Results 1 to 11 of 11
Thread: A minor problem of my pc
    • Banglavai's Gadgets
      • Asus Maximus VI Hero
      • Core i5 4670k
      • G-Skill Ripjaws X 2X 8GB 1600
      • 2X Samsung EVO 840 240GB
      • Gigabyte GTX 770 Windforce OC
      • Asus MX279H 27 inch
      • ROG SupremeFX 8-Channel High Definition Audio
      • Bose 301 Direct / Sennheiser Momentum 2.0
      • Logitech G105
      • Logitech G5
      • Xbox 360(usb wired)
      • Fractral Design 650 watt 80 plus gold
      • No need at all
      • Windows 8.1 64bit Professional
      • 100 Mbps
      • 30 Mbps
      • 146
    Banglavai's Avatar
    Oct 2009
    Helsinki, Finland
    Default A minor problem of my pc
    Hello.i m currently playing just cause 2 on my pendium d and 9600gt wit 2.5gb of ram.but i m facing some problems during playing this game.after playing 40-45 mins my pc became hang and didn't responce.so i hav to restart it and started playing again.i faced this problem 4 times today.keu ki bolte paren exactly ki prob hoise?thx.btw ami amar pc te ei game ta high graphics with 4x aa te more than 30+fps paitesi.its a nice game.
    Default Re: A minor problem of my pc
    either apnar PSU or apnar RAM er jonno. amio Pentium D 3.0GHz, 9600GT 512MB DDR3, 2x 1GB DDR2 667 ram, G965 mobo use kori... amar kono problem hoi na. 305W PSU diye apnar PC chalano risky. ar, RAM ero problem hoite paare,,, amar ek friend er hoise ei rokom ekbar but er por ar hoi nai.
    ar, apnar toh all high diye 30+ paowar kotha na, ami bohu struggle kore avg 25 paitesi,,, so apni er psu diye 30+ ? impossible. use fraps and check again.
    • knroeoueqisk's Gadgets
      • Intel Core i5 750
      • Cosonic head phone
      • Perfect keyboard
      • Delux optical mouse
      • Normal Non brand gamepad
      • Thermalake TR2 500 watt
      • Samsung 22X Dvd Writer
      • i am happy with it.
      • 15 Kilobytes - 64 Kilobytes
      • 5-15 kilobytes
    Dec 2009
    tomar je power supply tate tomar je graphics card ase seta cholche etai to beshi.mone hoy tomar power supply upgrade kora uchit.at least thermaltake 400 watt lite power supply kena uchit price 3300-3500 taka.UCC te paba. alpana plaza 3rd floor elephant road.
      • Core i5 4670k
      • Logitech G105
      • Logitech G5
      • No need at all
      • 100 Mbps
      • 30 Mbps
      • 146
    Banglavai's Avatar
    Oct 2009
    Helsinki, Finland
    Ami 3din age akjon er kach theke 533bus 1gb kini with 11months warrenty.oi ram er ki kono prob hobe?naki amar psu er?karon amar grafix card ta ecs 9600gte which needs no extra 6pin.thx 4 ur help.
    R ami just cause er benchmark dekhsi oita 31.25fps dekhay on my 800*600.not 1028*768.jai hok ami fraps diye dekhbone.but it runs preety smooth to my low end pc and i m happy.
      • Intel Core i5 750
      • Perfect keyboard
      • 5-15 kilobytes
    Dec 2009
    ram er problem kina bolte partesina
    but power supply ta very weak even for your "low end PC"
    jodi mone koro notun ram tai trouble korche taile oi notun ram ta khule computer chalay dekho ar just cause 2 khele dakho.dekho tate sommsar somadhan hoi naki.
    arekta advice hollo ram khule check korar age just cause 2 high setting ar AA off kore khele dekho.hoito tahole sommosar somadhan hoie jaite pare.
    Look, we both have 9600GT 512MB DDR3 and Pentium D 3.0GHz(mine is equipped with 4MB cache). U have 2.5GB ram (dunno the bus) and I have 2x 1GB DDR2 667(single channel). And, I have win7 ultimate x64 where u have x86 version(dunno which edition).
    And, truth to be told, even my thermaltake litepower 400w can't handle my crappy rig properly... So, how can ur 305w psu handle ur rig ? Look, mine is 95w tdp cpu and ur's can be 130w. So man, forget ur ram and get a ASUS 550W/500W. That would be future proofing.
    U have much worse psu than me, so u'll definitely get much lower Fps. But, I really don't understand, how the hell an extra 512MB ram can cover ur psu's major bottleneck and give u a really good performance boost over me ?! Is Just Cause 2 that ram insentive game ? It can't be.
    Btw, I benchmarked with the last in-game benchmark in this settings - aa 4x, af 8x, 1024x768, bokeh filter on, gpu accelerated water simulation on, vsync off, other settings to max. Got avg 13 fps only !!! But, played over 30 minutes without dying and recorded using fraps (that gameplay got many firefight and explosion scenes). Got avg. 25, min 21, max 33. As the fps didn't gone below 20, the game remains perfectly playable.
      • Core i5 4670k
      • Logitech G105
      • Logitech G5
      • No need at all
      • 100 Mbps
      • 30 Mbps
      • 146
    Banglavai's Avatar
    Oct 2009
    Helsinki, Finland
    Quote Originally Posted by Rion_cnGamer View Post
    look rion,my gpu is ecs 9600gte 512mb ddr3 and pentium d 925.but tomar gpu kon company er?i m sure that our processor is same.but our performance is not same.u hav a 2slot 2gb 667 ram.but i hav 4 slot 2.5gb 533 bus ram.(256(2) 1gb(2)).so ur ram is definately better than me.but i think my performance is better than u and i donno why.i m using a dell pc.and as far as i know that a brand pc performs better than a clone pc.tumi ki sure j psu bodlaye dile ami bhalo fps pabo???r fraps chalu kore game khelle fps kisuta kom dekhay.but ami amar tai kono lag painai even an explosion in just cause 2.its graphics is awesome and i love this game.recently 4 this game i bought a x747 gaming mouse o kinsi.btw thx 4 ur support.
    • avas911's Gadgets
      • Gigabyte GA-EG41MF-US2H
      • Built In Realtek ALC883
      • A4Tech X7 XL-747H 3600 DPI
      • Delta GPS-500AB A 500W
      • Asus 16x IDE DVD R
      • Rahimafrooz 600VA Premium
      • Win7 Ultimate 64Bit
      • Slow in gaming
      • Link3 512
    avas911's Avatar
    Jaber koto nilo mouse?
      • Core i5 4670k
      • Logitech G105
      • Logitech G5
      • No need at all
      • 100 Mbps
      • 30 Mbps
      • 146
    Banglavai's Avatar
    Oct 2009
    Helsinki, Finland
    1450 from global brand.joss mouse.amar khub bhalo lagse.fps game khele sheirokom moja.ashole age ami logitech 300tk er mouse chalaitam tai difference onek besi lagtese.
    Quote Originally Posted by Jaber17 View Post
    no, it's a wrong info.
    a good PSU won't only give u much better performance, but also strong stability and protection of your PC.
    btw, I think u better sell your 2 256MB DDR2 RAMs,,, ekhon sell korle jai paben, pore oitao paben na.
      • Core i5 4670k
      • Logitech G105
      • Logitech G5
      • No need at all
      • 100 Mbps
      • 30 Mbps
      • 146
    Banglavai's Avatar
    Oct 2009
    Helsinki, Finland
    @rion:-tumi parle tomar windows 7 rating gular ekta pic dao
Page generated in 0.22403 seconds with 13 queries.
