Thread: i5 3570K OC voltage and temps
    • Rawkill's Gadgets
      • Asrock Z77 Extreme 6
      • WD Blue 1TB x 2
      • Creative Sound Blaster ZX
      • Logitech F510 Rumblepad
      • Prolink 1000VA
      • Cooler Master HAF - X
      • 550-600 KB/s
      • 200-2500 KB/s
    Rawkill's Avatar
    Default i5 3570K OC voltage and temps
    I recently OCed my CPU from 3.4 to 4.4GHz. At peak usage from AIDA, Prime95 and Intel Burn Test I got the highest voltage at 1.248V (avg 1.224-1.232 V) and highest temps to be 66*C (avg 55-61 *C). Are the voltages and temps normal or are they too high ?
    yuup seems fine to me... for ivy i knew max voltage is 1.28. its below that so it should be ok.
    http://redwanhasan.blogspot.com/2013...bridge-in.html :v
    • Rawkill's Gadgets
      • WD Blue 1TB x 2
      • Prolink 1000VA
      • 550-600 KB/s
      • 200-2500 KB/s
    Rawkill's Avatar
    Thanks
  1. I5-3570k
    By Ahnaf_i7X in forum Help - PC Buying
    Last Post: April 12th, 2013, 04:35
  2. Need help buying a Voltage Stabilizer
    By dipanzan in forum Help - General Shopping
    Last Post: June 18th, 2012, 20:29
  3. i5 2nd temps
    By king_showrav416 in forum Technical Support
    Last Post: November 24th, 2011, 15:09
  4. Sale (Used) Voltage Stabilizer
    By saadbillah in forum Shop - Gadgets
    Last Post: September 23rd, 2009, 12:26
Page generated in 0.15397 seconds with 14 queries.
