Results 1 to 16 of 16
Thread: Need efficient help to overclock Q8200
    • Extreme Noob's Gadgets
      • Gigabyte P67A-UD3R-B3
      • Intel Core i5 2500k @4.3Ghz with CM Hyper212+
      • G-Skill Ripjaws X 4GBX2 1600Mhz @8-8-8-20
      • Mushkin Callisto Deluxe 40GB SSD; WD Caviar Black 1TB SATA3; Samsung Spinpoint F3 500 GB
      • Sapphire Radeon HD6950 2GB unlocked to HD6970; XFX GT240 as a dedicated Physx Card
      • Viewsonic VX2260WM 22 inch Full HD LCD Monitor
      • Creative Sound Blaster X-fi Titanium PCI-E
      • Microlab Solo 7c 2.0 Full Range Stereo Speakers
      • A4 Tech Slim Normal Keyboard
      • A4 Tech X7 Laser 3600DPI gaming mouse with Razer Goliathus Speed Edition
      • Xbox 360 Controller ; DIGI USB Joystick
      • Corsair TX650w V2
      • Asus SATA 24x DVD R/W Dual Layer
      • Twinmos USB Flash Disk 4 GB
      • Micro 1000VA
      • Windows 7 Ultimate 64Bit
      • 3D Mark Vantage- P24529; 3D Mark 11- P5642
      • Housed in a Cooler Master HAF 912 Advanced
      • IsPros
      • 30KBPS
      • Do not Know
    Extreme Noob's Avatar
    Sep 2009
    Mohammadpur, Dhaka, Bangladesh,
    Default Need efficient help to overclock Q8200
    CPU:Q8200
    Core Clock: 2.33ghz>2.93ghz (333X7)=2333mhz>(419X7)=2933mhz;
    CPU multiplier:7x ;
    FSB:1333>1676
    Temp:34*c(idle)/53*c(OCCT Linepack CPU stress test for 2 hours) ;
    RAM: @Stock 838 mhz(after some tweaking with ram latency & memory multiplier settings in the bios;
    RAM Timings: 5-5-5-15
    DRAM : FSB=1:1
    VCORE:1.18750v
    MCH core: 1.20000v
    ICH I/O: 1.55000v
    DRAM Voltage: 1.80000v
    With all powersaving features(C1E,C2E,EIST) kept off &
    with Thermaltake V1-AX Cpu cooler.
    Now my question is: 1.if I reach 429 fsb then what should be my safe vcore?do I need to bump up my NB & SB voltage then?on that case will the motherboard need any kind of cooling? 2.my rams are from transcend which are not very durable.up to which range there rams are overclockable without cooling?remember I don't want to do anything that can affect my components longivity. I wish I will get proper instructions from overclocking masters like MAZHAR,MURAD9,@marex.please help me guys.advanced thanks.
    ---------- Post added at 12:26 ---------- Previous post was at 10:45 ----------
    Isn't anyone there to help me ?
    • shaikh_imtiaj's Gadgets
      • Asus P6X58D-E| Gigabyte G31-ES2C
      • Core i7 930 @ 3.88GHZ cooled by True Spirit| E5200 @ 3.15Ghz
      • Patriot 6GB DDR3 1600| Transcend 3GB DDR2
      • Samsung F3 500GB|Samsung 160GB +Samsung 1TB F1
      • Gigabyte GTX660 OC| Intel GMA3000
      • Asus MS228H LED
      • Creative x-fi Titanium | intregreted realtek x-fi modded
      • Creative GigaworksT20 +Inspire2.1|A4tech HS-800 Gaming Headphone
      • Newmen Backlit Gaming KB E370Logitech NewTouch 100
      • A4tech X7 747H | Logitech M90| A4tech x7
      • XFX Dual analog | Xbox360 wired Controller
      • XFX 650W Core edition|Thermaltake Litepower 400W
      • Benq DVD/RW, Benq DVD rom
      • Canon Lide25| WD 500GB USB3| 16GB+8GB Transcend | 2GB PNY
      • Rahim Afrooz 600va
      • Windows 7 x64|Windows xp sp2+Windows 7 build7600
      • A killer PC...Grrrrrr
      • Link3 | Banglalion
      • 60-70 | 100
      • 60-70 | 8
    shaikh_imtiaj's Avatar
    Jan 2009
    Greenroad,Dhaka
    Default Re: Need efficient help to overclock Q8200
    If u kept the voltage within 1.25v u will be safe. But first set the desired fsb in the bios and bump up the voltage a little. And then check if the system is stable or not. Ur mobo is based on p43 chipset it can handle high fsb. So i dont think u will not need to increase the NB and SB voltage. And at that fsb it will not require any special cooling. For safety manage a good air flow on your case.
