Results 1 to 10 of 10
Thread: Can't figure out the problem...Please help :(
    Member Valkyrie™'s Avatar
    Default Can't figure out the problem...Please help :(
    Hello everyone, my pc is giving me a lot's of trouble lately. I bought it 1 years ago, the configurations are not good but it is ok for me.
    Intel Core2Duo 2.13 GHz
    nVIDIA 8500 GT
    1 GB DDR2
    Samsung 732NW
    400W Smart PSU (Default with Casing)
    After a night work, i put the pc in hibernate mode and slept. Next morning I went up and turned it on. I saw there was no display and the monitor was blinking. It was no ordinary blink. The light was on for 2 seconds, and off for 0.5 second.
    I opened the casing and reinstalled AGP and RAM. It worked allright. Next time I turned it off and turned on it was giving me the same problem. Yesterday it was ok if i reinserted the AGP.
    But today it is not working at all. It is giving that weird blink and I tried everything I could. If I hit the power button the computer gets turned off normally but the display is showing nothing. 1 or 2 times the monitor displayed after being kept on for 10-12 minutes but not all the time that happened. Added to that is the electricity problem so if I somehow manage to turn it on electricity goes and I am blank once again.
    Please give me some solution to the problem.
    Bleh.
    • AmareX's Gadgets
      • 1000 GB Samsung
      • Realtec 8 channel digital
      • A4tech GameMaster
      • XFX XGear
      • Transcend 4 GB Pendrive
      • Sendon Extreme 1000 VA
      • Windows 7 Ultimate x64
      • I am satisfied :)
      • GP
      • 30
      • 30
    AmareX's Avatar
    Between α and Ω.
    Default Re: Can't figure out the problem...Please help :(
    mone hosse RAM/GFX slot er somossa.
    01. RAM r GFX slot e ekta patla minus screw driver dhukay halka kore top to bottom move korte paren tahole slot er pin gular oxide remove hoye jabe.
    02. RAM and GFX er pin gula rubber eraser diye valo kore rub korun...
    Then try again putting them on slot with added pressure.
      • Asus P5KPL-AM
      • Dual Core E5400
      • Built-In
      • AOC F22 22"
      • Realtek
      • Delux
      • BUSTED !
      • Transcend 16GB
      • DigitalX 650VA
      • Windows 8 Pro x64
      • IS PROS
      • Average: 24 Kbps
      • Average: 24 Kbps
    йЦммєя³¹'s Avatar
    Apr 2009
    try cleaning the slots and the connectors of the gfx and the mobo
    sometimes the dirt gathered there can hamper the electricity flow
    had some what similar problem with my old p4 pc
    Thanks I will try that. Any other ideas? If that thing doesn't work?
    Bleh.
    Ok, I tried what you all said but it didn't work. I found out that the pc is working fine, if I put it in hibernate mode (start button -> up -> enter) and then turned on again, the display appears after 2-3 minutes. Can someone tell me what problem is this :S?
    Bleh.
    • AmareX's Gadgets
      • 1000 GB Samsung
      • A4tech GameMaster
      • XFX XGear
      • I am satisfied :)
      • GP
      • 30
      • 30
    AmareX's Avatar
    Between α and Ω.
    I guess its time to check your PC with another GFX card!!
    Just try it.
    Try switching it on with the built in GPU?
    If so, you know your GPU went poof :<
    Built in gpu doesn't work either...though I am not sure if its ok, it never worked...i was served with a crap pc
    Bleh.
    • AmareX's Gadgets
      • 1000 GB Samsung
      • LG Flatron W1942S 19&quot; wide 16:10 LCD
      • A4tech GameMaster
      • XFX XGear
      • I am satisfied :)
      • GP
      • 30
      • 30
    AmareX's Avatar
    Between α and Ω.
    R u sure that your built in GFX isnt turned off from bios? If not, reset the BIOS and try built in again.
    Besides that, try another GFX card to be sure.
    • Flame's Gadgets
      • MSI 880GMA-E35
      • AMD Phenom II X6 1090T @ 3.2Ghz
      • 2x4GB Transcend DDR3 1333MHz
      • 2TB Hitachi 7200RPM
      • XFX AMD HD6850 1GB
      • LG Flatron W1953T 18.5&quot;
      • Realtek HD Audio
      • Creative | A4Tech
      • Genius KB 101
      • Genius X Scroll
      • Genius Maxfire
      • Tt TR2 500W
      • ASUS DVD-RW
      • ADATA 320GB External HDD
      • Prolink somethingsomething
      • Windows 7 Ultimate (64-bit)
      • 5.9 | 7.7 (without HDD)
      • BEST! :D
      • Spark
      • 45
      • 35
    Flame's Avatar
    Aug 2008
    Something like this happened to me once. My monitor would start to 'turn on' but would immediately go off and repeat the process. Monitor'er display ar light schit-schit korto. But CPU would act normal. Turned out my monitor was broken.
  1. HDD Problem ...
    Last Post: March 17th, 2010, 00:40
  2. HDD problem
    By theprince in forum Technical Support
    Last Post: September 30th, 2009, 19:08
  3. PSU Problem
    Last Post: May 13th, 2009, 03:57
  4. Got Problem
    By s.a_rocky in forum Older NFS Games
    Last Post: January 29th, 2009, 11:20
  5. dl problem in RS
Page generated in 0.21585 seconds with 14 queries.
