Results 1 to 10 of 10
Thread: Freezer 7 Pro
    • Red Devil's Gadgets
      • Gigabyte Z68X-UD5-B3
      • Intel Core i5-2500K Sandy Bridge @4.00 GHz with Corsair H75 LC
      • AVEXIR - Core Series 8GB(4GBX2) 1600MHz @9-9-9-24
      • Samsung 850 Evo 250GB SSD + Seagate Barracuda (4TB+3TB) HDD
      • MSI GTX 960 2GB
      • ASUS VX229H IPS Panel Monitor
      • Creative Sound Blaster X-FI Titanium
      • Altec Lansing expressionist ultra MX6021
      • Corsair Vengeance K70 Mechanical Keyboard
      • A4tech Bloody V9C/Razer Goliathus Fragged Control Edition
      • XBOX One Wireless Controller
      • Thermaltake Smart SE 630M || Cooler Master HAF 912 Advance Mid Tower Case
      • Pioneer DVD RW
      • Transcend V60 8GB, Apacer 2GB pen drive
      • RahimAfroz 800VA
      • Windows 10™ Pro 64 Bit
      • My PC is my life......
      • ICC
      • 8mbps
    Red Devil's Avatar
    Default Freezer 7 Pro
    Want to sell a Freezer 7 Pro CPU Cooler. it is completely new & boxed.
    My asking price is 2800BDT(Fixed). If any 1 want to buy this then call me @01816275789 or send me a PM
    Awarding- Winning High Performance CPU Cooler
    Main Features
    Extremely Quiet
    The low speed 92 mm fan reduces the noise level to a minimum.
    The patented fan holder is able to practically eliminate the typical buzzing sound of 92 mm fans.
    Patent No 203 07 981 U1 (Germany)
    Patent No 10/834 232 (USA)
    The PWM chip in the motor allows an exact fan speed control via BIOS. (4 wire)
    Powerful cooling
    6 Heat Pipes (three used double sided) are able to transfer heat up to 200 Watt. The heat exchanger is built of 42 fins and consists of a surface area of over 4700 cm2 and allows for resistance free energy transfer to air.
    Integrated Cooling of Voltage Converters
    Air is drawn in from the side of the fan to cool the components around the CPU.
    Some air is blown out towards the voltage converters on the mainboard with the bent fins at the bottom.
    Patented Vibration Absorption
    The four rubber connectors on the fan case act as a vibration damper to absorb the vibration of the running fan and prevent vibration transfer to the heatsink and the case.
    Easy Installation
    The cooler is to install without any tools within seconds.
    Specifications
    Heat Sink: 104 x 58 x 126.5 mm
    Fan: 107 x 43.5 x 96 mm
    Overall Dimensions: 107 x 96.5 x 126.5 mm
    Rated Fan Speed: 900 - 2500 RPM (PWM)
    Bearing: Ceramic Bearing
    Power Consumption: 0.16 Amp.
    Air Flow: 45 CFM / 77 m3/h
    Weight: 520 g
    Noise Level: 0.9 Sone
    Thermal Resistance: 0.17C/Watt
    Thermal Interface Material: Pre-applied MX-1 / MX-2 Paste
       0
    • ЯV●@spret's Gadgets
      • Asus 970 pro
      • AMD FX-6100 @ 3.5ghz
      • Kingstone Hyper-X 1600mhz 8GB DDR3
      • Samsung Spinpoint 1TB 7200rpm
      • XFX HD 6870 @ 910mhz
      • Viewsonic 17'' LCD @ 1440x900
      • Creative Tactic 3d Alpha USB sound card
      • Thermaltake TT Shock
      • A4 Tech Normal
      • A4 Tech 2x Office
      • Xbox 360 controller
      • Gigabyte Superb 720W
      • WD Ext. 2TB 7200 rpm HDD
      • RahimAfrooz 100VA Premium
      • Windows 7 home premium 64 bit
      • dont know
      • Awsome....