    And transcend rams can do 850mhz without much problem as far as i know. It will not lessen ur rams longevity that much.
    So in bios make the fsb 425 and bump up the voltage a little and stress the system for 2 hour to check the system is stable or not. If not then bump up the voltage a bit. And post ur result.
    For secondary use: E2160 OC @2.2Ghz| Gigabyte 945GCMX| 1.5GB DDR2| Thermaltake 400w| Intel GMA 950
    Quote Originally Posted by shaikh_imtiaj View Post
    yup, shaikh bhaiya
    well transcend RAM gula erektu beshi gese amr mobo te, like it was stable till 890MHz & then memtest e fail kortesilo
    ar voltage 1.35 is the deadline from INTEL, but imo opinion it doesnt hurt much if you go till 1.4 & that would suffice for a 3.2-3.4 clock
    ar afaik, do an overnight prime to ensure that the system is completely stable & also run a session of Crysis & GTA4 if you have them installed
    if you find that the system is not stable even after providing ample voltage like for eg 1.3-1.35...bumb the NB & SB one notch & try to keep the FSBRAM to a 1:1 ratio & regarding temps, hope your cooler keeps below 75C
    • Uchiha Obito's Gadgets
      • ASUS P7H55M
      • A4Tech X7
      • 1 x Samsung DVD-RW
      • Transcend 16GB JetFlash 700
      • Windows 7 x64 + Linux x64
      • Didn't see till now.
      • RIG OK and Console Awesome.
      • BTCL ADSL 512kbps, 1mbps
      • 60KB/s and 120KB/s
      • Secret
    Uchiha Obito's Avatar
    Sep 2008
    Mymensingh, Bangladesh.
    amar transcend RAM is stable at 944MHz.:S
    ar ami 3.4GHz e koekdin chalaisi ASUS Cooler bechbar age.:Stokhon mone hoi 1042.2Mhz e operate korto RAm duita.
    and yeah stable cilo.:]
    dip tomar to AXE ram na?
    Quote Originally Posted by Sumon Datta View Post
    nah normal JetRAM
      • Corsair TX650w V2
      • Micro 1000VA
      • IsPros
      • 30KBPS
      • Do not Know
    Sep 2009
    Thanks. that will help a lot.to me safety & longibity>performance in terms of overclocking.I don't want to rise my cpu temp above 60*c.I will try according to your proposed settings and will post result here.
    ---------- Post added at 13:50 ---------- Previous post was at 13:41 ----------
    yup, shaikh bhaiya
    Dipanzan which kind of memtest is this?is this any kind of software which can test your rams?if it is then please give me the download link.I need a programme which can make my ram maximum stressed with showing real time ram temp and voltage.
      • Asus MS228H LED
      • 60-70 | 100
      • 60-70 | 8
    Jan 2009
    Greenroad,Dhaka
    Guyz don't suggest him to go for high oc on ram as he wants safe oc. In high oc it might me stable but it will lessen the longevity of ram if theres no proper cooling.
      • Corsair TX650w V2
      • Micro 1000VA
      • IsPros
      • 30KBPS
      • Do not Know
    Sep 2009
    Where are Mazhar bro,@marex,murad9?plz comment bout my problem.
    • Mazhar's Gadgets
      • ASUS B250 Strix
      • AMD Ryzen 1700X
      • G.Skill 2x8GB DDR4 3200
      • Samsung 850 Pro 1TB
      • Gigabyte 1070Ti
      • Dell U2711
      • ASUS Essence STX II
      • Beyerdynamic Tesla T1
      • G910
      • G502
      • Xbox One Controller
      • Windows 10 Home
      • Aamra
    Mazhar's Avatar
    First of all, turn all power saving features, especially C1E,off. Only thing that you might keep on is speedstep, turn all other power saving features off. Thats the first rule of thumb.
    420+ FSB might require a change in FSB strap. What FSB: DRAM ratio are u using? Just mention me your fsb and dram speed, thatl do. About safe core voltage, 1.35V is safe, as dipanzan mentioned earlier. Temps up to 75'C load is fine, provided volts are below 1.35v.
