512 kBps with a B
    Franklin's Avatar
    Jul 2011
    Universe
    Exclamation Difference Between TwinMOS Mainstream Series And TwinMOS ValueRAM Series (M-Tec Chip)?
    I bought a preowned 4 GB TwinMOS ValueRAM 1333 Mhz the other day and dual-channeled it with my existing 4 GB TwinMOS Mainstream 1333 Mhz. Their memory frequency is alike and I have no issues at all.
    As per Vanguard bro, he says it(the valueram) has very low longevity, durablity and no capability to overclock. Now, I am thinking of returning it. But, my decision is still tentative and I am kind of in a dilemma.
    Not sure what to do now. :/
    Edit: I have no plan on overclocking RAM at all.
    @aayman , @Vanguard , @avas911 , @dipanzan
    Quote Originally Posted by Franklin View Post
    @dipanzan
    If you don't overclock, then keep them. The longevity will depend on the IC and the condition you put it in. I'm still using my A-Data value RAM which I bought 2.5yrs back.
    Exactly. The latency of those two are different.
    but you didnt mix them up with other ones, right?
      • Gigabyte z97P D3
      • A4 tech
      • Asus DVD RW 24x
      • DOT
      • 512 kBps with a B
      • 512 kBps with a B
    Franklin's Avatar
    Jul 2011
    Universe
    Are all of your A-DATA RAMs completely similar?
    ami koyekdin age adata 4gb kinsi... Adata value ram er model number ta ki? value ram bujhbo kemne?
    I've only 1 stick of 2GB DDR3 installed. It was a 2x2GB A-Data DDR3 RAM, the other half is in another PC. I'm using this RAM because my 16GB Dominator kit is the in the US from RMA.
    Latency is also not an issue as you make it out to be. Motherboards nowadays are far more sophisticated and will accept those RAM in dual channel and configure timings appropriately. It's not that he has a 3k Trident kit, where manual/XMP tuning is required.
    Yes my RAM are similar, but I've only 1 stick installed now.
    Value as in cheap RAM. The ones which are usually without a heatsink.
      • Gigabyte z97P D3
      • A4 tech
      • Asus DVD RW 24x
      • DOT
      • 512 kBps with a B
      • 512 kBps with a B
    Franklin's Avatar
    Jul 2011
    Universe
    @dipanzan , dual-channeling those RAMs should not be an issue?
    Not if they are the same RAM/IC/make/model, they shouldn't.
      • Gigabyte z97P D3
      • A4 tech
      • Asus DVD RW 24x
      • DOT
      • 512 kBps with a B
      • 512 kBps with a B
    Franklin's Avatar
    Jul 2011
    Universe
    What's IC? :X
    but bd ram market price to utha nama kortese cheap bujhbo kemne... ar amar 1333 ram e kono heatsink o nai
    tomar value adata er model number ta dio packet thakle../.
    No. Mainstreams also comes without heatsinks. There are 5 types of twinmos in the BD market:
    1. Twinmos with M.tec chips- without heatsink 1333mhz CL9
    2. Twinmos with M.tec chips- with heatsink 1600mhz CL11
    3. Twinmos with Twinmos chips- without heatsink 1333mhz CL9
    4. Twinmos with Twinmos chips- with heatsink 1600mhz CL9
    5. Twinmos Twister - with heatsink 1600mhz CL9, can be achieved to 1600mhz CL8. XMP1.3
    • KING offspring's Gadgets
      • H61
      • i3-2100
      • 8gb
      • 1.16tb
      • gtx 960 2gb
      • tt volos
      • ps3
      • TT 450w
      • prolin650va
      • windows 10
      • 256
      • 256
    Sep 2014
    how can i find out da least latency i can run on my ram??
