Results 1 to 8 of 8
Thread: Help on Redialing a PPPoe Connection Auto
    • ABDmaster's Gadgets
      • Intel Media Series DP35DP
      • Core2Extreme 3.0 GHz QX6850
      • Transcend 2 GB DDR2 800MHz
      • Samsung 1TB F1 + Western Digital 320GB Blue
      • ATi Sapphire HD4670 512MB
      • Asus 19" VW192T
      • Built-in 7:1
      • Logitech Rumblepad2
      • ThermalTake 500W TR2
      • Apollo 1000VA
      • Windows Vista SP2 32-bit
      • Spark
      • 20 to 30
    Uttara, Dhaka
    Default Help on Redialing a PPPoe Connection Auto
    I set the redial setting on my PPPoe Broadband connection, but It never seems to redial the connection when the line is dropped. Please tell me how to fix it. Its really annoying when the line goes off when playing games, sleeping or went outside, while lossing my downloads.
    Using Windows Vista SP2 32bit and my connection is SparkBD
    • Speed's Gadgets
      • Creative ZxR| Built In
      • ASUS DVD +/-RW
      • USPOWER 2000va Online UPS
      • Windows 10 Pro 64 bit
      • DHAKANET
      • 750
      • 650
    Speed's Avatar
    Khilgaon
    Default Re: Help on Redialing a PPPoe Connection Auto
    Quote Originally Posted by ABDmaster View Post
    this happens to me as well......my redial is set to 99 times......seems redialing works for me....but,u know 99 is a low number if the connection is dropped for more than 3 hrs.....so,after that 99 times my connection just stall....indeed it's very annoying this pppoe connection type...but,it's our faith or luck that max of us don't get a direct connection
    • AmareX's Gadgets
      • 1000 GB Samsung
      • Realtec 8 channel digital
      • A4tech GameMaster
      • XFX XGear
      • Transcend 4 GB Pendrive
      • Sendon Extreme 1000 VA
      • Windows 7 Ultimate x64
      • I am satisfied :)
      • GP
      • 30
      • 30
    AmareX's Avatar
    Between α and Ω.
    Go to Control panel>Internet Option>Connection and set to "Always dial my connection".
    Next, go to your PPPOE Dial UP Connections Properties>Options and Set redial attempts as much as you can (like 999999) and set "time between redial attempts" to 1 seconds, "idle time before hanging up" should be "never". Then check "Redial if line dropped".
    There are also some free software (search google for reconnect/redial soft) for this job but they are not essential if you do the steps stated above correctly.
    • Speed's Gadgets
      • ASUS DVD +/-RW
      • DHAKANET
      • 750
      • 650
    Speed's Avatar
    Khilgaon
    Quote Originally Posted by @mrX View Post
    correction: redial attempts on windows 7(maybe vista & xp also) is limited to 99
    • AmareX's Gadgets
      • 1000 GB Samsung
      • A4tech GameMaster
      • XFX XGear
      • I am satisfied :)
      • GP
      • 30
      • 30
    AmareX's Avatar
    Between α and Ω.
    Quote Originally Posted by ЯV●Speed View Post
    Sorry Speed I missed that, in that case, for Win7 users, I would suggest atleast "1 min" time between redial attempts for longer redialing.
    In Xp, u can enter upto 999999999.
    Noblesse Oblige
    • CvP's Gadgets
      • ASUS P8Z77 V Delux
      • Intel Core i7 3770K @3.9GHz
      • EVGA 980Ti 6GB
      • Samsung 17"+22"+22"
      • Realtek HD Audio <internal>
      • Creative Inspire 5:1
      • Razer BlackWidow Ultimate
      • G7
      • Seasonic X 850W 80Plus Gold
      • External DVD-RW
      • Link3/Amber IT
      • 10000
      • 10000
    CvP's Avatar
    install WinPOET
      • Asus 19" VW192T
      • Built-in 7:1
      • Apollo 1000VA
      • Spark
      • 20 to 30
    Uttara, Dhaka
    The redial wont work in the normal way... Have downloaded ReConnect ...
    now i probably have to wait and see until the line drops ...
      • Asus 19" VW192T
      • Built-in 7:1
      • Apollo 1000VA
      • Spark
      • 20 to 30
    Uttara, Dhaka
    Tested ReConnect..... it works quite good..... it got some little bugs, but as long it helps me to redail the connection after dropped, i'm fine with it..!!!
  1. Replies: 20
    Last Post: July 5th, 2010, 08:38
  2. Auto Shutdown software for 7
    By йЦммєя in forum Software
    Last Post: September 9th, 2009, 17:30
  3. Auto turn off UPS MOD!!
    By minitt in forum Others PC Hardware
    Last Post: April 19th, 2009, 01:49
  4. Auto Downloading :|
    Last Post: October 14th, 2008, 20:44
  5. Auto LogOff
    By xk::v (Gimmjaw) in forum Technical Support
    Last Post: May 9th, 2008, 23:24
Page generated in 0.20637 seconds with 14 queries.