    About NB voltage, it depends on the strap, since a 400mhz strap should not require any additional voltage at 430fsb. if a 333mhz strap is used, it might require a voltage increase, but I suggest not overvolting the NB by more than 0.1v with stock motherboard cooling (ie 1.2v to 1.3v). Remember, never increase the volts if your system doesnt require it. If it becomes unstable, increase volts by one increment and see if it stabilizes. If CPU core volt is 1.3V, and you increase FSB from 420 to 430 which causes instability, increase core volt by one increment, then two. If none of them help, go back to 1.3v and increase another voltage, for example NB voltage or DRAM voltage (check your DRAM chips used, give me the serial numbers in the RAM chip itself since saying transcend will help 0%). Any DRAM chip usually OC to around 900mhz, but the point is you can always use a 2:1 strap which if i remember correctly is 400fsb strap, which will mean at 450fsb your memory speed will be 900mhz, which should be doable.
    Dont do the OCCT Linpack test. Do the normal auto (1h) test. Then do 1 hour of Linpack too if you want.
      • Corsair TX650w V2
      • Micro 1000VA
      • IsPros
      • 30KBPS
      • Do not Know
    Sep 2009
    Bro,I have given all informations about my settings in the first post.please read it carefully.I am using 1:1 fsb:dram @400mhz strap.my ram is ddr2 transcend so that It is being operated at 800mhz on 400mhz strap.
    • Mazhar's Gadgets
      • ASUS B250 Strix
      • AMD Ryzen 1700X
      • Gigabyte 1070Ti
      • Dell U2711
      • G910
      • G502
      • Windows 10 Home
      • Aamra
    Mazhar's Avatar
    read my post carefully. I mentioned setting it to 2:1 fsb : dram, so that at 400fsb (1600) your DRAM speed is 800mhz and operating at a 400fsb strap. Then work your way up
    Also, i mentioned saying transcend is going to help 0% since they use different chips binned at the same 800mhz speed in the exact same model line, hence the reason why a few jetrams clock better than axerams. I need the numbers and digits printed on the RAM chip itself to determine its max rated voltage and overclockability
    impeccable advice Mazhar bhaiya, I would just like to add one more thing: if the motherboard aint that good with vdroop, turn off speedstep & give it a go, this way you can venture for higher volts...but it might not be required since the overclock is not that big xD & dramaviewer: using a 2:1 strap will let your modules remain at their rated frequencies whilst letting your CPU to get overclocks I hope you get it now.
      • Corsair TX650w V2
      • Micro 1000VA
      • IsPros
      • 30KBPS
      • Do not Know
    Sep 2009
    My present clockspeed: 400*7=1600mhz;MCH Frequency latch: 400mhz;system memory multiplier: 2.00D - this is my current setting which makes fsb:dram=1:1 ram serial numbers: 5192010157 & 519871-4732
    Quote Originally Posted by dramaviewer View Post
    My fsb: 400*7=1600mhz;MCH Frequency latch: 400mhz;system memory multiplier: 2.00D - this is my current setting which makes fsb:dram=1:1 ram serial numbers: 5192010157 & 519871-4732
    eh :O now isnt 400*7=2800MHz or 2.8GHz =P
      • ASUS P7H55M
      • A4Tech X7
      • Secret
    Sep 2008
    ayee 400x7= 1600?
    ore bhai FSB: DRAM Ratio ta apni doya kore everest diye check kore dekhben?
      • Corsair TX650w V2
      • Micro 1000VA
      • IsPros
      • 30KBPS
      • Do not Know
    Sep 2009
    ayee 400x7= 1600?
    Sorry oita amar clockspeed chilo after overclocking :400 X 7=2800Mhz.ar ami FSB ta ke 1333 theke 1600 korsi.thank u 4 correcting me
    আমি এখন আর গেম খেলি না...
  1. Closed Intel Core 2 Quad Q8200 2.33 Ghz
    By Extreme Noob in forum Shop - Gadgets
    Last Post: November 28th, 2009, 16:37
  2. Replies: 0
    Last Post: October 20th, 2009, 11:11
  3. Replies: 2
    Last Post: June 24th, 2009, 23:19
  4. Q6600 or Q8200
    By awestruck in forum CPU
    Last Post: November 7th, 2008, 03:17
Page generated in 0.29886 seconds with 14 queries.