      • 110-135kbps(avg)
      • 64kbps
    ЯV●@spret's Avatar
    Chittagong
    Default Re: Freezer 7 Pro
    Arctic cooling asolei boss cooler.....amar 9600gt r cooler o ai companyr.....marvelous.....ai jinis sell kortesen ken
    Speed is like ADDICTION.....
       0
      • MSI GTX 960 2GB
      • Pioneer DVD RW
      • RahimAfroz 800VA
      • ICC
      • 8mbps
    Red Devil's Avatar
    ami bro aita sell korar jonnoi ansi..............!!
       0
      • Asus 970 pro
      • A4 Tech Normal
      • A4 Tech 2x Office
      • dont know
      • Awsome....
      • 110-135kbps(avg)
      • 64kbps
    ЯV●@spret's Avatar
    Chittagong
    hmmmm.........valo.........amar hate akon tk thakle kine feltam.......AC asolei boss
       0
    • Black Neon's Gadgets
      • Gigabyte GA-Z87X-UD3H
      • Intel 4570 3.2 GHz Core i5 4th Gen.
      • 16 GB Corsair Vengeance DDR3 [1600]
      • [W.D. Caviar Blue 2 T.B. X4] + [W.D. Caviar Blue 1 T.B. X1] + [Transcend StoreJet USB 3 1 TB X3]
      • Sapphire HD7870 GHZ EDITION OC VERSION 2G GDDR5
      • ASUS VX229H + ASUS VX229H [Dual Display]
      • Creative Inspire 6.1
      • Logitech G510 Gaming Keyboard and Logitech G13 Advanced Gameboard
      • Logitech G 500
      • Logitech Rumble PAD 2 & Microsoft XBOX 360
      • Thermaltake Toughpower Grand 750W
      • ASUS 18X SATA DVD-RW and Samsung 22X USB Extarnal DVD-RW
      • Transcend StoreJet 35 ULTRA
      • Apollo 1200 V/A
      • Windows 7 Ultimate Edition X64
      • I hate Benchmark
      • IT's OK For Me....
      • Teletalk 3G
      • 128 KBPS
      • 64 KBPS
      • 138
    Black Neon's Avatar
    Pallabi, Dhaka
    Eita ki revision 1 na 2?
       0
    • Speed's Gadgets
      • Creative ZxR| Built In
      • ASUS DVD +/-RW
      • USPOWER 2000va Online UPS
      • Windows 10 Pro 64 bit
      • DHAKANET
      • 750
      • 650
    Speed's Avatar
    Khilgaon
    aharey cooler ta dekhey tou valoi lagtesey....but,same as @spret....hatey taka ekdom e nai.....nailey nogod e kintum....bty,RD vai ei cooler tai ki manual fan control asey?.....i mean fan control tou bios e lekha dekha jachey?
       0
      • MSI GTX 960 2GB
      • Pioneer DVD RW
      • RahimAfroz 800VA
      • ICC
      • 8mbps
    Red Devil's Avatar
    Quote Originally Posted by Black Neon View Post
    rupel vai...aita 1..........1 ta 2 o silo.......but oita sell hoia gese...
       0
      • MSI GTX 960 2GB
      • Pioneer DVD RW
      • RahimAfroz 800VA
      • ICC
      • 8mbps
    Red Devil's Avatar
    Quote Originally Posted by ЯV●Speed View Post
    nop....bro......just pwm fan control .
       0
      • MSI GTX 960 2GB
      • Pioneer DVD RW
      • RahimAfroz 800VA
      • ICC
      • 8mbps
    Red Devil's Avatar
    Product sold.........
    @mod close this thread.
       0
    • AmareX's Gadgets
      • 1000 GB Samsung
      • Realtec 8 channel digital
      • A4tech GameMaster
      • XFX XGear
      • Transcend 4 GB Pendrive
      • Sendon Extreme 1000 VA
      • Windows 7 Ultimate x64
      • I am satisfied :)
      • GP
      • 30
      • 30
    AmareX's Avatar
    Between α and Ω.
    Thread Closed.
       0
  1. Closed Freezer 7 Pro Rev.2
    Last Post: January 2nd, 2010, 12:00
Page generated in 0.22068 seconds with 14 queries.