    now its running at 9-9-9-24
    im running
    TwinMOS ValueRAM Series (M-Tec Chip) 4gb
    • GalibTheGamer's Gadgets
      • MSI X370 Gaming Pro Carbon
      • Ryzen R5 1600 @4.0GHz
      • Gksill Ripjawas V DDR4 16GB 3000MHz
      • Samsung 850 EVO 2350GB
      • MSI GTX 1080 Gaming X
      • Philips 223V 21.5 inch monitor
      • Logitech K270
      • Bloody A9 (core 3 cracked :P )
      • Xbox One controller (Wireless)
      • EVGA G2 850W
      • A4-Tech PKS-732G Anti-glare WebCam
      • Windows 10 Pro 64-Bit
      • KC Network (3 Mbps)
    GalibTheGamer's Avatar
    May 2013
    So, are the Twinmos chips better than the M.tec chips?
    • Arka karlos's Gadgets
      • gigabyte b75m hd3
      • intel core i3 3220
      • twinmos 4gb piano black
      • western digital blue 1tb
      • sapphire 7870 dual x oc
      • dell s2240l
      • realtek onboard
      • Microlab M-590
      • habit HV-G83
      • corsair vs450 cp-9020096-uk
      • samsung s222
      • Ideal 800va
      • windows 7 ultimate 64bit
      • teletalk 3g
      • 100KBps
    Arka karlos's Avatar
    well i found the twinmos with heatsink 1333mhz cl9 in the market. that was piano black maybe.
    Quote Originally Posted by GalibTheGamer View Post
    Yes. A thousand times.
    • SoMoN.Khan's Gadgets
      • MSI z97 Gaming 3
      • i7 4790k
      • 8 GB
      • Adata SSD sx900,1Tb Samgsung F3 7200rpm
      • Asus GTX 780
      • Dell S2240L
      • ALC 1150
      • Solo 7c/Sony XB500
      • Cosair k70
      • A4 tech X7
      • Dilong
      • TM Tough Power 550w
      • Samgsung DVD,LiteOn DVDRW
      • Win 10 64 bit
      • 7.8
      • it ok, i dont use it that much. Office gift me mac mini !!! which i use now.
    Dec 2009
    Uttara, Dhaka
    is Twinmos DDR3-2133/DDR3-1866 8 gb ram available with tight timing like 8?
      • Logitech K270
      • EVGA G2 850W
    May 2013
    Ow, that was quite surprising. Can I use the part number of my RAM or through any software to detect whether my chips are of M.tec or Twinmos? I don't exactly remember since I bought them about 2 years ago.
    Unfortunately, you cant.
      • Logitech K270
      • EVGA G2 850W
    May 2013
    Oh, my bad
    So, Value series from Twinmos have M.tec chips and the Mainstream series have Twinmos chips?
    And we should try to avoid Value series always?
    I think I've read somewhere that the module manufacturers buys the chips from the fab as a bulk, and uses speed binning to sort out higher performing chips from lower performing chips. I think that's why all of them has value series modules, just to use up the chips that doesn't make up to the standards of mainstream and performance modules. It's not that you'll always find only M.tec chips only on value series and Twinmos chips only on Mainstream series. So, we should avoid value series modules whenever possible, if there are mainstream and performance series rams are available from the same manufacturer, but only for performance considerations.
    Longetivity does not depend on chip perfromance, but on some extent the fab's quality. I've heard SKHynix and Samsung are the best chip fabs, both for their higher rate of high performing chips and better longetivity.
  1. Replies: 3
    Last Post: November 15th, 2013, 19:38
  2. Sale (Used) Twinmos Mainstream series DDR3 1333Mhz RAM 2x2GB
    Last Post: November 12th, 2013, 21:51
  3. Replies: 2
    Last Post: January 25th, 2013, 01:15
  4. Sale (Used) Adata Gaming series DDR2 2GB 1600MHz and Twinmos 2GB 1333MHz
    By salmanshah in forum Shop - Gadgets
    Last Post: May 29th, 2012, 12:46
  5. Replies: 16
    Last Post: January 8th, 2012, 13:19
Page generated in 0.30556 seconds with 14 queries.
