Thread: facing problems with gts 250...!!!!
    • morshedkhan97's Gadgets
      • GB 965g-ds3 rev 3.3
      • e5200 OCed @ 3.0 GHZ with Freezer 7 pro
      • 3gb ddr2 800 mhz
      • 250 gb sata
      • gigabyte hd 5770 1 gb
      • lg flatron 17" crt
      • thermaltake 420 watt
      • 7 32 bit
      • not a monster...but gets my job done...
    Jan 2010
    Unhappy facing problems with gts 250...!!!!
    whenever i run a gpu stress software like furmark or OCCT my pc turns off automatically.......i noticed that this anomaly only happens when my gpu reaches 82 or above.......i dont face this problem when i play games....except this one time when i was playing crysis warhead....
    when i run occt it shows some error...like some glitches or something....
    • avas911's Gadgets
      • Gigabyte GA-EG41MF-US2H
      • Built In Realtek ALC883
      • A4Tech X7 XL-747H 3600 DPI
      • Delta GPS-500AB A 500W
      • Asus 16x IDE DVD R
      • Rahimafrooz 600VA Premium
      • Win7 Ultimate 64Bit
      • Slow in gaming
      • Link3 512
    avas911's Avatar
    Default Re: facing problems with gts 250...!!!!
    OCCT and some benchmark tools do a test called burn in test...they use all possible available resources of the card...so it pulls highest power and gets very hot...most gpus now a days have a fail safe trigger from frying or destroying your card....it shuts down the chip.....a game doesnt try to load all the shader cores of a a card...so it doesnt happen when you are playing games...may be not in case of crysis....here what Ryan Smith said in the anadtech review of 5870....
    That problem reared its head a lot for the RV770 in particular, with the rise in popularity of stress testing programs like FurMark and OCCT. Although stress testers on the CPU side are nothing new, FurMark and OCCT heralded a new generation of GPU stress testers that were extremely effective in generating a maximum load. Unfortunately for RV770, the maximum possible load and the TDP are pretty far apart, which becomes a problem since the VRMs used in a card only need to be spec’d to meet the TDP of a card plus some safety room. They don’t need to be able to meet whatever the true maximum load of a card can be, as it should never happen.
    Why is this? AMD believes that the instruction streams generated by OCCT and FurMark are entirely unrealistic. They try to hit everything at once, and this is something that they don’t believe a game or even a GPGPU application would ever do. For this reason these programs are held in low regard by AMD, and in our discussions with them they referred to them as “power viruses”, a term that’s normally associated with malware. We don’t agree with the terminology, but in our testing we can’t disagree with AMD about the realism of their load – we can’t find anything that generates the same kind of loads as OCCT and FurMark.
    Regardless of what AMD wants to call these stress testers, there was a real problem when they were run on RV770. The overcurrent situation they created was too much for the VRMs on many cards, and as a failsafe these cards would shut down to protect the VRMs. At a user level shutting down like this isn’t a very helpful failsafe mode. At a hardware level shutting down like this isn’t enough to protect the VRMs in all situations. Ultimately these programs were capable of permanently damaging RV770 cards, and AMD needed to do something about it. For RV770 they could use the drivers to throttle these programs; until Catalyst 9.8 they detected the program by name, and since 9.8 they detect the ratio of texture to ALU instructions (Ed: We’re told NVIDIA throttles similarly, but we don’t have a good control for testing this statement). This keeps RV770 safe, but it wasn’t good enough. It’s a hardware problem, the solution needs to be in hardware, particularly if anyone really did write a power virus in the future that the drivers couldn’t stop, in an attempt to break cards on a wide scale.
    Source
    • knroeoueqisk's Gadgets
      • Intel Core i5 750
      • Cosonic head phone
      • Perfect keyboard
      • Delux optical mouse
      • Normal Non brand gamepad
      • Thermalake TR2 500 watt
      • Samsung 22X Dvd Writer
      • i am happy with it.
      • 15 Kilobytes - 64 Kilobytes
      • 5-15 kilobytes
    Dec 2009
    "It’s a hardware problem, the solution needs to be in hardware, particularly if anyone really did write a power virus in the future that the drivers couldn’t stop, in an attempt to break cards on a wide scale."
    • avas911's Gadgets
      • Slow in gaming
      • Link3 512
    avas911's Avatar
    I dont think so....just gpu makers are throttling the softwares...
  1. Smile: anyone facing browsing problem?
    By AmareX in forum Smile/BDCom
    Last Post: February 5th, 2010, 14:39
  2. game problems
    Last Post: December 3rd, 2009, 12:25
  3. UT 3 Facing Worlds, aka Face Classic, aka Face returns to UT3
    By TAW_LegendaryHero in forum Unreal Tournament
    Last Post: July 22nd, 2008, 07:02
  4. Problems!!
    By Deep -xCross- in forum Technical Support
    Last Post: May 27th, 2008, 11:22
  5. Farming problems
    By kabir_sharif2000 in forum DotA Talk
    Last Post: May 21st, 2008, 13:42
Page generated in 0.16812 seconds with 14 queries.
